All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Apr 26, 2024 at 1:54 PM
    TacoDozer22
    TacoDozer22 Well-Known Member
    Greg
    Colorado
    2018 DCSB OR
    Sag is also only a recommendation (albeit a more refined one) as you are measuring the position of the air spring at a static position. How you ride and where you ride should be a factor.
    At first I rode off the back and even at static sag my fork felt too stiff. When I started to weight the front more, it was too soft.
    100% start with sag but don’t be afraid to +/- pressure based on feel.
    levie125 likes this.
  2. Apr 26, 2024 at 2:31 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Somewhat agree, but less than 15% or more than 20% and you probably need to adjust elsewhere. Tokens, compression, rebound.
  3. Apr 26, 2024 at 3:51 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Sag is a starting point, but I wouldn’t venture past 5% recommendations.
    As someone else said, too mug sag and you’re not taking advantage of the small bump compliance dampening and hitting a spike of resistance too soon.
    Too little sag and your spring is doing everything and you’d have to run rebound slower since it’s becoming a pogo stick.
    Start with a lower service.
    Take all tokens out, and pump to the recommended air pressure, check sag is good. Then follow recommended dampener settings, and go ride.
    If you’re not bottoming or getting close to bottoming great, if you’re bottoming add 1 token, add the same air, and repeat.
    The more tokens you add the less linear your fork feels and it becomes more spikey. Personally I’d prefer to run no tokens, but then I’d clap my fork.
    Before you start worrying about changing dampener settings make sure that you have the spring side sorted first.
    113tac and jubei like this.
  4. Apr 26, 2024 at 4:46 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Here you guys go, idk what the V2’s went on sale for prier to being “outdated” seems decent.
    abacall, 113tac and PhoS like this.
  5. Apr 26, 2024 at 6:32 PM
    cartter469
    cartter469 Professional Idiot
    Cartter
    TBD
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
  6. Apr 27, 2024 at 12:36 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Lube party. And a ride in the canyon. Not a bad Saturday.
  7. Apr 27, 2024 at 1:52 PM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    +1
    Sounds like rebound is too slow and pressure too low.
    Think of this: :bikewhoops: but instead of following the contour it’s smashing into the top of the rollers because it’s not extending down fast enough. Look at the wheels. You want the wheel to do what the back wheel is doing, not the front.
    Not a fan of Zebs, but it shouldn’t feel like that.
    You can also try a “traction tune”.
    Set recommended sag, compression wide open, rebound full fast. Idea is you’re using rebound to control motion, not compression damping.
    RockiesTaco likes this.
  8. Apr 27, 2024 at 5:56 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wife left me alone today so I had to play ‘destroy the evidence’. She knew I was updating a bike and never asked anything beyond that :anonymous:
    The bike that got the upgrades was my Poseidon Redwood. It’s now in its final form, and the only thing Poseidon left is really the frame at this point. I went full Apex mechanical, replacing the Microshift group set. I had no issue with Microshift but the brakes were not confidence inspiring and they were cheap, heavy components. Still need to trim that shifter cable and rebleed the rear brakes, but she rides like a dream! I put just shy of 50 miles on it today.
  9. Apr 28, 2024 at 8:24 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    I've had Code RSC's on my last bike with 200/180 rotors and stock pads. I fluctuate between 210-230lbs mostly, and I always thought the Code RSC's were solid but nothing mind blowing. I was used to them and could service them nicely at home so that's what I stuck with on my new bike.
    New bike has Code RSC's, 200/180 HS2 rotors (I doubt the HS2 rotors do much but I didn't want to leave anything on the table), and MTX red pads.
    I've done about 10 rides on my new Yeti SB120LR (coming off 3 Achilles reconstructions so way out of shape). Brakes have felt fine but I haven't done a big downhill or been in shape enough to really push them.
    Anyways, yesterday I hit some local good downhills and these pads kick ass. Plenty of power and surprised me numerous times. Finally getting some confidence back after 2 years off the bike, as well as getting used to the new bike.
    If you have Code's and need a little more power, check out the MTX red pads.
    levie125, abacall, 113tac and 5 others like this.
  10. Apr 28, 2024 at 8:49 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    The hs2's are great for quicker initial bite and longer descents. I've got them on my bikes and haven't looked back. I've heard thr mavens are even better but I'm still sticking with my code r's for now. Maybe ill switch to rsc/ultimates later. Haha!
  11. Apr 28, 2024 at 10:05 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Does anyone use a small portable washer for their bikes after a muddy and/or cow/horse poop ride?? Im talking like a gallon or two hand pump or electric sprayer that has some decent pressure behind it. im not trying to get the bike spotless, id just like to get the bigger messes off before it dries on the way home.
    example 1
  12. Apr 28, 2024 at 10:13 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’d probably go with disposable gloves, sanitizing antibacterial wipes, and paper towels and a trash bag. Glove up. Paper towel it off, then run the wipes down. Then dry with paper towels. Toss it all in the bag and dump it there in a trail waste bin or tie it up and trash the main mess at home.
    Edit: the rationale for this^ is I am leery of making poop into poop mistTM that will move as aerosol into all sorts of nooks and crannies and MY FACE.
    levie125 and tacokid09[QUOTED] like this.
  13. Apr 28, 2024 at 10:48 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I’m about the same size, usually closer to 220s-230s and run gold and red on my RSCs after recommendations from this group. Im also running an HS2s in I believe the same sizes. It’s for sure a good combo.
  14. Apr 28, 2024 at 10:55 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Yea , get the 2 gallon though.
    tacokid09[QUOTED] likes this.
  15. Apr 28, 2024 at 11:34 AM
    Pugga
    Massachusetts
    I have a 1.5 gallon hand sprayer, like what you’d use for a garden. It’s cheap and works perfectly for what you described, just to knock the heavy stuff off before headed home.
  16. Apr 28, 2024 at 12:15 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I’ve had people tell me after getting the ebike I won’t go back. I’ve got to say, the ebike is fun, but it’s completely different. First ride back on the arrival in probably 3 weeks and I’m having a blast.
    The ebike I feel has made me faster on the regular. Both in climbing and descending. The bike now feels even more nimble than before.
    As a tool for progression I’ve got to say I’m a big fan of the ebike.
    113tac, abacall and tacokid09 like this.
  17. Apr 28, 2024 at 12:46 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Noob checking in!
    I’m doing my first frame up build, and I want to see what you guys think. I’m getting ready to press in headset cups on a new steel frame and I have a proper headset press to do this, but how much should I worry about the state of the faces and bores in the headtube?
    I’d like to just send it and get this together, but if it’s worth checking them and possibly getting reaming and facing done at my LBS, I can do that. I just don’t know how much I should care :p
    Thanks!
  18. Apr 28, 2024 at 1:27 PM
    Pugga
    Massachusetts
    I just went for it and pressed them in. Only did it once, worked out. I freaked out because they started walking a bit but they straightened out just fine.
    jubei[QUOTED] likes this.
  19. Apr 28, 2024 at 1:44 PM
    jubei
    NoCo
    Stuff. Also things.
    Thanks!
    I’m actively trying to manage my analysis OCD with this stuff and just get it done and get riding :D
  20. Apr 28, 2024 at 3:15 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    I have a water port day tank 4ish gallons but never use it for bikes, mostly used camping. That's a good idea though
