All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 23, 2020 at 7:00 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    First time taking someone out, not knowing their ability, I definitely took you on a fun and more mellow ride. You crushed it man, and had I known you had the time and skill I would have taken you on either one of these three.
    Here's the 'regular' loop:
    And the longer loop (what it doesn't show is the 8K descent):
    Or the high altitude ride:
    Oh, and cause someone mentioned the oil slick Ergon...
  2. May 23, 2020 at 8:52 AM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    That’s good because I can sure use some new shorts after some tire ass cheek burn I got coming off a jump yesterday lol. Swear I didn’t shit myself :rofl: thanks Maxxis
    DarthPow, 113tac and Vlady like this.
  3. May 23, 2020 at 9:01 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Rode my fiancé’s small Trek Roscoe (undersized for me) yesterday and let her ride my FS for a little. Holy shit - I actually liked it a lot compared to my FS. Not that I like it better, but it was a different type of ride and I felt much more “grounded” especially around corners. Maybe it was the small frame, but it felt like a great ride. I never really had an opportunity to try both types of bikes back to back on the same trails to feel the difference.
    113tac and backcountryj like this.
  4. May 23, 2020 at 9:06 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Question - Ever since swapping my Fork to a Fox 34, I’ve been hearing a clicking type of sound coming from my headset, or lower fork area. It almost sounds like plastic hitting plastic sound but it’s a tick that I hear constant throughout the ride. Anyone know what that could be?
    levie125 likes this.
  5. May 23, 2020 at 9:32 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    When does it click? Turning the bars or hitting a bump/ compression of suspension? Is the compression bolt tight enough?
  6. May 23, 2020 at 9:39 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Sure you didn’t...sure...
  7. May 23, 2020 at 10:02 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    So before the recent Tacoma World run on X-Tiger sunglasses I purchased some Oakley Field Jackets with Prizm Trail Torch lenses and a pair of X-Tigers to compare. I actually like the look of the Tigers and they fit ok, but comparing the lens quality back to back it’s a staggering difference. No real surprise I guess. The X-Tigers are a good option for cheap eye protection on the trail (safety glasses replacement) but if you can swing for a quality lens I think it’s worth the upgrade.
  8. May 23, 2020 at 10:19 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Yeah for the price they are definitely a solid choice considering oakleys and smiths are at least 5x more expensive. The x tigers didn’t fit me too well and the nose pad isn’t super comfortable but I just feel like there is no room to complain for the price haha
  9. May 23, 2020 at 10:32 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Not turning specifically, but going over bumps it happens...There's no play in anything with the headset or fork. But like going straight on a singletrack trail even the flat trail uneveness will make it tick every other second almost. The compression bolt where the compression knob is? Thats tight.
    jmauvais[QUOTED] likes this.
  10. May 23, 2020 at 11:38 AM
    KentuckyDoug
    KentuckyDoug Well-Known Member
    NC
    2020 TRD Sport 4x4
    None
  11. May 23, 2020 at 12:05 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Yeah but it feels way cooler to say “X Tiger” than “Oakley”
    Gunshot-6A[OP] likes this.
  12. May 23, 2020 at 12:28 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Those trail torch lenses are def a step above. But if you compare the base lenses to china oem ones, theyre a lot closer.
  13. May 23, 2020 at 12:30 PM
    Gunshot-6A
    Conner
    Everett, WA
    Hit WOW with @ginseng27 this morning. 25* with wc of 17* at the top. Little bit of fresh to work through on the climb up, but then the most heavenly BC like loam and hero dirt Ive ever experienced in UT. Such a great ride! I continue to be impressed with the Sentinel through and through, and Id buy one again in a heartbeat.
  14. May 23, 2020 at 12:52 PM
    jmauvais
    NorCal
    ...stuff
    loosen the side bolts on the stem and the compression bolt, take the headset out from the top and bottom for a re-grease. Look at the inside of your cups to check for unevenness or wear/ gouging. Look over the bearings. If all is good, re-grease and reassemble. Remember compression bolt on top cap first, then side bolts on stem afterwards. This is a simple and inexpensive solution that may fix it quick and easy. Other options start to get pricey like fork rebuild and such.
  15. May 23, 2020 at 2:14 PM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Thank you for the guidance! I’ll have to crack her open this week and inspect everything. Hopefully it’s all good and I just didn’t set something right. Fork rebuild is the last thing I wanted to hear haha. Especially because everything feels good while I’m riding, just an annoying constant clicking. Thanks again
  16. May 23, 2020 at 2:19 PM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    New bike day! Ready to put some miles on her.
  17. May 23, 2020 at 2:43 PM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Feeling too see if there is interest. I’ve got several Specialized Torch 2.0 shoes for sale. Some Oakley sunglasses, new clothing, helmets. Name it and I can see what I have and get you pictures.
  18. May 23, 2020 at 2:55 PM
    jmauvais
    NorCal
    ...stuff
    no worries. I fix a lot of my friends bikes. Common thing I’ve seen is people tightening the side bolts on the stem before the compression bolt on top. You have to compress everything and get it right first, then the side bolts lock it all together. hopefully it’s simple like that, and not a bearing or cup being damaged. I’ll hope for the best brother! And nice new bike!
    abacall, levie125 and paleh0rse like this.
  19. May 23, 2020 at 6:10 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    oh, wow!
  20. May 23, 2020 at 6:11 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    ^^^ This.
    Decide what bike type you want and Test-ride many bikes. Try at least 5 bikes minimum before starting to make decisions. Be conscious of, and try to keep the influence of Colors, brands, & marketing influence out of the decision. You'll develop a distinct preference in that process... When you find the right one you'll know.
    This process has worked for me quite well. It is time consuming - but also fun!
    Coolerman, levie125 and RockiesTaco like this.
