All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 8, 2021 at 7:47 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Love the looks of that bike! What's the biggest bottle you can fit?
  2. May 8, 2021 at 8:58 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Thanks!
    I honestly don’t know. My frame is a size medium and I use a side entry bottle cage. Could be tight with a top load cage.
    Both these bottles fit, and both hold similar volumes of water (20/21oz). The bigger one is the insulated style. Pretty obvious a larger volume non-insulted bottle will fit, but I haven’t tested anything larger.
    mtskibum16[QUOTED] likes this.
  3. May 8, 2021 at 9:15 AM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Damn funny. Live in the PNW. Top of my driveway is a 22% grade...
    Malvolio and GarlicFarts[QUOTED] like this.
  4. May 8, 2021 at 11:29 AM
    Tacobello
    Tacobello Well-Known Member
    2018 Magnetic Gray Metallic TRD OR DCSB
    I've been looking at tray style racks but occasionally sleep in the canopy. How accessible is the glass and tail gate with two bikes on one of these?
  5. May 8, 2021 at 12:13 PM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    Hasn’t been a problem for me but I do run the Kuat hitch extender so that it’s not in the way when I open the tailgate - https://www.amazon.com/Kuat-Racks-Hi-Lo-Hitch-Extension/dp/B003ASYPPU
    Most of these carrier tilt down/out for opening tailgates on SUV/crossovers.
    Thank you so much for the grips! @RockiesTaco
  6. May 8, 2021 at 12:17 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Depends on the rack, and if you have the stock receiver location or something higher in an aftermarket bumper. I have a 1Up 2 bike rack and it tilts down in seconds with the bikes on it, which allows me to lower the tailgate fully without hitting anything. And when I had my shell, I could open the liftgate easily too. 3rd Gen DCSB. You still had to go in from the sides of the tailgate to crawl in, but perfectly manageable.
    Malvolio and neatoneto like this.
  7. May 8, 2021 at 12:20 PM
    dman100
    2016 TRD OR DCSB
    No shell in this pic, but you can see the 1Up clearance. 6481D283-4C80-41EF-B9B8-8894AEC2F9BD.jpg
  8. May 8, 2021 at 1:25 PM
    backcountryj
    Jonathan
    GA
    Just gotta be mindful of the inboard bike pedal position :anonymous:
    Malvolio, levie125 and neatoneto like this.
  9. May 8, 2021 at 9:21 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Just wanted to share that my oldest (9yo) took me out for a 13-mile ride with pretty significant climbs tonight. She’s really getting into riding, and I’m hoping we have many more years of biking and camping and rock climbing and exploring.
  10. May 9, 2021 at 6:04 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    ACtC-3e8lEstlhkVvPP_VP-5FA4w4lmfJggD8pin_f5b7c638582799cdcec58ab5e5f4127316a7a452.jpg
    ACtC-3cJjBpEVnaoyBvcoOl6yMDHfjkmhd_WnAYU_412a7a907a9c992012ef95a27d1dce7bfe3827f0.jpg
    I'm also trying to solve the opening the tailgate with a hitch rack puzzle but with the twist of having a much higher receiver than factory. I'd be open to buying a new rack that folds down lower. It seems like 1up is about the lowest but it still sticks up almost 5" higher than the hitch pin, room I obviously don't have.
    The Kuat I have sticks up twice that much, I could try a drop hitch adapter but it would need to be at least 8" of drop if I measured everything right...super awkward. A 14" straight hitch extender should get the rack just beyond the tailgate, which I'm going to try. Seems like that would be slightly less awkward but ultimately disappointing on at least one level.
    I've got a Decked system under the Softopper so a tailgate pad won't work. I tried an upright roof tray on my cab rack but that's less than ideal. Anybody got any bright ideas?
  11. May 9, 2021 at 7:37 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    If you're set on trays, a swingaway extender might be an option IF you can mount it upside down. Below is a pic with one.
    Anyone know if they can be flipped? It would need to be flipped at the hitch mount and the tray mount. Otherwise he's in the same predicament.
    Or, take a look at this article I wrote a while back. You can use roof trays mounted on the bed rack.
  12. May 9, 2021 at 10:01 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    That's a good point, but don't think mounting it upside down would be a good idea. The lower arm that sits underneath the swing out is probably designed to absorb some of the weight of the actual bike rack. I would definitely check and see if it voids any warranties by mounting it in a way it was probably not designed to be mounted. I would also think you would be liable for any failures due to using it in a manner it probably wasn't intended to be used. Just my $.02
  13. May 9, 2021 at 11:53 AM
    backcountryj
    Jonathan
    GA
    Slithery friends are back out
    Clipless doesn’t always mean painless
    tweakit88, abacall, 113tac and 8 others like this.
  14. May 9, 2021 at 12:11 PM
    mtskibum16
    PNW
    Looks to me that the moment of the rack at the point the swing arm is connected is transferred through the vertical pin connection. The moment on the pin will essentially transfer the load the same in either orientation. The small amount of vertical shear the lower arm is taking should be pretty easily handled as a tensile load in the pin. That's my thought at least at first glance. I'd want to look at the assembly closer to be sure.
    rblalliance[QUOTED] and levie125 like this.
  15. May 9, 2021 at 3:01 PM
    neatoneto
    CT/Mass
    Got up to New Hampshire today to enjoy the prime weather.
    Malvolio, mtskibum16, abacall and 7 others like this.
  16. May 9, 2021 at 3:16 PM
    E.J.
    Josh
    NWA
    ACtC-3d4OBy_Q2Q49nl_8idpeo9o16NBIl2iUSVV_affdce3e51a1c135e2138943094fa7705688dba3.jpg
    Grom and Mom. Our nine year old crushed 8 miles of Ozark single-track today.
    vicali, mtskibum16, abacall and 9 others like this.
  17. May 9, 2021 at 3:21 PM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    Dented my rear rim... unable to get it to hold air. I used a butane torch and hammer/pliers to try and get it back. Any other ideas? Or bombproof wheel recommendations? edit; maybe i should look into vittoria air-liners....
    Also cinched the tire. Not sure if patch will work since I don't have a rim to test on lol
  18. May 9, 2021 at 3:32 PM
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    All joking aside, I have some S1’s for sale.
  19. May 9, 2021 at 3:39 PM
    piff
    Minnesota
    Bone stock baby
    hmm... well TBH I was really only looking for a rim... I only have ~120 miles on hub/cassette trying to avoid replacing everything if possible.
    mrtonyd and levie125[QUOTED] like this.
  20. May 9, 2021 at 4:05 PM
    TacoDozer22
    TacoDozer22 Well-Known Member
    Greg
    Colorado
    2018 DCSB OR
    Could you use a 1up in combination with a Kuat hitch drop?
    levie125 likes this.
