All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jul 29, 2024 at 12:11 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i'll try turning the bars 90 and check for play too. i was trying to move it left and right to check if it was the hub, but didn't really show any difference. turning 90 sounds like it would be a better approach
    levie125 likes this.
  2. Jul 29, 2024 at 1:46 PM
    gdb85
    gdb85 Well-Known Member
    Pgh, Pa
    2016 SR5 DCLB 4x4
    SID's had a bushing issue a couple years ago...not sure of the age of your fork, maybe old stock when ya put bike together...? Might want to look into it regardless.
    Gunshot-6A[OP] and abacall like this.
  3. Jul 29, 2024 at 1:57 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Hold the crown and grab the arch on the lower and pull back and forth. You will know pretty quickly if it is a bushing problem. I did the same multiple headset adjustments on a previous bike and couldn't find the issue. I asked a friend on the trail, he did the above and I was like, oh, duh.
    H3llRid3r and levie125 like this.
  4. Jul 29, 2024 at 2:28 PM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Check the headset to make sure you have all the right parts. Some headsets have extra plastic thin spacers beneath the top bearing cover and a split compression ring. If you're positive it's not the headset (make sure that the spacers are higher than the top of the steerer by 5mm), check the stem bolts to make sure that all are tight. Check to make sure that the wheel axle is tight. To check if it's the CSU, turn bike upside down, take front wheel off and push the fork legs back and forth to see if you can make the CSU make a cracking sound. If the fork is older, it maybe the bushing. You can check this in a similar way as checking for a loose headset (brakes on, rock bike back and forth but instead of holding the headset, put your hand between the stanchion and lower to see if you can feel slop in the bushings).
    abacall and levie125 like this.
  5. Jul 30, 2024 at 5:58 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Yeah buddy! Second riding pic looks like an older Reign? Welcome back, you'll be shredding in no time.
    @flipnidaho said it all. My moneys on the headset or the SID.
    I've been off for the last 3 weeks(ish) and so glad to be riding again. Taking care of a 2 year old, aging parents, new house with things that need fixin', has definitely cut into my riding this year. I'm about half of the miles I'm usually riding, but every damn day is a good one.
    We've also had a super dry summer here. Just a few hours of rain in the last, probably 2 months... So dry, dusty, rutty, hard as shit, at least the smoke lifted. Still super fun.
    All the locals know these pics...
  6. Jul 30, 2024 at 6:10 AM
    RtacomaN
    RtacomaN Well-Known Member
    Taylor
    Colorado
    Did you change your headset spacers?
  7. Jul 30, 2024 at 6:43 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Good eye, bit it's a glory dh that I stripped down. I had that frame for many years, sold it 3 times bought it back back twice couldn't the last time so it go replaced with an 09. They were bulky bikes but did they ride like a hot damn.
    And a video for those of you that like old school steep rocks and wood work
    https://www.pinkbike.com/video/369472/
    tacokid09 and levie125 like this.
  8. Jul 30, 2024 at 7:41 AM
    mrtonyd
    Tony
    Colorado
    To those that replied to my question about my headset possibly being loose, I think thats what is going on.
    I checked all the linkage bolts, the bottom one on the shock was a little loose, but maybe a 1/4 turn if that. Don't think this was the problem. I only feel the rock/knock when I hold the front brake, not the rear. Kinda points to the headset.
    I haven't swapped anything on the bike besides the stem cap to one that can hold a garmin, but I did swap back to the original one and the problem is still there. I pulled the fork off and cleaned and regreased everything, the little knock is still there. It almost feels like its the headset and the CSU to lowers on the Sid. I'll have to take it to the shop today since I can't get rid of it.
    I'm suspicious I rode with the headset loose. The top bearing cup/seat looks a little worn. Running my finger on different parts feels rough but one part feels smooth. The rougher parts look silverish like they were worn down while the smooth part is still black.
    Replacing a headset doesn't sound fun. Starting to think I won't have my spur for a week or so while I wait for a replacement and shop time.
    Lighting isn't great, but the worn parts are the front and back while the smoother part is like left-front left corner.
    https://imgur.com/a/hOhb8zA
    backcountryj and 113tac like this.
  9. Jul 30, 2024 at 8:22 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    definitely looks like it may not have been tight enough at some point or maybe you got a bad cup or bearing, maybe they didn't put any grease on the bearing when the bike was put together? It's probably a mix of everything tbh
  10. Jul 30, 2024 at 9:49 AM
    mrtonyd
    Tony
    Colorado
    Took my Spur to the shop closest to my work when they opened today. They just became a Transition dealer like a week or two ago so nice.
    They didn't think it was the headset but the bushings in the Sid. They are going to open a warranty ticket with Rock Shox once I can get them my proof of purchase. Gonna have to text them a picture of it tonight when I get home.
    Sucks since I don't think I'll get my Spur back for a week or two. Luckily my Patrol is running good and I'm taking that to Snowmass this weekend anyway.
    I didn't think I was riding the Spur that hard, but maybe. At the same time, all those big XC race courses look way gnarlier than anything I've done with my Sid. Maybe I should swap to a pike like I think backcountyj has on his spur.
    levie125, gdb85 and 113tac like this.
  11. Jul 30, 2024 at 10:26 AM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I mean, those guys are tiny AND I'm sure they're servicing/replacing their forks way more frequently than you are...
  12. Jul 30, 2024 at 10:27 AM
    mrtonyd
    Tony
    Colorado
    lol true. i didn't think about them having their bikes serviced by a professional everyday.
  13. Jul 30, 2024 at 10:29 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    I need more Kudo's. Y'all should follow me on Strava
    Strava: Will D
    If you're in Washington, we can start some friendly competition's. I road ride, and MTB
    Gunshot-6A[OP] likes this.
  14. Jul 30, 2024 at 11:39 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Yup. Pike at 140, coil out back. No regerts.
  15. Jul 30, 2024 at 1:24 PM
    SenatorBlutarsky
    Utah
    @backcountryj and @mrtonyd curious your thoughts (of course anyone can chime in)...
    My wife was considering trading in her 27.5 Yeti SB140 for a Spur or SB120 or some other short travel 29er... she likes XC and endurance racing and just generally doing long rides but she's also a very capable descender. She'll ride whole enchilada at least once a year and get on the steeper stuff around Utah with some regularity. I'm thinking the Spur is a great option for this as it's in the XC travel category but seems to match her descending abilities for that travel category, especially cause she's a pretty small lady.
    mrtonyd and Gunshot-6A[OP] like this.
  16. Jul 30, 2024 at 1:47 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I'm riding the same stuff on my Spur on the top end that others on 140 bikes are on their lower-mid range, so I think you're pretty accurate in that assessment. I picked a bad line on Autobahn in Galbraith and gave the bike a few shots this weekend that were closer to enduro bike territory by accident and it held up well.
  17. Jul 30, 2024 at 2:12 PM
    mrtonyd
    Tony
    Colorado
    I agree with GunShot. The Spur is great for all day rides and can handle descents real well. You can tell its not a bigger bike, but its capable.
    I think Mo Awesome described it as an XC bike for enduro riders. Its not the lightest or fastest XC bike, but its super fun. They did an XC comparison video series in the last month.
  18. Jul 30, 2024 at 3:59 PM
    backcountryj
    Jonathan
    GA
    I’d concur with all that @Gunshot-6A and @mrtonyd have said. The Spur is small in numbers, but it backs its up like a 140 bike for sure. The very first ride I put on mine after building it up was a full upper/middle/lower black mountain run in Pisgah. Never felt under biked that whole trip. I don’t ride as hard or as fast as some, but Pisgah ain’t no slouch, regardless of your speed.
  19. Jul 30, 2024 at 6:13 PM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
  20. Jul 30, 2024 at 7:14 PM
    cartter469
    cartter469 Professional Idiot
    Cartter
    TBD
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    I tried. That shit hurted. At least I’m barely using gas compared to last summer not driving an hour to south Tahoe 3 times a week to ride lol
    Gunshot-6A[OP] and Dr. Doom Says like this.
