All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 22, 2019 at 6:46 PM
    #8561
    dbbowen2
    dbbowen2 Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    I know a guy with this same bike. It’s fun as hell. Nice progressive frame design
  2. May 23, 2019 at 1:14 AM
    #8562
    Tacos03
    Tacos03 Well-Known Member
    Summit
    2018 TRD OR DCLB
    “Finished” up this little side project I still want it closer to the truck so I’m gonna move the fork mount in about 3 to 4 Inches it’s not too far out it just wiggles a little too much for my liking so bringing it in would be a lot better for the that. Can see the photo how much room I could move it in.
    arnette64, Jpiskura, 113tac and 5 others like this.
  3. May 23, 2019 at 4:58 AM
    #8563
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    It has aged well geometry wise I just wish it was a tick slacker up front
    dbbowen2[QUOTED] likes this.
  4. May 23, 2019 at 5:06 AM
    #8564
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Angle kits fix that ;)
    Irongrave[QUOTED] likes this.
  5. May 23, 2019 at 5:28 AM
    #8565
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    Awesome shot! Is that in Mass?
  6. May 23, 2019 at 6:51 AM
    #8566
    dbbowen2
    TN
    too many to list
    Wouldnt a longer fork do it too?
    Gunshot-6A[OP] likes this.
  7. May 23, 2019 at 6:51 AM
    #8567
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Weeknight rides without lights are back on the menu, boys! :headbang:
    Seriously, though, it's so much easier to get through a week of work bullshit when you can hit the trails for multiple hours during the week without the need for lights and hiding from park rangers... lol
    The new tailgate pad works like a charm. Love it!
  8. May 23, 2019 at 6:53 AM
    #8568
    dbbowen2
    TN
    too many to list
    Thats a dope bike man! What size coopers are you running? (on the truck lol)
    paleh0rse[QUOTED] likes this.
  9. May 23, 2019 at 7:01 AM
    #8569
    paleh0rse
    Raleigh, NC
    Thank you! The bike has definitely given me a million smiles, and counting. :headbang:
    The Coopers are 255/85R16's. I decided to try out a 33" skinny setup and have zero complaints.
    Irongrave likes this.
  10. May 23, 2019 at 9:37 AM
    #8570
    dbbowen2
    TN
    too many to list
    Nice! I am debating between 285/70/17 and 285/75/17 right now. Wondering if the 34 would even be worth it.
  11. May 23, 2019 at 10:22 AM
    #8571
    paleh0rse
    Raleigh, NC
    Those sizes definitely have a tougher looking stance, but my intent is/was to avoid the CMC and mpg/power hit of the 34+" larger tires, while still gaining the improved clearance and look of 33's. It was also nice that they fit the stock TRD OR without rubbing both before and after I changed the wheels and suspension.
    Good luck with your choice!
  12. May 23, 2019 at 10:26 AM
    #8572
    dbbowen2
    TN
    too many to list
    I see what you mean, that’s awesome that they fit stock! The 285/70/17 is a 33 and the 285/75/17 is a 34. They’re just a little wider, which is why they rub the cab mount. Cutting and welding is a non issue for me. My problem is that I keep buying bike parts hahaha.
    The biggest issue for me is if I go with the 34 I’ll need to regear. If I go 33 I don’t have to re gear, which means I could get a fox factory fork instead
  13. May 24, 2019 at 7:08 AM
    #8573
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Not the same way. Three ways you can change geo:
    1. Taller forks. 10mm of added for length gets you approx. 0.5* more slack, but it also raises your bottom bracket height, slackens your seat tube, and it will also shorten reach. Together those four differences can make the handling change quite a bit.
    2. An angle kit. It only changes head tube angle (and slightly longer wheelbase), often adjustable or available to adjust between 0.5* - 2*.
    3. Offset shock bolts (full squish only). Will slack out heatube and seat tube by 0.5*, and also drop your BB approx. 10mm. You can use two, and get 1* and 20mm drop.
    You can also combine any of these together. For example, I added a taller fork, but also an offset shock bolt. That gave me 1* more slack, and my BB right back where it was meant to be. Unfortunately, my reach became shorter by 10mm, and my seat tube was slacker by 1* as well.
    Changing geo is kind of a give-and-take situation.
    Hope that made sense. I spent some time researching this when I wanted my Troy to become more slack with a longer fork but wanted to preserve other aspects.
  14. May 24, 2019 at 7:12 AM
    #8574
    Irongrave
    Drew
    Knoxville TN
    1998 T4R Limited
    I've been doing a good bit of research myself that whole keep improving this bike and frame or drop the coin and get a newer bike that matches what I want geo wise for my riding style.
  15. May 24, 2019 at 7:18 AM
    #8575
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Thing is, newer bikes improve more than just the geo. The suspension kinematics in the last 5 years has become better by leaps and bounds (on most bikes). So many newer bikes can now give you more squish while not need climbing switches, feel supple and bottomless, provide more traction, suck up the little chatter, yet still have a crazy good pedaling platform.
    We get closer and closer to that ever popular saying, "climbs like trail bike, descends like DH bike."
  16. May 24, 2019 at 7:35 AM
    #8576
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    Won’t it also pitch the nose of the seat up into your taint?
  17. May 24, 2019 at 7:37 AM
    #8577
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    You do realize seat angles can be re-adjusted, right?
    abacall, Gunshot-6A[OP] and paleh0rse like this.
  18. May 24, 2019 at 7:41 AM
    #8578
    Apollo14
    Jonathan
    Vail, CO
    I did not. I thought they only move front to back. I’m still a new guy.
    Hence the post in the form of a question. But thanks for input! :thumbsup:
    abacall and ridge[QUOTED] like this.
  19. May 24, 2019 at 7:55 AM
    #8579
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Yep, changing seat angle is easy. Just adjust the bolts that hold it onto the rails. That's why there's a little rocker plate on the post. I prefer to slide forward and nose down a bit so my ass bones are sitting more on the rear, puts less pressure on my tender taint, and puts me in a better climbing position on those steep sections.
    Vlady and DarthPow like this.
  20. May 24, 2019 at 7:57 AM
    #8580
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    I also ride with the seat pointed down. Lets me put more power down, because it puts my pelvis and low back in a better position, and it doesn't put pressure on my taint.
    Vlady likes this.
