All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Oct 14, 2023 at 11:24 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    The Dissector is a fast rolling/cornering tire but not really the best technical climber. I'd recommend swapping it for DHR2 or a Highroller II if you want more grip out back.
  2. Oct 14, 2023 at 12:39 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Yeah, but shouldn’t it be better than an Ikon? The knobs are a lot bigger. That’s why I was wondering about the compound. I’ll give the Dissector until it wears out ‘cause I’m cheap and lazy but I’d be open to a DHR2 which is what Ibis fit on the front in a 3C MaxTerra compound.
  3. Oct 14, 2023 at 1:40 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    the non 3C is a dual compound, these are relatively hard and not that sticky. The knobs will probably start coming off before you wear it out. Here's a guy slanging cheap Maxxis OEms on ebay. $33 bux for a DHR2 , the guy is legit I have bought a bunch of stuff off him. https://www.ebay.com/itm/364275782190
  4. Oct 14, 2023 at 2:37 PM
    dman100
    2016 TRD OR DCSB
    Well, it’s $45 with shipping but still cheap. An interesting experiment to see if the compound makes that much difference. I don’t know why Ibis cheaped out on the rear tire since the front is 3C. Though I can’t complain, they gave me a carbon bar for free. Thanks.
  5. Oct 14, 2023 at 5:27 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    tried truing a wheel today.. definitely not great but way better than it was before i tried lol. How often do people do this and do you DIY or bring it to a shop. seems my rear wheel needs it every 2 or so months.
  6. Oct 14, 2023 at 5:32 PM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    How much time ya got?
  7. Oct 14, 2023 at 5:49 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    It could be the compound. I rock a 2.4 rekon maxxterra on the rear of my Ripley af and have minimal issues with climbing traction. Some situations it can get squirrely such as super dry or wet conditions but for the most part it’s solid. I also run like 23 psi on a hookless 30mm inner width rim and I’m like 240 loaded up.
    dman100[QUOTED] likes this.
  8. Oct 14, 2023 at 6:52 PM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Quite a bit when I’m not riding or working. Took today off from riding to button up some maintenance stuff I’ve been putting off so I’m good for tomorrow morning. Messing with the wheel took me maybe a half hour to make it “okay”.
    Or did I miss the point of your question?
  9. Oct 15, 2023 at 5:19 AM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    The original wheel builder probably did not put linseed oil (or spoke prep) during building and tensioning the wheel. This prevents the spokes from backing out as you ride. I would rebuild the wheel using linseed oil on the spokes and get a spoke tension meter to get the wheel to the right tension. Ride it a few times and retighten if needed. Wheel building can be therapeutic with the right beverage.
    abacall likes this.
  10. Oct 15, 2023 at 7:20 AM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    I talked to a coworkers son who is a bike mechanic, he said the same thing about not using spoke powder or something along those lines causing the spokes to loosen. Since the LBS who built the wheel is closed on sundays, ill give them a call tomorrow to ask if they use anything linseed or spoke powder when assembling. Wheel truing can be therapeutic like you said, it's a nice time to just sit down and focus on something and not worry about busting knuckles :rofl:
    abacall likes this.
  11. Oct 15, 2023 at 7:28 AM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Personal experience with learning how to true a wheel (only built two from scratch) is that it's not something that you can just follow steps to get right. Right enough, sure. But actually get your wheel built/trued up well takes time and lots of practice. Usually more that doing it a few times a year. I had 4 bikes, all that I practiced on regularly and I still didn't get it as good as a shop did in a few minutes and $25. Of course YMMV.
    As mentioned above, a good tension meter, stand, nipple wrench, spoke prep, time and patience are a must. You can get by without a stand, using the frame and some zip ties, but it's not ideal.
    One bit of advice I can offer is that tension is the most important thing, getting wobbles and hops out are the outcome of good tension. If the tension is off your wheel will get out of true faster and be significantly more prone to failure. It's highly unlikely you'll notice a small hop/wobble when you're riding, as most tires have some when installed anyway.
    It's definitely a zen-like practice, but it can also be infuriating at times. :rofl:
  12. Oct 15, 2023 at 7:44 AM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    yeah, i was thinking a shop could get this done way faster for the $20-25 OTD and it still be better than what i did since my tools are limited to zip ties and a spoke wrench :rofl:
    Im just about to head out the door for a ride, ill let you know how it goes.
    abacall[QUOTED] likes this.
  13. Oct 15, 2023 at 12:02 PM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Had a nice ride this morning. Wanted more but the legs said no. Wheel felt good and stiff leading to getting some more speed out of corners which was cool. Pics or it didn’t happen right?
    Dirtjunkie, jubei, RickE24 and 9 others like this.
  14. Oct 15, 2023 at 12:29 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This came in the mail!
    I’ll be healed up for fat bike season and I plan to make up for lost time!
    gumbine, Dirtjunkie, RickE24 and 12 others like this.
  15. Oct 16, 2023 at 6:25 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    jubei, Rezkid, tacokid09 and 9 others like this.
  16. Oct 16, 2023 at 7:18 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Well done on that trail! Not sure I would have the balls to carry the speed you did on those exposure sections.
    neatoneto[QUOTED] likes this.
  17. Oct 16, 2023 at 7:55 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    desert riding always good. Burro was closed so we only did Hazard county down but it's still a blast to rip.
    @abacall and I were talking, next year, we need to organize a TW trip to do....TWE! (The Whole Enchilada)
    Dirtjunkie, RickE24, Rezkid and 7 others like this.
  18. Oct 16, 2023 at 8:17 AM
    neatoneto
    CT/Mass
    Good stuff, I've learned you need to book TWE at least twice if you're making the trip to Moab. Just in case weather is crap that day. I'm all in for going back!
    levie125 and ginseng27[QUOTED] like this.
  19. Oct 16, 2023 at 8:23 AM
    ginseng27
    '17 DCSB OR
    not enough.
    really depends on time of year. August is when you're likely to see any type of storm in the area. it can bleed into Sept but Sept is usually your best bet. October is always a gamble but if you get lucky with a full run in Oct, you get some amazing weather and temperatures to ride in (i was able to do it super late october before)
  20. Oct 16, 2023 at 8:48 AM
    evenslower
    evenslower Well-Known Member
    Agree, I’ve done 3 trips in the La Sals and down TWE during the week after Labor Day in 3 different years. Seems to be a good window.
    neatoneto and ginseng27[QUOTED] like this.
