All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Dec 5, 2022 at 1:21 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I don't have a camper or cap but I do have a bedrack i throw on every so often. I don't use the side mount like that. a lot of us have hitch racks. 1up's are popular here. they can swing down and out of the way of the tailgate. You can also get a swingout so that you can swing the whole rack out of the way.
  2. Dec 5, 2022 at 1:28 PM
    Hudock08
    Hudock08 Active Member
    2021 Cement Tacoma TRD Sport
    Fox 2.5 Factory Race Series w/ Remote Reservoirs - F&R BF Goodrich 285/70/17 T/A KO2s on 4Runner TRD Pro Wheels - Alu-Cab Contour Canopy
    Never knew of 1Up until now. Thanks for that! I like that they have a single bike hitch rack. I don't need more than that. haha
    barelfly likes this.
  3. Dec 5, 2022 at 1:29 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @Nimble9 makes/made a product similar to what you’ve pictured. As a long time truck cap owner I’ve considered modding up a camper capatible option. I opt for a 1up hitch rack most often but will roll tailgate style for quick rides.
    @Gunshot-6A is it possible to link the blog @abacall wrote on bike carrying options in the first post of this thread?
  4. Dec 5, 2022 at 1:45 PM
    ginseng27
    '17 DCSB OR
    not enough.
    popular option is the 2 rack. I have the 2 rack super duty with extension leaves when the need arises. Anotehr option is the quikrstuff. the original 1up designers split off and started quikrstuff. is it that much better? not sure. i've only seen 2 in the wild and never handled one so i can't say.
    Hudock08[QUOTED] likes this.
  5. Dec 5, 2022 at 1:59 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Can you find the link for me? I could only find TiresOnTrails and it errored out when I clicked on it.
  6. Dec 5, 2022 at 2:18 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i dont have a cap yet, but am planning on getting one by/for summer.
    i think adding bed stiffeners and a fork mount to that is the way to go for security. keeps bike entirely in the bed and everything should lock. can even loop a chain through the frame into the bed stiffener. someone on here made a nifty wheel mount for the side rails. bed stiffeners are recommended for caps with tents on them anyway?
    if im just riding 10-15 min from my house ill probably through a tailgate pad on and leave the back window open. this shouldnt damage the struts on a shell would it?
    if my bed starts to get too crowded then i guess a 1up is the way to go.
    very rarely do i carry more than 1 bike anyway
  7. Dec 5, 2022 at 2:30 PM
    backcountryj
    Jonathan
    GA
    Yea I’ll try and track it down after I feed my minions.
  8. Dec 5, 2022 at 2:56 PM
    backcountryj
    Jonathan
    GA
    @Gunshot-6A found it, but it’s a dead link. My bad for the wild goose chase.
    Gunshot-6A[OP] likes this.
  9. Dec 5, 2022 at 3:47 PM
    ginseng27
    '17 DCSB OR
    not enough.
    I guess it's time to create one for this page as a single post!
  10. Dec 5, 2022 at 4:19 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    @abacall, I’m trying to join you in that 170 rear club. Got the Ultimate with a Super Alloy Racing spring.
    Couldn’t find a 205x65 to save my life, got a 205x62.5 and cut the little 2.5mm plastic spacer. The sag marking on the shaft don’t match up and it does say 62.5, but I can live with that.
  11. Dec 5, 2022 at 4:39 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Bikes under my cap, I stagger the mounts so they all fit. That’s a full size truck though, you might need a mid or high rise cap to make that work on a Tacoma.
    Before the cap, I had a Diamondback bed cover and I mounted a Rocky Mounts track to the top and used the same fork mounts.
  12. Dec 5, 2022 at 6:27 PM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Those of you with gravel bikes - anyone notice a different from a 650b wheel to a 700c? My redwood is riding on 650b's and I don't really have a complaint - can get some wider tires mounted up which work great on mild single track up to fire roads, but I notice a decent amount of drag on pavement runs. Coming across a good selection of budget friendly 700c wheels that I keep looking at.
    My typical gravel ride is consistent of 50% pavement, 50% dirt/gravel/single track. The hills to get over to the trails can be brutal on pavement and really not sure how much a larger wheel would offset the grind. Although I guess a harder rolling resistance is only strength training at the end of the day.
  13. Dec 5, 2022 at 7:40 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I do most of my riding on my 3T Exploro with 650x48s and race on 700x38-42. The 700s are faster but it's marginal.
    Tire choice is going to make the biggest difference. Both tread and width moreso than diameter.
    But increasing your overall diameter will also give you higher gearing which will make it tougher to get up the hills.
    Personally, if I were in your situation, I'd keep the 650s.
    What tires are you running? There are a lot of shit gravel tires out there. You can get away with them on gravel and trails but they reveal themselves on pavement.
    113tac and guitarjamman[QUOTED] like this.
  14. Dec 5, 2022 at 7:41 PM
    barelfly
    barelfly Well-Known Member
    2019 Cavalry Blue Tacoma TRDOR, 2014 Iceberg FJC
    @guitarjamman I run 2.2” on my Cutthroat, and at times, sure I wish I had some skinnier tires for some of the rides I do, but I actually prefer the wider tires for what I ride most of the time (dirt/gravel/single). I look at it as a benefit feeling more comfortable on the rough stuff with a bit wider tire than having a skinny to go a little faster when I’m on the pavement.
    One of these days I’ll buy another wheelset so I can run two types of tires, but who knows when I’ll actually do that.
    And I realize now that you are asking about 650 to 700, which I can’t answer, but can give a perspective on the wider tires I guess.
    guitarjamman likes this.
  15. Dec 6, 2022 at 5:31 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    I stopped hosting it a couple months ago. Paying over $350 per year out of pocket for something I got zero return on didn't make sense to me anymore. I put it out there to help others, but traffic started to dwindle and I got a house and a baby boy. So, it's gone.
    I'm not sure if I can still access the original WP files, I hope so. I put a shit-ton of time into that site, so it'd be good to save that somewhere I guess. I'll see what I can dig up over winter break and make a post somewhere. I think it makes more sense as a separate thread, so people can contribute to it.
    Yeah buddy! From my (seasonally) limited experience with the 170, you won't regret it one bit. I am curious to hear your comparison since you spent a good amount of time on the 152.
    That spring might work ok, but I'm not sure if the damping will match the spring rate correctly on the shorter spring. What I mean to say is that, as the spring comprises its rate changes, and those values might not match up to the valving on the damper. Think of it as this, as the coil compresses, your coils come in to contact with one another and ramp up that rate bit by bit.
    Another thing to consider is that the shorter spring might not allow for full travel as it compresses into its stroke. I'd definitely contact WA1 before getting on that setup, let them chime in.
    Once I dial in my spring rate on the 170 with cheaper optioned coils from RS, I'll dig in to researching compatible light springs. Again, WA1 might have a good option.
  16. Dec 6, 2022 at 5:50 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Reading about the springs, they tend to have the highest tolerance for a linear spring rate than any other one I could find info about. Something around 1.5% change at most through out the entire spring compression.
    Also, it's meant for a 65mm stroke shock. Look into them, apparently they're not uncommon on UCI DH and EWS bikes.
    https://www.superalloyracing.com/pr...ic-compatible-65mm-stroke-pom-spacer-included
    abacall[QUOTED] likes this.
  17. Dec 6, 2022 at 5:50 AM
    guitarjamman
    Zach
    Northeast
    2019 Ram 2500
    I am running a 650bx47 WTB Venture front and back which is pretty low profile for pavement - can average close to 12-13 mph with the majority being pavement and some fire roads mixed in. If I do anything, I may keep these and then go with a 700c and skinnier tires depending on the terrain for the day. Not a harm to have two sets of tires (other than my wife killing me adding more wheels to the stable).
  18. Dec 6, 2022 at 6:04 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    If you have a shortbed it may be tough to fit inside depending on the bike. I ride a 57.5cm salsa warbird and I have to set the bars turned all the way to one side and take the air out of the rear tire...even with that I shattered my window back in august. Maybe the added weight of the kayak made it worse? Not sure but even my large trek stache barely fits with air out of the back tire. I haven't even attempted my ibis ripley af because I think it's like an inch longer than the stache.
    As you can see, I also have a hitch rack. I was driving down from Maine to Virginia and usually prefer to keep my bikes under the cap for longer drives....probably won't be doing that again.
    chiefcrunchy likes this.
  19. Dec 6, 2022 at 6:10 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Think you'll have time to host two of us in late Spring? :)
    Also just booked a Costa Rica riding trip for late-January. Pretty pumped
  20. Dec 6, 2022 at 6:17 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    No harm in two wheelsets (or three, or four) horses for courses and all that.
    WTB makes a lot of 650 tires but, in my experience, they're all pretty mediocre. I'm currently using a set of Maxxis Ramblers in 650 that I find pretty mediocre too. They're ok with the correct pressure but a few PSI in either direction leaves them either feeling squirrley or they ride like a garden hose. I'll probably bin them after this winter season.
    I really like the Schwalbe G-One Speed or, my current favorite tire, the Pirelli Cinturato H. I have the Pirellis in 700x35, and 40, but may pick up a pair of 650x50. The Pirellis are the best gravel tire I've ever run on pavement. You barely even notice the tread on the road. I raced on them all summer and rode a ton of BC trail with them too.
    guitarjamman[QUOTED] likes this.
