All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jul 24, 2017 at 11:04 PM
    #1601
    LaRue Shooter
    LaRue Shooter "Keep your dick in a vise."
    Southern Cal
    Built up, locked 06 Sport Access Cab
    Trijicon sticker on rear window.
    Yes.
    Welp. It's called a VeeGo and it's made by a company called Ride Scoozy(.com). It's got a 500 Watt hub motor and 20" x 4" tires. It can be propelled via 5 different levels of pedal assist or just plain old motorcycle style twist throttle. Top speed is somewhere around 23mph(flat ground/weight dependent) and will do that for a good 55-60 minutes on throttle alone and can be extended well beyond that with varying results depending on what level of assist and how much you actually pedal. It'll climb a little under its own power, but you will get much better results if you help it even a little by pedaling on steeper grades. You can also adjust the torque curve to a degree if you purchase it with the LCD computer/display thing.
    I've ridden it across about 4" deep sand, but I think it really depends on the type sand you're on. It doesn't have a huge amount of torque with the 500W motor, however a 750W version that is in development will solve that and add a good 7-8mph on top. It does great on harder packed trails and gravel roads as long as you know its limits.
    I love the damn thing. It's obviously no purpose built, pedal assist MTB, but those aren't these, either. Two completely different animals. This is something that - if you were at Zion National Park - could get you from the campgrounds to the entrance of the narrows and back with ease and without having to sit next to anyone on the shuttle. Haha.
  2. Jul 25, 2017 at 11:10 AM
    #1602
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Interesting ... I know that eBikes are somewhat controversial in the purist cycling world but they are fun and practical. Full disclosure: I work part-time in an eBike shop. I don't own one (yet) but have gotten a lot of satisfaction hauling stuff on an electric cargo bike, cruising through town on an electric city bike, and tackling twisty steep (up!) singletrack on 150mm travel full-sus eMTB's. Fitting that folder into the back of an AccessCab is pretty nice.
    burntkat, JJ TACO and LaRue Shooter like this.
  3. Jul 25, 2017 at 11:57 AM
    #1603
    LaRue Shooter
    Southern Cal
    I got bored and took the thing out and rode around for over an hour along the beach last night just for kicks and barely broke a sweat. It definitely does like to have a little help going uphill instead of working purely under its own power but doesnt require much. I guess thats the idea behind the pedal assist concept. You help it and it helps you. This thing is a hoot. Can't wait to try the 750W.
  4. Jul 25, 2017 at 12:23 PM
    #1604
    dman100
    2016 TRD OR DCSB
    @LaRue Shooter it looks like you have a Bafang power train which is pretty reputable, maybe one notch below the mid-drive Bosch, Yamaha or Brose setups used by Haibike, Trek, Specialized etc. Not sure how yours is spec'ed, but the pedal assist on the brands I mention respond to bike (wheel) speed, pedaling cadence, and applied torque on the pedals, measuring these variables about 1000 times per second, and then feeding in power based on those plus the level of pedal assist that's selected. Note that in California eBikes are limited to 750W max (though those ratings are somewhat variable .... peak power, nominal power, sustained power etc) and either 20 or 28 mph, with usage restrictions based on speed and whether equipped with a throttle. 20 mph bikes with no throttle (i.e. pedal assist only) can be ridden anywhere bicycles are allowed unless the local jurisdiction prohibits them and posts the prohibition at trailheads. The "no motorized bicycle" signs do not apply to compliant eBikes; California law explicitly distinguishes between an eBike and a motorized bike, even if the latter is electric but greater than 750W, no pedals, not speed limited to 20/28 etc.
    LaRue Shooter likes this.
  5. Jul 25, 2017 at 1:13 PM
    #1605
    LaRue Shooter
    Southern Cal
    @dman100 That is GREAT info. Thanks! I guess I know why it won't go any faster, even though it clearly has a little left to give up around that 20mph mark. I love using the twist throttle, but the PA is more fun. This, however would not perform well on our local trails. Too steep and too technical. My thinking is out in the desert or around camp. Unfortunately I got my hands on it a little too late in the season to use it out there.
    Oh, and I think this uses a simple crank arm sensor for pedal assist. Pretty rudimentary compared to what you described, but it seems to work fine? I don't know, I'm still enjoying the novelty of the thing.
    Thanks again! Awesome info.
  6. Jul 25, 2017 at 2:38 PM
    #1606
    JJ TACO
    JJ TACO Well-Known Member
    16 TRD OR DCSB MT QUICKSAND
    What kind of e bikes do you sell?
  7. Jul 25, 2017 at 5:01 PM
    #1607
    kwesterh
    kwesterh Well-Known Member
    Colorado
    2020 CM Tundra
    Out for a ride shortly after getting my new truck.
    burntkat, ccallen and discostu like this.
  8. Jul 25, 2017 at 8:11 PM
    #1608
    dman100
    2016 TRD OR DCSB
    Our shop sells Haibike, Stromer, Pedego, and Xtracycle eBikes, plus non-electric Bromptons. Brompton will be announcing their upcoming eBike later this month.
    JJ TACO[QUOTED] likes this.
  9. Jul 25, 2017 at 8:19 PM
    #1609
    FlipDiver
    FlipDiver Well-Known Member
    San Diego
    '17 TRD Pro Cement
    Suns out bikes out
    burntkat, ccallen and arnette64 like this.
  10. Jul 26, 2017 at 8:32 AM
    #1610
    ackshen
    ackshen Well-Known Member
    Golden, CO
    2016 Black TRD Sport DCSB 6MT
    Magnuson Supercharged, 6112/5160
    For anyone looking for a hitch rack that doesn't interfere with the tailgate, the Thule T2 Classic works perfectly. It's almost like they designed it with the Tacoma in mind. With the rack in the flat position, you can drop the tailgate and it doesn't hit. If you tilt it down, you can open the tailgate with two bikes on it. The T2 Pro does not work, it hits the tailgate.
    Selling my Yakima HoldUp2 as I got sick of dealing with the hitch extender I had and found the raise/lower action bulky. It also had two pins to drop/raise it, the T2 classic has a much easier lever mechanism and IMO a much better rack to deal with, though less substantially built.
    FlipDiver and ToyoDrew like this.
  11. Jul 26, 2017 at 3:34 PM
    #1611
    machspeed
    machspeed Well-Known Member
    Michigan
    2016 Tacoma TRD Offroad 4x4 Accesscab
    Finally made my decision about which bike mounting solution to buy, now that summer is half over lol. I was on the fence between a tailgate pad, 1up hitch rack, or the pipeline rack.
    Ordered up a Pipeline bike rack last night, hope it works out for me and is not junk. I wanted a rack to keep the bikes in the bed, not many racks work great with Lefty, thru axle, mid fat and fat bikes, plus the standard 700c and 29er stuff etc, so this gives me flexibility
  12. Jul 26, 2017 at 4:20 PM
    #1612
    JJ TACO
    I'll have to check them out. I was thinking about getting something beside a quad to get to my hunting spots.
  13. Jul 30, 2017 at 11:32 AM
    #1613
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Went out for a ride today in Blackwater State Forest. Florida makes it miserable to ride with the heat.
    burntkat, FlipDiver and JJ TACO like this.
  14. Jul 30, 2017 at 5:37 PM
    #1614
    Trentonthegreat
    Trentonthegreat Active Member
    2016 SR5
    Here's my bike using a rec rac setup.
    burntkat, ccallen, FlipDiver and 3 others like this.
  15. Jul 30, 2017 at 5:56 PM
    #1615
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Got 24 miles in today. Rode from Deer Valley to Canyons via the Wasatch Crest. Finished on a high note! Just kidding, I rode the blue DH trail next to it cuz Im still joey AF and double down is pure gnar.
    Actually realized that I started mountain biking 1 year ago today!
    burntkat, ccallen, FlipDiver and 4 others like this.
  16. Jul 30, 2017 at 8:44 PM
    #1616
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    I like that set up it looks simple and clean. Does it just attach off the bed rails? Have a link to where it can be found? Using ratchets right now and it's not the best option
  17. Jul 30, 2017 at 9:01 PM
    #1617
    Tootall604
    Tootall604 Well-Known Member
    2015 Tacoma sb
    burntkat, kryten, ccallen and 5 others like this.
  18. Jul 31, 2017 at 4:41 AM
    #1618
    Trentonthegreat
    2016 SR5
    Yeah. It's great. Check it out. www.Recrac.com
    Dgibson529[QUOTED] likes this.
  19. Jul 31, 2017 at 5:40 AM
    #1619
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Thanks. Good price too
  20. Jul 31, 2017 at 6:25 AM
    #1620
    Turboprop21
    Turboprop21 Member
    Manny
    Any road bike guys in here?
