All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Nov 3, 2021 at 10:32 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    you guys have tires?!
  2. Nov 3, 2021 at 10:33 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    My wife's tires are also flat
  3. Nov 3, 2021 at 10:46 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It's three squeezes and 2 fist bangs on the top. The fist bangs can be skipped if the first squeezes indicate it needs more or less air, but they are a required final step before riding.
    mrtonyd and guitarjamman[QUOTED] like this.
  4. Nov 3, 2021 at 11:07 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Lets not forget the between the leg look at the rear tire when going over roots and rocks to make sure it doesn't squish too much.
  5. Nov 3, 2021 at 11:30 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I do for sure. Only way I know my exact tire pressure is when I pull out the floor pump.
    Oh I love this check. Until I run into the tree in the approaching turn because I was all pressure conscious.
  6. Nov 3, 2021 at 1:19 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Oh I def do this if they aren't too squishy
    Only when they want to.
    backcountryj and mrtonyd[QUOTED] like this.
  7. Nov 3, 2021 at 1:44 PM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    then you ask your buddy eyyy what do you think? Think I'm good ?
    backcountryj likes this.
  8. Nov 3, 2021 at 6:44 PM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Ha! Made me chuckle :p
    Honestly, I'm definitely OCD when it comes to tire pressure. And bar/fork alignment. And having tire logos lined up to valves. And hub logos opposite valve stems. And logo placement. Can't handle chain slap, or creaks. And cables have to be tidy. And cleaning/lubing chains every time I ride...
    Shit.... I may have a problem....
  9. Nov 4, 2021 at 5:08 AM
    guitarjamman
    Zach
    Northeast
    2019 Ram 2500
    I understand the obsessive side of bike maintenance. I bought my bike used so it came pre-scratched, but I have put more elbow grease into maintenance and little nuances like you described than I care to admit. I honestly check my tire pressures before every ride, make sure my shocks are at the right pressure, lube my chain, adjust my derailleur at least once a month, etc.
    It is all completely NOT necessary, but I enjoy riding my bike and if not riding, I like to be able to tinker and interact with it. Sometimes I just stare at it.
    Kf-fT1X_0diyN6ONQabvt0wl8i859H9kjZJcXF0-_3952d5c67e31ed069549367f193d11c0f679149d.jpg
  10. Nov 4, 2021 at 5:08 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Not checking air and feeling the tire squirm on a jump is always a good indicator.
    guitarjamman and Gunshot-6A[OP] like this.
  11. Nov 4, 2021 at 7:49 AM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    I just joined the full squish club. First full sus, guy who sold it to me actually has a taco and might end up on here. Excuse the Subaru I picked it up in.
    Guy upgraded it a good bit and I know some of the stuff but like I said new to the full squish game. Hopefully going to get out today.
    Anything I should know? Had a hardtail before
  12. Nov 4, 2021 at 8:00 AM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Your tire logo’s aren’t lined up with your valve stems.
  13. Nov 4, 2021 at 8:01 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Do you work in the industry?
    Is it a flip switch? Usually I ignore people's opinion on coil shocks because the overwhelming bias associated with a big purchase ("iT trAnSfoRMed my bIKe"). But, I always trust your opinion and you have me coil-curious for my future trail bike. I tend to also be in the lightweight category so air shocks are not ideal for me. The more other bikes I ride the more I realize I need a new bike...
    abacall[QUOTED] and backcountryj like this.
  14. Nov 4, 2021 at 8:09 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    going from a hard tail to full squish does take a bit or relearning. setting up your suspension will take a few rides too. start with your sag on the fork and shock. rebound and compression gets a little more complicated. find a good setting and when your on the trail change it a click or two in either direction. not everyone uses the same setting, but you can use other's settings as a starting point. (i still dont know what my suspension is set at and change it every few rides cuz why not. ive also had this bike for like 2 years now)
    Cipher94[QUOTED] likes this.
  15. Nov 4, 2021 at 8:53 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Not anymore, no.
  16. Nov 4, 2021 at 9:43 AM
    TacoDozer22
    TacoDozer22 Well-Known Member
    Greg
    Colorado
    2018 DCSB OR
    You will probably need to increase your rear tire pressure compared to a hardtail. Now you you get traction, compliance and bump absorption from the suspension more so than the tire.
    make sure your rebound is set on the rear. You’ll adjust it based on shock pressure and ride feel. If you don’t have separate LSR/HSR adjusters it’s probably not too critical since single adjustment rebound knobs control LSR but LSR can certainly impact HSR if it’s too extreme.
    might need to mess with volume spacers too.
  17. Nov 4, 2021 at 1:23 PM
    mrtonyd
    Tony
    Colorado
    someone must have been following this thread and came up with this presta replacement
    https://www.pinkbike.com/news/reserves-fillmore-valve-aims-to-make-tubeless-easier.html
    looks like the whole 'valve core' is replaceable too
    https://bikepacking.com/wp-content/uploads/2021/11/Reserve-Fillmore-Tubeless-Valves-Review_3.jpg
    id like to give these a shot, but they don't look like they would work with cush core?
    6. Can you use CushCore with the Fillmore valve?
    - Yes, it works, but the poppet pushes against the CushCore when you release pressure, so it takes additional force on the cap to let the air out of the tires."
    levie125, Pablo8 and Gunshot-6A[OP] like this.
  18. Nov 4, 2021 at 2:03 PM
    azinwood
    azinwood Active Member
    Seattle, WA
    21 OR Cement
    Why wouldn't it work with cushcore? says it does, just takes more effort to push the plunger since it's up against cushcore.
  19. Nov 4, 2021 at 2:36 PM
    mrtonyd
    Tony
    Colorado
    the valve that came with my cush core has like a u shape on the part that sits in the rim to allow air under the insert. since this doesn't have that, i wasnt sure.
  20. Nov 4, 2021 at 4:23 PM
    azinwood
    Seattle, WA
    21 OR Cement
    I think from the videos and the descriptions on PB it should work. The space created by the plunger when it is depressed should allow air to fill in and around the insert similar to the one provided by cushcore which directs the air perpendicular to the valve stem.
    mrtonyd[QUOTED] likes this.
