All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Apr 7, 2022 at 6:53 PM
    Wile_E_RedDog
    Wile_E_RedDog Well-Known Member
    Terry
    Sacramento, CA
    2008 Silver Tacoma OR Baja DCSB
    AT Overland Summit,
    LOL, Again in the process of maintenance and fitting a new/old fork and spacers would go below to determine many were needed when the top cap was tightened down. It's in the first step of checking a fit. Note no break levers on it, no dropper lever, nothing but tightened down to keep the fork from falling off while it's travel is checked blah blah blah blah.
    But yes, if the fork works I expect it will have two spacers below and one above after the fork is cut after it is determined to work with the bike.
  2. Apr 7, 2022 at 6:57 PM
    Harry P. Ness
    Harry P. Ness Well-Known Member
    Ben
    Arizona
    2019 silver double cab trd off road
    Wave 3. 8:15.
  3. Apr 7, 2022 at 7:46 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    BRUH, I just scored this felt f70 in absolutely tip top condition for a killer price. Light af too. Needs a new back tire. Gonna ride this baby till the wheels fall off. Anyone recommend going tubeless ? As for the ELY Nevada race. I might have to bow out. Elbow surgery is happening very soon.
    azinwood and Pugga like this.
  4. Apr 7, 2022 at 7:56 PM
    Wile_E_RedDog
    Terry
    Sacramento, CA
    AT Overland Summit,
    Dam nice job That's a big bike you must be a big guy.
  5. Apr 7, 2022 at 8:12 PM
    vorkuta775
    Texas
    tesla truck
    Yeah I'm fluffy, THICCC. nah I'm 6 foot 260.
  6. Apr 7, 2022 at 8:28 PM
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    vorkuta775 likes this.
  7. Apr 7, 2022 at 8:42 PM
    vorkuta775
    Texas
    tesla truck
  8. Apr 7, 2022 at 10:31 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I have heard that ARB compressora can work. I use the airshot which is essentially a can with a tube to connect to your valve to blast it with air. :/
    Gunshot-6A[OP] and abacall like this.
  9. Apr 8, 2022 at 3:39 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Nice.
    I'll never not recommend tubeless but it's less important, I think, with narrower tires.
    Road tibledd can be a bit tougher to set up as well.
    My road bike is set up on 30s and tubeless most of the time but I usually race on 28s with latex tubes.
    vorkuta775[QUOTED] likes this.
  10. Apr 8, 2022 at 5:45 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    That's the easiest way to go. Fill the can, connect to your tire and blast it.
    ginseng27[QUOTED] likes this.
  11. Apr 8, 2022 at 2:07 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    My ARB single can do it, unless you have a particularly feisty tire/rim combo. I already had a track pump and this, so I didn't get an airshot type pump.
    Most importantly, people look at you like some sorta space wizard when you pull an air compressor hose out of your truck at a trailhead and fix a bead :rofl:
  12. Apr 8, 2022 at 7:21 PM
    vorkuta775
    Texas
    tesla truck
    Got some new rubber on this morning, minor adjustments, bike is solid. Did a 33 miler today. Really windy, high of 77 . Good Friday ride.
  13. Apr 8, 2022 at 9:30 PM
    Wile_E_RedDog
    Terry
    Sacramento, CA
    AT Overland Summit,
    As one would justly deserve!
  14. Apr 9, 2022 at 2:09 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    +1 for the Airshot (check Amazon). Soapy water always helps too
  15. Apr 9, 2022 at 10:27 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Thank You! I could not figure out why my make shift
    Yep, it's a keeper for sure!
  16. Apr 10, 2022 at 5:55 AM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Time for the annual seal service for the 36. While I wait for the parts, I figured it was a good time to get the backup bike up and running. The backup bike had a creak under power and come to find, the plastic preload collar decided to crack. It also needed a new AXS rear derailleur (the old AXS RD bricked but SRAM replaced it with no questions asked) and an AXS Reverb burp, and a quick burn off some brake pad contamination.
    azinwood, mrtonyd, neatoneto and 6 others like this.
  17. Apr 10, 2022 at 6:38 AM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
  18. Apr 10, 2022 at 7:00 AM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Nice! I'm in the same process right now with my Wrecker. It's completely torn apart. Checking and repacking all bearings, sending in fork/shock to Push, peeled and reinstalling Ridewrap, new frame stickers, brake bleed, caliper rebuild, clean and retape wheels, re-tension true wheels, new handlebar, new grips... Full rebuild in place of a new bike.
    I was sooooo close to pulling the trigger on a Dreadnaught or Spire. In the end I realized I still really love the Wrecker, so I'm going to make it feel new again.
    neatoneto, RockiesTaco, jubei and 4 others like this.
  19. Apr 10, 2022 at 7:04 AM
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    I enjoy bikes w/throttles more than pedals (unless there is more than one grandkid present)
  20. Apr 10, 2022 at 7:07 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Spent a quarter of yesterday circumnavigating America’s Mountain. I’ve done a few variations of this over the last couple years.
