All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 15, 2023 at 2:18 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Here's one that has seen a fair amount of blappage. I've never had an issue with this beyond aesthetics. But yea definitely in bike park type berms I'll roll a tire @ 30psi.
    levie125 likes this.
  2. May 15, 2023 at 2:38 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    mine look like bigger X's on my dhr/dhf. like if the lines kind of diagonal from top right to bottom left were the same spacing and perpendicular too.
    never been an issue though.
    maybe its a different casing and tire though
  3. May 15, 2023 at 5:24 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Introducing, the Meta!
    (yes, I already fixed the seat angle, looked fine in the stand, not fine on level ground)
  4. May 15, 2023 at 5:35 PM
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
  5. May 15, 2023 at 8:01 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I’m coming to you guys broken. I was messing around with my trigger shifter and shot this thing across the garage. In my efforts to clean, sweep, and check the piles of dirt I’m coming up empty handed. Does anyone have an old trigger shifter and can send me this little metal clip I’ve screenshot. Apparently you can’t buy it separately.
    Also, from what I’ve saw this clip is in every shifter. SX to XX1. So I’ll take the clip from any broken or cheap shifter.
    https://youtu.be/OexaMmJkoMs
    chiefcrunchy and levie125 like this.
  6. May 16, 2023 at 7:30 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    That's great news about the knee man. Always good to have peace of mind. Good luck at the MRI.
    Tire rolling. Although higher pressure does reduce it, the tradeoff isn't always worth it. A trail I ride has a techy loose as shit top section, and a fast and bermy lower. I'll take the grip on the loose over support on the berms anyday.
    If you're rolling the tire, you're showing cords. I consider it a sign of a shreddy day.
  7. May 16, 2023 at 8:08 AM
    chetterthecat
    OR
    13 sport
    And hangover.
  8. May 16, 2023 at 1:36 PM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    New Bike Day! 29 NS Eccentric Alu
    RickE24, chiefcrunchy, PhoS and 8 others like this.
  9. May 16, 2023 at 2:24 PM
    Dirtjunkie
    Dirtjunkie Well-Known Member
    Northern Colorado.
    2006-Taco-Sport-TRD-Quad Cab-Short Bed, 4x4 No mods to speak of.
    These are kind of cool. The G-String of tailgate mats.
  10. May 16, 2023 at 3:19 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    That’s just a bikini. A Bomber pad is the G-String
  11. May 16, 2023 at 4:13 PM
    Dirtjunkie
    Northern Colorado.
    That would depend on the size of the contents. That’s a full size truck, a Brazilian tuck.
    vivid02, honda50r, photogr4x4 and 3 others like this.
  12. May 16, 2023 at 5:39 PM
    Pugga
    Massachusetts
    Nice! Got the rest of the parts on order?
    Any tips on bleeding TRP brakes? I bled them 3 times, following the TRP video instructions and I still barely have any braking power.
  13. May 17, 2023 at 4:23 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Do you have a firm lever?
  14. May 17, 2023 at 6:28 AM
    Pugga
    Massachusetts
    A little spongy, but it doesn't just compress to the handlebar, it does firm up but I have to use a lot of pressure to get the brakes to do anything. I ended up ordering some pads, thinking maybe the pads got contaminated along the way? I rubbed them down with isopropyl after the bleed but maybe something else is going on. Fronts were fine, they were a closed system when I got them so I just wiped them down and they're working fine. The rears were an open system when I got them so I assumed bleed from scratch. I used the cup at the top, syringe at the bottom. Pushed fluid from the caliper to the cup, use the lever to push fluid back to the syringe, push fluid back from the syringe to the cup, plug the cup, put the bleed screw back in, pump the lever a few times and hold under pressure, tap the caliper with the handle of a screwdriver to get the fine bubbles out, pull the cup, replace the lever screw and good to go. It seems like some fluid is escaping when I pull the syringe, even with the cup sealed, which I'm assuming is letting air in and leading to the spongy lever.
    Thinking this through, I suppose I could try to cap the lever while it's still the high point, then flip the bike in the stand so the caliper is high and pull the syringe. Maybe that would prevent fluid from escaping?
  15. May 17, 2023 at 6:50 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    I dont know if it matters but I usually do a 2 stage push pull sequence like these vids. Bleeding brakes can be a pain, for me its 50/50 if it works first try or takes 2-4 attempts.
    https://www.youtube.com/watch?v=RKZ6FIH6yzc
    https://www.youtube.com/watch?v=nqdp7a7FXe8
    werp, Pugga[QUOTED] and backcountryj like this.
  16. May 17, 2023 at 6:55 AM
    StZu
    Richard
    Dallas Texas
    https://youtu.be/RKZ6FIH6yzc
    This is how I learned to do brakes.
    Some parts are on order and I have a buddy who is giving me some wheels, fork, crankset, and whatever else he can find.
    chiefcrunchy, Pugga and Wulf like this.
  17. May 17, 2023 at 7:34 AM
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    thats what I run - its nice to not hassle with a full tailgate diaper when its just my bike being moved.
    RtacomaN and Dirtjunkie[QUOTED] like this.
  18. May 17, 2023 at 3:43 PM
    TacoDozer22
    TacoDozer22 Well-Known Member
    Greg
    Colorado
    2018 DCSB OR
    I find the TRPs a huge pain to bleed because of the use of a set screw on the caliper bleed port and it’s location.
    The best method that works for me is to use the push/pull method shown above to get all the old fluid out. Then I remove the caliper from the mount and gravity bleed (I.e. open funnel at lever and open set screw at caliper) while rotating/tapping the caliper to get air out of the caliper. It’s wildly messy and you have to be really careful with cleanup but I can get them perfect first go.
    Pugga[QUOTED] likes this.
  19. May 17, 2023 at 3:55 PM
    cartter469
    cartter469 Professional Idiot
    Cartter
    TBD
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    Yall got any tips for jumping in the wind? Been riding at a smaller little park with some loop trails and doing the jumpline. But damn reno is windy. 35 mph other day. 30 today. Blowing across the line on monday and straight into my face today. So the jumps where its more than a little 5 foot table and has a proper lip on them, I feel myself getting moved around or not having enough speed when its right at me.
    At least im riding :D
    And decided the trail I saw up a mountain had to be investigated
  20. May 17, 2023 at 3:59 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Ya. Don't. Jumping in the wind is terrifying. They stop big events because of it. If the pros wont/don't do it. Neither will I
