All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 28, 2020 at 8:36 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If you take the front wheel off, you'd prob be able to. My shortbed is way too short to hold a bike with both wheels on.
    Malvolio and 113tac[QUOTED] like this.
  2. May 28, 2020 at 8:37 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I don't think the long beds can even do it comfortably and consistently. :/
    DarthPow likes this.
  3. May 28, 2020 at 8:38 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Yeah I know there is no way I’ll be able to fit it with the front wheel on. My plan is to build a drawer for my tools and other random stuff so I can clear up the cab
  4. May 28, 2020 at 8:38 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    It’s doable with a fork mount positioned low enough to clear the bars of the roof and you’ll have to angle the rear of the bike for anything modern geo. Fitting two bikes under the cap gets tricky.
    113tac[QUOTED] likes this.
  5. May 28, 2020 at 8:40 AM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I can't speak to the short bed part (though I could go measure how much extra length I have in the long bed). Height wise, this setup worked fine for me with a cab-height snugtop shell. The bikes slid in/out just fine.
    PFXv3_ttZNRMftwVZWAHYGsph5OFdHuA7jbePC6z_358eda3135f81e3f2f6e85ed664cb0be3c41a5a2.jpg
  6. May 28, 2020 at 8:40 AM
    113tac
    Stephen
    Northern Virginia
    If I have two it would likely be an MTB and gravel bike, hopefully that’s a little easier. I’m thinking one drawer to the side and bike on the other, do you think that would fit?
    E-Paz 732NJ likes this.
  7. May 28, 2020 at 8:42 AM
    Gunshot-6A
    Conner
    Everett, WA
    Think about how wide your handlebars are as well. I suspect thats part of why he has it in the middle, along with being his interior walkway
  8. May 28, 2020 at 8:42 AM
    113tac
    Stephen
    Northern Virginia
    Solid! Looks like plenty of room to the sides even if I had to angle it
  9. May 28, 2020 at 8:43 AM
    113tac
    Stephen
    Northern Virginia
    Yeah I might go do some fitting, drawers aren’t required, it’s more out of boredom haha. Covered storage out of the cab is my main goal haba
  10. May 28, 2020 at 8:43 AM
    backcountryj
    Jonathan
    GA
    I think so. As long as the drawer is on one side leaving full bed to roof clearance for the bike. Honestly I’d be skeptical if you could run two bikes with a drawer system.
    Perhaps with the right ingenuity and a pull out slide setup you could do it though.
    Edit: @SenatorBlutarsky just posted what I was referring to slide out wise. Short beds may still have an issue though. Man I miss my trail limo.
  11. May 28, 2020 at 8:44 AM
    SenatorBlutarsky
    Utah
    The problem you could run in to angling it is having wide bars fit. I had to have both fork mounts positioned pretty close to the middle or our bars would hit the outside of the shell window where it angles down.
    Gunshot-6A[OP] likes this.
  12. May 28, 2020 at 8:44 AM
    Gunshot-6A
    Conner
    Everett, WA
    That was my 2nd quarantine project
  13. May 28, 2020 at 8:48 AM
    113tac
    Stephen
    Northern Virginia
    I’ll do it live and just measure and play around with it when I get the cap haha
    Gotcha, I think it will be doable, I’ll probably just have to think about a design that I like.
    Nice! I figure it will be a productive use of my time haha
  14. May 28, 2020 at 9:10 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Yea, I have a long bed, and even with a Medium Frame 27.5, I have to tilt the wheel for it to fit laying down.
    ginseng27[QUOTED] likes this.
  15. May 28, 2020 at 10:05 AM
    ginseng27
    '17 DCSB OR
    not enough.
    Definitely not gonna be able to put a large 29er there. Lol.
    That said, over the weekend, I had a Yakima hangover 6 bike all fully loaded. And a small 27.5 on my tailgate pad all sitting perfectly. 7 bikes just looks ridiculous but fun.
    levie125 and 113tac like this.
  16. May 28, 2020 at 10:19 AM
    DarthPow
    Yea the tailgate pad would be ideal for carrying several bikes, but since I'm usually only carrying one MTB (or two road bikes, but I have fork mounts on the front bed rail for those) I just lay it down flat, and go.
  17. May 28, 2020 at 10:53 AM
    ginseng27
    '17 DCSB OR
    not enough.
    Nice. Good way to do it. Actually, I think evoc sells single or dual pads for use with one or two bikes. So you don't have an entire 5 or 6 bike pad. That said though, might as well get the entire pad. Haha.
    I'm still just waiting to get a one up rack. :/
    DarthPow[QUOTED] likes this.
  18. May 28, 2020 at 11:13 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    the bomber pads work good for a single bike too
  19. May 28, 2020 at 1:13 PM
    DarthPow
    I'll check out the EVOC options, but the bomber pad is crazy expensive for just one bike, like at that point, I'd just get the full width pad...
  20. May 28, 2020 at 1:29 PM
    ginseng27
    '17 DCSB OR
    not enough.
    I had to check. it's called the "Evoc tailgate pad duo". holds two.
