All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Mar 6, 2020 at 10:33 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    We all know you weren't staring at the bike
    abacall and Gunshot-6A[OP] like this.
  2. Mar 6, 2020 at 10:38 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I got the pro kit. Figured I could use it for any other sram stuff I might ahve in the future. :D
    levie125 likes this.
  3. Mar 6, 2020 at 11:51 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    I went to a local BMX practice last night on the DJ. Was a good time, ill be going more often.
  4. Mar 6, 2020 at 1:31 PM
    machspeed
    machspeed Well-Known Member
    Michigan
    2016 Tacoma TRD Offroad 4x4 Accesscab
    Terrain we ride is likely the difference. Back in the day with my VP Free the bash was there when I needed it, but it almost alway came into play when I botched a line.
    Now with 1x drivetrains and the bike brands I run, I would rather eat a chain or destroy a bb bearing than toast a frame putting the force in that area. Some bikes are built to take that impact thru the guide mounts, mine typically are not. I sometimes wish I had a 180/200mm + travel bike again, but would not put it to good use anymore.
    I am somewhat surprised you notice any better shifting with more expensive chains. Usually its the rest of the drivetrain with almost any clean chain is the ticket. A mid level chain that has the harder coating than the cheap stuff will get the best life for the money the majority of the time, and as long as the chain is clean and not worn out, shifting is not effected. I have not really heard of anyone running a high end chain who could honestly tell the shifting difference when a properly adjust and clean drivetrain was used. Usually its a snazzy coating for slightly longer chain life, and like a 50 gram weight savings.
  5. Mar 6, 2020 at 2:00 PM
    5 pigs
    5 pigs Well-Known Member
    john
    Looking forward to the ride tomorrow. Hope I get some good cards ;)
    ridge likes this.
  6. Mar 6, 2020 at 2:23 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Sunday is demo day :bananadance: Was able to reserve 2 of my top 3. The other may end up being available as the person who reserved it is also demoing multiple bikes.
    MR E30 and levie125 like this.
  7. Mar 6, 2020 at 2:25 PM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    The load goes through the BB shell area either way. But with mounts you hope the company was specifically designing for those loads. If I was routinely in more rocks I could see wanting something.
  8. Mar 6, 2020 at 4:14 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Wow. Went on a ride today out on Redstone Arsenal. First off, @Jerneyman sucks ass as a trail guide. We went the wrong way on like 5 trails to start so it was like an hour and a half of climbing, which means he the mountain goat did fine and me the mountain walrus fucking died. I also took my new pedal to the calf and that hurts like hell.
    but.
    we finally got to the top and hit a bomb ass technical downhill that I can’t wait to hit again and film for you guys. I got my first rock rash on my bike and I nearly cramped up going down it. It was awesome. Here’s our bikes for a fun “for the gram” photo.
    if you zoom in right behind my chain ring you’ll see the new gouge I got lol.
    And here’s my lovely leg
    Geoff, paleh0rse, levie125 and 4 others like this.
  9. Mar 6, 2020 at 4:21 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I've also got the pro kit. Bleeding sram brakes is a pain so anything that makes the process less crappy is welcome. If you aren't in a hurry, I might sell it in a couple weeks. My guides are dragging and I can't get them to stop it so I may buy some new maguras if my last attempt at a fix doesn't work
    mtskibum16[QUOTED] likes this.
  10. Mar 6, 2020 at 4:31 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Tidechaser likes this.
  11. Mar 6, 2020 at 5:11 PM
    backcountryj
    Jonathan
    GA
    This may be a dumb question, but how exactly do warranties work for non-original owners if the bike/frame was never registered by the first owner?
    Does the next buyer truly have the ability to just register the bike/frame via serial number I assume, and then the warrant would be honored for their uses?
  12. Mar 6, 2020 at 5:19 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Wrong way is just relative :D
    Once I ride all those trails out there, I’ll be a better guide, I promise.
  13. Mar 6, 2020 at 7:23 PM
    Colton58D
    Colton58D Well-Known Member
    2017 Tacoma Trd Pro
    That’s how they sell demo bikes. I would think any unregistered bike would work the same. Worth a try.
    backcountryj[QUOTED] likes this.
  14. Mar 6, 2020 at 7:30 PM
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    Redstone Arsenal... wow, that brings back some fun memories. My Army AIT was there back in 1992 during the summer... BRUTALLY HOT being out on a demo range, but I did enjoy our occasional sorties into Huntsville when they rarely gave us free time.
  15. Mar 6, 2020 at 8:06 PM
    ETBA
    ETBA Well-Known Member
    Erik
    Texas
    2021 TRD Off-Road
    Took the Chameleon out to Purtis Creek today... a little muddy, but the trails were flowing pretty good.
    Geoff, asuchemist, abacall and 6 others like this.
  16. Mar 7, 2020 at 8:21 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Bash guide territory. Fruita, yesterday.
    ridge, MR E30, Geoff and 11 others like this.
  17. Mar 7, 2020 at 8:24 AM
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    NOPE!!!
    Horse-thief Bench?
    I wonder how many people tried to imprint their faces on the rock at the bottom of the picture.
  18. Mar 7, 2020 at 8:31 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    There is definitely a good chance that all the dark dirt at the bottom of that photo is dried blood. :D :crazy:
    ridge and Gunshot-6A[OP] like this.
  19. Mar 7, 2020 at 8:34 AM
    levie125
    2019 DCLB TRD
    Haha thats hilarious.
  20. Mar 7, 2020 at 8:41 AM
    paleh0rse
    Raleigh, NC
    ridge, disconnected, ETBA and 2 others like this.
