All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Mar 1, 2025 at 5:19 PM
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Offset...it can make a difference...several rabbit holes on this topic...this video explains it pretty well along with a link to TPC's blog explanation.
    https://youtu.be/8yOLpW1WnTU?si=fFtu2pH0oVQoFDH7
    More offset/51mm - better stability at higher speeds
    Less offset/44mm - better handling in technical sections, slower speeds.
    asuchemist[QUOTED] likes this.
  2. Mar 1, 2025 at 5:31 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    That guy is a great rider. I would be dead climbing that mountain. Great explanation.
  3. Mar 1, 2025 at 7:55 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    It's not that big of a deal.
  4. Mar 2, 2025 at 5:59 AM
    gdb85
    gdb85 Well-Known Member
    Pgh, Pa
    2016 SR5 DCLB 4x4
    ^^^ Agree, most regular "Joes" wouldn't be able to tell the difference...I'm quite certain I couldn't.
    Gunshot-6A[OP] and Pugga like this.
  5. Mar 3, 2025 at 3:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :yay:
    even the doggo is excited!
  6. Mar 3, 2025 at 4:10 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
  7. Mar 4, 2025 at 8:00 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Anyone want an EXT Aria, 185x55?
    Will need air can service. It may be the perfect time for someone else to get it retuned for them or their bike. Tune is for a 185 lbs rider on a 152 Arrival, though I’m currently running it in 140mm travel using a different link. I’m just going to convert my bike to 170mm.
    $500 shipped, comes with box, tuning card, and 600 psi pump, DOES NOT COME WITH BOTTOM HARDWARE.
    H3llRid3r, backcountryj and 113tac like this.
  8. Mar 4, 2025 at 8:15 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    Did something I don’t regret. :headbang:
  9. Mar 4, 2025 at 8:20 PM
    asuchemist
    NONE
    No regrets if you send me the other fork!
    :fingerscrossed:
  10. Mar 5, 2025 at 8:15 AM
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Anyone here have experience with USWE bike hydration packs?
    I've worn Camelbak M.U.L.E.'s, Osprey Katari/Raptors...would appreciate feedback from folks who've worn and ridden USWE products.
    Please let me know which model and pack space/hydration bladder size you utilized. Thanks in advance.
  11. Mar 5, 2025 at 9:31 AM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Unfortunately, Allied BC40 frames are no longer made in the US. I'm glad I bought before the switch.
  12. Mar 5, 2025 at 1:56 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I’ve got the outlander pro 2l. It’s one of the smallest they make but it’s nice. No bouncing with this size. I usually rock the pack, a small running pouch to hold nutrition and either a frame bag, top tube bag, or tool roll type thing.
    It’s seems like a lot but it’s like a layered EDC. I’m able to adjust depending on what I’m doing. Most of the time, I just need the hydration pack and running pouch thing.
    As far as the bag itself, it fits nicely. I’m a big guy especially for a biker at 230+/- and so I’m probably on the upper limit of the size but it fits fine. Sometimes it will ride up a tiny bit but it’s easy to fix with one hand. Build quality is great after like a year or so of use. The version I have is kind of in between a running vest and hiking pack as far as the materials they use.
    unfortunately since mine is small I can’t speak to how a bigger version would feel if it was like half loaded.
    geoyota760[QUOTED] likes this.
  13. Mar 7, 2025 at 6:42 PM
    Pugga
    Massachusetts
    Finally had some time to put into this, here they are with the Schwalbe G-One R Pros mounted up. They tested to be an extremely fast rolling tire while still having good puncture resistance.
  14. Mar 9, 2025 at 4:45 AM
    flipnidaho
    I finally had some time to put together a bike that's been in the box for a month while I focused on getting an old car baselined. I built it up yesterday using some new parts (crankset, bb, tires, grips) and some old parts (drivetrain, saddle, wheels). The SB115 came with SLX and Fox Factory suspension and seatpost and was a deal that hard to pass up. Some build pics below with before and after weights. For an apples to apples comparison, the built up weight without pedals was 24.87 lbs so a 5 lb reduction from stock. The last weight is fully rigged up with pedals for an honest ready to ride weight. The ultrasonic heater cleaner is excellent for cleaning up old parts (I use chain wax on all my bikes so it wasn't too bad). My goal was around 25 lb-ish so mission accomplished. The front Mezcal maybe to XC-ish though so that may have to be replaced by a Rekon eventually. The wheelset is 1240 grams with tape and valves.
  15. Mar 9, 2025 at 7:15 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Are those Nobl TR32's with Berd's?
  16. Mar 9, 2025 at 9:15 AM
    flipnidaho
    They're LB rims.
  17. Mar 9, 2025 at 9:27 AM
    boostedka
    James
    NM
    Nice!
  18. Mar 9, 2025 at 9:33 AM
    flipnidaho
    Maiden happened today. Still some tweaks that need to be made like cutting the steerer, shortening the front brake hose and figuring out why the Fox Transfer post doesn't extend fully half the time.
    backcountryj and PhoS like this.
  19. Mar 9, 2025 at 9:52 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    We had a similar issue with one recently and used some WPL suspension lube and it freed right up. I'm sure you've already messed with seat post clamp tightness, but if not you can try loosening it a touch.
  20. Mar 9, 2025 at 10:51 AM
    flipnidaho
    I ended up just opening it up and cleaning it. Works better now. The Transfer that came with it (brand new), I'm returning to the bike shop since it's still under warranty. I may consider the Neo as I've gotten used to how clean the bike looks with just brake hoses.
    Dr. Doom Says[QUOTED] likes this.
