All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jun 22, 2018 at 11:36 AM
    #4601
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I ride a large frame, but a build up is tempting. Especially when I can call in a favor or two with Hubsessed up in Ogden.
  2. Jun 22, 2018 at 11:57 AM
    #4602
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Quick JMP (Oakland) this morning.
    wahoobie, arnette64, Sm32589g and 2 others like this.
  3. Jun 22, 2018 at 11:58 AM
    #4603
    kolache king
    kolache king Well-Known Member
    Traveling via Louisiana
    2016 Barcelona Red DCSB SR5 4x4
    What’s the general consensus here about taking a 120mm stock fork and upgrading to a 130mm-140mm fork?
    Obvious slack it out a bit more. If I went with 140 I believe my head angle would end up being equal to my genius’ head angle. May elevate the BB a bit which isn’t that bad for this bike.
    Stress the frame too much?
  4. Jun 22, 2018 at 12:21 PM
    #4604
    SWCOLO
    SWCOLO Well-Known Member
    2016 DCSB TRD OR 4x4
    @Thechist Here is my setup. I have a DCSB with a topper. I can fit my Large 6Fattie and my wife’s Med 6Fattie side by side. I can also fit my large Fatboy and my large Ti SS in there. 5152114A-8D85-40A3-A0D9-360C8893816D.jpg 7414857E-636D-43B3-A72A-D1BB12AED302.jpg 508969D0-E263-4B32-BE90-BE14D6E007CA.jpg
    arnette64, Sm32589g, Jayts76 and 5 others like this.
  5. Jun 22, 2018 at 12:22 PM
    #4605
    Diesel11B
    Diesel11B Active Member
    Dustin
    2018 Inferno Taco TRD Sport 4X4
    K&N CAI Thrush 2 Chamber
    Hi guys. Just got my rocky mounts and header rail installed and ready for some mileage. Anyone in here near the central Florida area? I'm hitting clermont at 8am tomorrow if anyone cares to join
    Sm32589g, JJ TACO and ccallen like this.
  6. Jun 22, 2018 at 12:26 PM
    #4606
    ccallen
    ccallen Well-Known Member
    Chase
    Missoula Mt.
    2016 tacoma TRD Off Road BBP
    SCS SR8's 17" TRD Adventure Edition
    Great looking set up.
    SWCOLO[QUOTED] likes this.
  7. Jun 22, 2018 at 12:34 PM
    #4607
    Gunshot-6A
    Conner
    Everett, WA
    Should be fine, but on slow uphills it may seriously get lazy in the steering department. I put a 160mm MRP Stage on my Bronson (+10mm) and it definitely wanders a little more than a floor model.
  8. Jun 22, 2018 at 9:46 PM
    #4608
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I grew up fairly near there ... in the ‘60’s pre-mountain bikes. Is there enough trail mileage to be worth coming up from Santa Cruz? Traffic on 17/880/580 sucks pretty much 24/7.
  9. Jun 22, 2018 at 9:52 PM
    #4609
    dman100
    2016 TRD OR DCSB
    What am I doing wrong? I can’t fit two bikes in that config under my ARE Z Series with 5’ bed. I can do one bike facing forward, one facing back (very tight bar-to-bar fit, plus bars to window/hinges/struts); or both facing forward (plenty of clearance, but then I have to crawl in to secure the front axle mounts. In either case I have to tip my size L 29-er to get the saddle under the rear opening, even with my dropper jammed down. What kind of shell do you have?
  10. Jun 22, 2018 at 9:57 PM
    #4610
    flipnidaho
    If you're already in Santa Cruz, don't bother (you already have better riding). I only do JMP during the week but hit Demo or UCSC on the weekends. The JMP trails are like a mini-Demo in that you climb up a little Ridge only to do some fun chunky stuff down. It gets pretty busy during the weekends and afternoons so it's hard to get any type of flow during those times.
  11. Jun 23, 2018 at 6:41 AM
    #4611
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Any of you run the KUAT transfer hitch rack? I have a topper and usually transport bike on there but taking the wheel on and off for short trips is annoying. Haha
  12. Jun 23, 2018 at 8:31 AM
    #4612
    kdtpnw
    kdtpnw Active Member
    2011 6spd TRD Off Road Access Cab
    It changes the overall geometry, but that’s not necessarily a bad thing. Like you said it will slack the head tube, raise the B.B., and it’ll also change the seat tube angle. I’d be most worrie
    d about raising the B.B. too much, that can make a bike feel top heavy/weird and unstable, but 10-20mm isn’t a ton. If you wanted to put a 200mm dh fork on that’s a different story.
    People definitely do it all the time, and some companies have even done it themselves/encouraged it. When I worked at a shop specialized made a version of the stumpy with a longer fork, I currently have a 1st gen Transition Smuggler which came with a 130 fork, but transition advertises that you can also use a 140. I don’t see how it would stress the frame significantly more, other than if having a longer fork encouraged you to hit bigger stuff. It will be noticeably slower to turn tight corners, and better at bulldozing stuff in a straight line. IMO is stick with only a 10mm increase from stock, but give it a shot.
    abacall and Gunshot-6A[OP] like this.
  13. Jun 23, 2018 at 8:39 AM
    #4613
    outdoorguy87
    outdoorguy87 Well-Known Member
    Justin
    2016 Taco TRD OR DCLB
    AFe cold air intake system, levelling kit, OEM massive LED projector heads, CBI offload bed rack with THULE box, Winjet LED rears
    I habe the CBI overland rack on my 16. How do the bars work with the rack? Do you then put a bike rack on them?
    ToyoDrew and DubfromGA like this.
  14. Jun 23, 2018 at 12:33 PM
    #4614
    kolache king
    Thanks for info guys. Yea, If I go up I’ll just go up 10mm. I’m on a job in the field working shift work, so no riding but plenty of time to shop for parts...
  15. Jun 23, 2018 at 2:51 PM
    #4615
    SWCOLO
    @dman100 Not sure. I made the base and then dry fit the bikes in there to mark the location for the wheel mounts. I mount my bikes rear wheel in first. Then all I have to do is thread the fork mount. I did not want to have to climb in to thread the fork mount. You can see the mount on the right (empty) is setback about 4 inches from the mount my bike is in. When the bikes are mounted the rear wheels are slanted toward the driver side. When both are in they clear the gas struts for the rear and Windoors. The 4 inch setback allows the bar ends and controls on each bike to clear each other. My topper is an ARE Z series too. Standard height. I do have to slightly tip my bike to the side for the seat to clear the rear opening, but once it gets past the opening, I have plenty of room. I just leave my dropper all the way down. Seems the major difference on how we mount them is my fork mount is located on the tailgate side.
  16. Jun 23, 2018 at 3:03 PM
    #4616
    TimmyC
    TimmyC Well-Known Member
    Tim
    Central MA
    2017 TRD OR DC Long Bed
    Billstein 5100's, OME 888 Coils, Dakar Medium Duty Leaf Pack, SC Ray Rims, BFG K02 - 285's, Leer XR100 cap, Topper EZ Lift System
  17. Jun 23, 2018 at 3:08 PM
    #4617
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Looks like a cool place to ride
  18. Jun 23, 2018 at 5:03 PM
    #4618
    dman100
    2016 TRD OR DCSB
    I guess I wasn’t clear ... I started with trying to mount our bikes with forks on the tailgate end and couldn’t get ‘em to both fit. I’ll try again ... maybe our bikes’ length or height (both FS 29-ers but not long travel) and/or bar and stem dimensions are just a bit bigger than your 6Fatties. Thanks for the comments.
  19. Jun 23, 2018 at 5:08 PM
    #4619
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    JuanitoBonito likes this.
  20. Jun 23, 2018 at 5:22 PM
    #4620
    maverick42
    maverick42 Well-Known Member
    2018 red TRD Off Road
    Highland is pretty sick, havent been up in a few years so I was thinking about making a trip up in the next few weeks, maybe after i get back from KT.
    micwillia likes this.
