All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Dec 6, 2022 at 6:17 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    No harm in two wheelsets (or three, or four) horses for courses and all that.
    WTB makes a lot of 650 tires but, in my experience, they're all pretty mediocre. I'm currently using a set of Maxxis Ramblers in 650 that I find pretty mediocre too. They're ok with the correct pressure but a few PSI in either direction leaves them either feeling squirrley or they ride like a garden hose. I'll probably bin them after this winter season.
    I really like the Schwalbe G-One Speed or, my current favorite tire, the Pirelli Cinturato H. I have the Pirellis in 700x35, and 40, but may pick up a pair of 650x50. The Pirellis are the best gravel tire I've ever run on pavement. You barely even notice the tread on the road. I raced on them all summer and rode a ton of BC trail with them too.
    guitarjamman[QUOTED] likes this.
  2. Dec 6, 2022 at 6:23 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Have you ridden the specialized pathfinder pro? My bike came with the ramblers in 42mm which were fine. I went to Rene Herse slick 44s (I forget the model) which were great until the turns got loose. the pathfinder pros have been pretty much best for everything, I'd be curious how they compare to the pirellis.
  3. Dec 6, 2022 at 7:00 AM
    kekkan
    kekkan Well-Known Member
    Kevin
    Southern New Hampshire
    2021 Cement TRD Sport DCLB
    I have a Leer 180 on my Tacoma mid rise cap, I build a draw slide in the back for the bike.
    20210920_164634.jpg which is their
  4. Dec 6, 2022 at 7:15 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    I personally haven't ridden the Pathfinder Pro. I'd fit them in the same class.
    A few friends have used them and one complaint is that they are almost like three different tires as you lean the bike over with sort of abrupt transitions between the different tread patterns. One of the reasons I like the Pirellis....the tread, though it gets deeper on the side of the tire, is a fairly predictable transition. The Pathfinder Pros are always fairly high rated by most so maybe my impressions are misguided.
    I wish I could afford to ride every tire out there.
    guitarjamman and 113tac[QUOTED] like this.
  5. Dec 6, 2022 at 7:23 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    this post makes me uneasy about putting bikes under a cap
    this post makes me feel a little better about putting bikes under a cap
  6. Dec 6, 2022 at 7:24 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    For those with a short bed 3rd gen, and a shell/cap on the bed, can you fit a bike back there with taking the front wheel off?
    Just sold my bike, but didn't even think to try to fit it in my bed under the Alu Cab. I usually transport with a 1up rack, but now with the cap I'd feel better about locking it up when I go to work, trips, etc.
  7. Dec 6, 2022 at 7:27 AM
    113tac
    Stephen
    Northern Virginia
    It is very possible that I haven't leaned them over far enough to notice the transition. Most of my riding is gravel roads, I rarely go onto singletrack so it's possible I haven't gotten a chance to feel the transition. I can see how the design would lend to that feeling though since it has a slick center and a hard line to the actual knobs.
    I also read some people saying the DHF has an abrupt transition, which I have never noticed on 2.5 or 3.0 tires so it is probably just me haha
  8. Dec 6, 2022 at 7:36 AM
    113tac
    Stephen
    Northern Virginia
    I had transported my bikes that way numerous times before, the window was probably under too much tension, I think the metal clamp on my gravel bike lever is what did the damage but it was hard to tell, it easily could have been the mountain bike brake lever.
    I think it all depends on the cap and bike. Like my stache has a shorter wheel base but longer stem and steeper headtube. I believe I am running a 40MM stem on my ripley af which also has a slacker headtube, so maybe it will fit. If it wasn't raining right now I would go test it out haha.
    See my response above, The alucab design looks like the rear window is more vertical so there is at least more room to fit bars. With a short bed we are working with very small spaces haha. I can't imagine how people are getting away with these new trucks with 4 foot beds.
  9. Dec 6, 2022 at 7:42 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Some are definitely more in tune with what's happening than others. :p
    If you're 100% gravel you'd likely worry about the transitions less. It's also very gravel dependent. Not everyone's road surfaces are the same. You're more likely to notice the transition (negatively) on pavement or hardpack than soft gravel or single track.
    I'm far less picky about tires on my mountain bike than I am on road or gravel. I have Minions as well...they're more tire than I need for my local trails but they came on the bike and IDGAF enough to change them before they wear out.
    113tac[QUOTED] likes this.
  10. Dec 6, 2022 at 7:50 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm one of those people. I've tried Minions since everyone seems to love them, but that dead spot kills them for me. I think it depends on your riding style -- apparently I spend a lot of time leaning just enough to be in the area with no traction. That traction-no traction-traction thing is nuts.
  11. Dec 6, 2022 at 7:52 AM
    113tac
    Stephen
    Northern Virginia
    it is definitely interesting because I 100% notice the lack of side knobs but not in between really haha. I'll have to see if I can notice it on my next ride haha.
    DingleTower[QUOTED] likes this.
  12. Dec 6, 2022 at 7:52 AM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    It shouldn’t, that one seems to be a longbed. But seriously, when we had an ARE Z Series, which has a very stylish sloped rear window and a very bulky hinge, on our short bed, our mountain bikes barely fit and they are old-school (vintage 2015) with steep HTA and pretty short wheelbase by modern standards. IIRC the road bikes with dropped bars had to go in forks to the front, and I suspect bigger MTB’s would have to do the same. I tried that setup for a while but got tired of of crawling up front to secure the fork mount. Now I either just throw them over the tailgate … or take the van.
  13. Dec 6, 2022 at 7:53 AM
    Hudock08
    Hudock08 Active Member
    2021 Cement Tacoma TRD Sport
    Fox 2.5 Factory Race Series w/ Remote Reservoirs - F&R BF Goodrich 285/70/17 T/A KO2s on 4Runner TRD Pro Wheels - Alu-Cab Contour Canopy
    I'm getting the same contour canopy as you, and I don't think it would be possible, well with a gravel bike, no. My hoods measure at about 43" from the ground.
    What is the interior height for the contour? about 39-40"? it might be possible with a flat bar mountain bike though! my seat is at about 38". I'mabout 5'10" tall.
  14. Dec 6, 2022 at 8:01 AM
    aturk
    Tony
    Charlotte, NC
    Ya that sounds right for the height.
    I'll have a spare tire back there, and a tote of stuff usually, so not much room to lay it on it's side. Although I guess I could pull the rear wheel for the longer trips if needed. For instance, Charlotte to Bentonville is about a 14 hour drive. Would prefer not to have my bike on a rack that entire time, but if I need to I guess it is what it is.
  15. Dec 6, 2022 at 8:26 AM
    Hudock08
    I like this setup!
  16. Dec 6, 2022 at 8:41 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I tried looking in the google cache, nothing. if you still have the account, i'm sure you can still access it. if not, I'm sure we could swarm a google doc as a draft before posting on here.
    abacall[QUOTED] likes this.
  17. Dec 6, 2022 at 10:22 AM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    For some reason I have decided to bike the Erie Canal Bike Trail from Buffalo to Albany or about 360m. For me I live close to Albany and can ride to the rail station, train it to buffalo and ride back (sounds so easy doesn't it?).... I've already bought the ticket for JUN23, my bike (Canyon Traillite 7) should fit the bill and I've already installed panniers.
    I'm just a regular rider probably 30 mile rides about 3 X a week sometimes more sometimes less. I do plan on knocking out some miles for conditionings sake prior to going and I have done a fair amount of primitive hiking/camping before so I plan on using alot of that gear....
    -How many miles should I knock out in a day?
    -My plan is to camp, camp, hotel kind of thing
    -thoughts on stealth camping? Only to fill the void where there isn't anything.
    any other thoughts/comments/wisdoms etc, etc are definitely welcome...
    Malvolio likes this.
  18. Dec 6, 2022 at 11:08 AM
    LoMeeein
    LoMeeein Well-Known Member
    Alex
    Connecticut, US
    Lunar Rock 2022 TRDOR DCSB
    I saw their sale and almost bit the bullet and then I saw one on marketplace for $900 locally, previously owned by the guy's 13yo daughter so I scooped it up immediately! Loving it. I'm 5'7-8 and it's a size small but I was going for something small and throwable and I have no complaints. Good eye too! Yep it's a '93 Mark II Tourer V. Freshly broken and stored til Spring when I have the motivation to put a new crank pulley on it haha.
    It's been here forever! Rockwell park in Bristol, CT. Awesome skate plaza, I'm an avid skateboarder too and been skating there for over a decade but it's been double fun having a bike for it. They've got a dirt pump track there too but honestly it's very poorly made and the rollers are too close together it's used more as an RC car track. They've also got some trails there with a few wooden drop features. The trails are also eh. If you're into all that, would totally be down to show you around it!
  19. Dec 6, 2022 at 12:00 PM
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    Ah it is Rockwell! Haven’t been there in a while and have only been 2 or 3 times. The area in that vid didn’t look familiar, then I watched it again and now it’s very obvious haha.
    I heard something about a pump track being added there but never saw it. I definitely need to check it out again next time I’m in CT.
    LoMeeein[QUOTED] likes this.
  20. Dec 6, 2022 at 12:05 PM
    LoMeeein
    Alex
    Connecticut, US
    I keep going back there hoping the pump track is better but it isn't. I just have to bite the bullet and drive the distance to Madison if I want to ride any dirt pump track. Shame Powder Ridge isn't open beyond bike park season, their new asphalt pump track is incredible
    LeFreakyBone[QUOTED] likes this.
