All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jun 8, 2020 at 11:56 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I should clarify, by uphill pig I meant slow rolling but it was a beefy tire when I tried it.
    Buddy demo'd an Ibis ripley that had dual assegai's on it and he did not enjoy the 2000+ ft pedal around PCMR.
    113tac and Bannerman[QUOTED] like this.
  2. Jun 8, 2020 at 11:57 AM
    Gunshot-6A
    Conner
    Everett, WA
    Bingo: My fork is funny. Did you use SRAM butter? Well, no... *click*
    Bannerman likes this.
  3. Jun 8, 2020 at 11:57 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Oh I bet it's miserable on the back. I don't feel like modern trail bikes have much weight on the front tire when climbing so hopefully wont suffer too much.
    levie125 likes this.
  4. Jun 8, 2020 at 12:03 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I've been running the Assegai up front and absolutely love it. The grip on DH is phenomenal. Granted, it is a bit heavy but as a front, not much of a concern. Didn't feel like it's become a detriment for my uphill performance.
    DHR II in the rear and it is a bit of a bear goign up but it's doable. I thought about Aggressor in the rear but didn't want to deal with changing it up just yet.
    Bannerman[QUOTED] likes this.
  5. Jun 8, 2020 at 12:06 PM
    Bannerman
    Johnson
    Charlotte, NC
    I'm running a coil and 4 pot brakes and am never going to be the first guy to the top. I'm excited to try it.
    Gunshot-6A[OP] likes this.
  6. Jun 8, 2020 at 12:12 PM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    These flats were not stans-able, both required some bacon to seal. Mine was right next to one of the center lugs and my wife punctured the sidewall. Either way, I think we're gonna both go with DD casing now since the desert can be pretty harsh on tires.
  7. Jun 8, 2020 at 12:23 PM
    ginseng27
    '17 DCSB OR
    not enough.
    that's why i run cushcore! :D no flat worries. I've had to flat repair other people's tires though mid trail though. :/
  8. Jun 8, 2020 at 12:32 PM
    SenatorBlutarsky
    Utah
    I know cushcore helps with pinch flats and ring dings, but I assumed it wouldn't prevent a hole right in the middle of the tread...?
    abacall and Gunshot-6A[OP] like this.
  9. Jun 8, 2020 at 12:42 PM
    ginseng27
    '17 DCSB OR
    not enough.
    no, but even if you have a flat tire, you can use it as a run-flat almost. Can help you get down the mountain. There have been moments when I've ridden with less than 15 psi because I just didn't check. and then I get to the next ride and pump up and realize it was that low. :/
  10. Jun 8, 2020 at 12:45 PM
    Gunshot-6A
    Conner
    Everett, WA
    I was reading something interesting the other day. One thing they have been finding with all rim insert designs is that it can prevent against sharp objects but the likeliness that you can burp / blow up a tire also increased if hitting big features because the air volume is smaller so the pressure ramps up way quicker than with a non-insert tire.
    113tac likes this.
  11. Jun 8, 2020 at 12:56 PM
    ginseng27
    '17 DCSB OR
    not enough.
    interesting. you have the source? I haven't burped my tire at all since putting cushcore in and i've been charging harder this year. Cushcore provides some insane sidewall support.
  12. Jun 8, 2020 at 1:09 PM
    Gunshot-6A
    Conner
    Everett, WA
    I'll look for it. But I mean hitting MASSIVE stuff. Like, far above our ability stuff.
    ginseng27[QUOTED] likes this.
  13. Jun 8, 2020 at 1:47 PM
    ginseng27
    '17 DCSB OR
    not enough.
    oh gotcha. haha.
  14. Jun 8, 2020 at 1:54 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    What an eventful day. 3 miles in and everything went to shit
    First, my chain snapped (2 months old), Maybe the dork disc does serve a purpose! :rofl:
    Go on, hit a few jumps some ups and downs. 10 mins later I go to change gears and it doesnt snap but the chain gets pushed All the way into the spokes. And the derailur was bent wedged on the inside of the cassettes biggest cog. I had to walk it out. In the lot I took a closer look and I cracked my derailur where it hangs to the hanger/bent the hanger as well. Just my luck my LBS had the same derailur, 1 left too lol.
    All Gucci now for my trip this weekend. Would have sucked if I had to order something
  15. Jun 8, 2020 at 1:57 PM
    Gunshot-6A
    Conner
    Everett, WA
    paleh0rse[QUOTED] likes this.
  16. Jun 8, 2020 at 2:09 PM
    ginseng27
    '17 DCSB OR
    not enough.
    jeez. that sucks for your ride.
  17. Jun 8, 2020 at 3:47 PM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    I always love the scent of fresh ferns.
  18. Jun 8, 2020 at 5:24 PM
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    I have been running DHF’s front and back on my scout and they have been great
  19. Jun 8, 2020 at 7:21 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    I actually dig the other color combos, and the performance reviews of the fork have my attention, as well.
    E-Paz 732NJ, stronghammer and 113tac like this.
  20. Jun 8, 2020 at 7:33 PM
    paleh0rse
    Raleigh, NC
    I think the 543mm axle-to-crown at 130mm travel might work well enough on the Stache, but it won't fit anything larger than 29x2.5. Lame.
    The lack of a 29+ version is a little annoying, for sure.
