All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jun 10, 2020 at 4:58 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    There’s a place up here that has all the equipment you could want.
    Carolina Fitness Equipment. That’s where I get all my stuff.
  2. Jun 10, 2020 at 5:06 AM
    SummitBound
    SummitBound Well-Known Member
    Greenville, SC
    2019 T4R OR
    I’ll give them a look, thank you! Just wanting a barbell and bumper plates right now. Potentially a small squat stand.
    but rogue has been sold out since this all started
    Bannerman[QUOTED] and Colton58D like this.
  3. Jun 10, 2020 at 5:08 AM
    Colton58D
    Colton58D Well-Known Member
    2017 Tacoma Trd Pro
    #140 plus some steel plates. but now someone is coming to buy them.
    SummitBound[QUOTED] likes this.
  4. Jun 10, 2020 at 5:11 AM
    Colton58D
    2017 Tacoma Trd Pro
    I got my squat rack/pull-up bar combo at Walmart. It was a little over a $100 but it does the trick. Good for the small garage gym.
  5. Jun 10, 2020 at 5:13 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Here are some of the trails around the Rochester NY area. I do not have experience at all the trails but you can at least check them out if you are in the area.
    https://www.mygroc.com/local-trails/
    E-Paz 732NJ[QUOTED] likes this.
  6. Jun 10, 2020 at 6:07 AM
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
    Here is another resource: http://www.cycle-cny.com/trails/
    I've never ridden in the Finger Lakes, but if you were in the Syracuse area, I could give you some opinions on trails. I would imagine that trails near Ithaca should be good considering having two colleges and generally a good sized community of outdoor enthusiasts.
  7. Jun 10, 2020 at 6:21 AM
    SummitBound
    Greenville, SC
    2019 T4R OR
    Glad they are selling so quick after reposting!
  8. Jun 10, 2020 at 7:01 AM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Thanks man! I did eventually find those two on Trailforks and what not but couldn’t really get any informative review so wanted to find someone who maybe had experience. If you had one day to ride out there which would you hit? Probably Shindagin?
  9. Jun 10, 2020 at 7:08 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Thank you for this link! Definitely helps and good to know Shindagin is a bike specific trail system. We won’t be up that way near Syracuse though. Gonna be staying just 20 mins west of Watkins Glen. Thinking Bike first day, hike the Glen the 2nd day, then paddle board and maybe hit a winery and disperse camp the last night (Taking my fiancé up there for her B-Day).
    Geoff[QUOTED] and Gunshot-6A[OP] like this.
  10. Jun 10, 2020 at 7:10 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Erwin is quite a bit bigger, but is likely farther away from you. It's like 10 mins from work when I go up there, so it's my go to.
  11. Jun 10, 2020 at 7:14 AM
    Gunshot-6A
    Conner
    Everett, WA
    Oh, if you're in Watkins Glen, def Erwin then. Corning has a few good breweries there if they're open, like Liquid Shoes and Iron Flamingo
    iriddler likes this.
  12. Jun 10, 2020 at 7:23 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    Haha yes it’s actually closer. However, we are hitting the trails along the way up there on our drive so both seem to be along the way. Erwin will be right off the main highway I have to take and is only 20mins away from where we’re staying. Think Erwin is more fun?
    Thanks for the tip, maybe we’ll check out a brewery after if their open
  13. Jun 10, 2020 at 7:28 AM
    Gunshot-6A
    Conner
    Everett, WA
    I think you'll be happy with Erwin. But that part of NY, you just have to embrace what you have. It's a far cry from Utah riding level, but it was still fun to ride and goof around on it with some of my local buddies.
  14. Jun 10, 2020 at 8:49 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Standard 2 syringe process. Except the Dominions added a second port on the caliper, they call it the "two stroke." It's essentially a second port on the other side of the caliper, which you can use if they are being really tricky. I've never had to use it to get a perfect bleed. It would be useful if you did a seal replacement on the caliper though, which again, I've never had to do in over 2K miles on the enduro bike.
    Here's a link to the bleed process.
    They also slowly let you know when it's time for a bleed. The lever throw gets a hair longer here and there, and if you need to use the reach adjust, you know it's time. Even then, performance doesn't change, just lever throw.
    They have a ton of extra features which you don't see on most brakes too; working bite adjustment, crosshair caliper adjustments, two stroke bleed option, etc..
    Super predictable, tons of power, buttery lever feel, perfect modulation, simple bleed, hold bleeds longer them most, never fade. Don't know what else you can possible want.
    Check out the rack options on Tires on Trails. It's a Yakima Bed rack, front loaders on top of that.
    levie125 and Gunshot-6A[OP] like this.
  15. Jun 10, 2020 at 11:59 AM
    Gunshot-6A
    Conner
    Everett, WA
    @2012TacomaGuy has a cool setup for his bike that I thought needed sharing.
  16. Jun 10, 2020 at 12:01 PM
    Bannerman
    Johnson
    Charlotte, NC
    Interesting, doesnt seem very stable front to back though, unless there is more support I am not seeing.
  17. Jun 10, 2020 at 12:02 PM
    Gunshot-6A
    Conner
    Everett, WA
    I'm hoping he chimes in, because I too have questions.
  18. Jun 10, 2020 at 12:04 PM
    Bannerman
    Johnson
    Charlotte, NC
    I mean, really cool use of space. Just with the bike being sideways, and the forks being turned, if he hits the brakes hard it seems like the bike would flop over into the bed. @2012TacomaGuy fellow Yeti brother, we need answers.
  19. Jun 10, 2020 at 12:21 PM
    2012TacomaGuy
    2012TacomaGuy Well-Known Member
    Hayden
    Goodyear AZ
    2012 Pyrite Mica DCSB TRD Sport
    Empty wallet
    Give me a couple minutes and I’ll mount the bike up and take close up photos of the supports. I use two cam buckles. There are more photos in my build page. It was fabricated by @EatSleepTacos #randyfab
  20. Jun 10, 2020 at 12:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    With it mounted like that, he'll run a strap through the spare tire and around the frame of the bike. That keeps it from flopping around. It also takes stress off of the welds and the forks of the bike.
