All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Nov 2, 2021 at 5:10 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Carbon bars... meh. Sure, they look good, and maybe offer a touch of difference. But I'd definitely say not worth the $.
    Longer droppers are awesome, and Oneups is a great price for a great dropper. Longest drops, adjustable, and reliable. Easy to spend the $ on that.
    FWIW, I've run damn near every shock option out there... Coil shocks are funny. I've honestly found that air can be just as good, if you have some heft behind you. I'm not heavy (150 w/gear) so coils really make a pretty large difference in terms of sensitivity. BUT, they usually lose some of the poppiness. Unless you get a specific tune for them! The 11-6 is an insanely good shock, and I'd argue worth every damn penny. Especially since you are really getting two shocks in one. They don't have a climb switch, they actually have two different tunes you can switch between and independently adjust as well. I have mine set up for trail mode, and DH mode.
    Another option, for you, is to go to Suspension Syndicate and get an EXT specifically tuned. They will adjust it, tune it, and help you get it dialed in to your bike and riding style. My buddy Rich loves his on his Enduro. Said it completely transformed it into a poppy, lively, and plowable bike.
    The advantage to these two options is that they are transferable between bikes. I know Push will adjust your shock to fit a new frame. I'm not 100% sure, but I think the EXT can also.
    Like I said; with the other off the shelf options, yes this can happen. It doesn't always, since a lot of that depends on suspension kinematics, but it can.
    On my 160mm Spartan, it did. I tried a Fox and MRP. Both made the bike faster, more calm, and so much smoother. But it did lose some pop no matter how I turned the dials.
    On my 140 Troy, the Cane Creek IL kept it's playful character. I think that's easier to achieve on a shorter travel frame since the mid-stroke is shorter and easier to pump off of.
    If you do get a used one, don't forget you need to send to Push anyway for a retune. Resizing is like, $250, I think. And a retune is an additional $150 above a rebuild cost of $200.
    Spendy, yes. And I would not recommend it f you're riding mostly buff and manicured trails. But if you ride steep, loose, chunky goodness the coil will make a big difference. I like the 11-6 so much, that I'll likely only buy a frame if Push supports its tuning for the shock.
    Again, my .02. I tend to notice these things a bit more than others, and I like turning the dials until shit feels spot on. So YMMV.
    honda50r, Ccwahoo, neatoneto and 3 others like this.
  2. Nov 2, 2021 at 7:35 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    If I lived close to you or someone I could trust to trail ride with and make adjustments with solid explanations I’d buy one.
    As of now I’m usually a set it and forget it guy.
    abacall[QUOTED] likes this.
  3. Nov 2, 2021 at 8:07 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    depending on the bike, a cascade link could greatly change how the bike feels
  4. Nov 2, 2021 at 9:59 AM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I've actually had multiple friends say that modern carbon bars (designed to flex a bit) took a lot of sting out of their hands on long/rough rides. Funny how different people have such different opinions about bike things.
    I do have a 170mm dropper already and it gets out of the way pretty good, but there's room to fit a 210mm OneUp so I always figured why not!
    The coil thing is so tough! It sounds like you and I have similar riding desires but opposite builds as I'm a 220lb clydesdale. I do believe Ohlins specifically tunes the shock for your bike as well. I'd love to get the 11-6, but that feels like such a huge commitment.
    Maybe I should talk to suspension syndicate, especially since they're local...
    No cascade link for the Rallon. However, Orbea did release their own updated link that does a lot of similar stuff to a cascade link (+10mm travel and increased progressivity). I added it to my bike a year or so ago and it was a fantastic upgrade.
  5. Nov 2, 2021 at 8:38 PM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    If you live in Orange County, think about coming out to this. Cool way to support our local trails!
  6. Nov 3, 2021 at 5:12 AM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    For sure they do, a bit. Kinda like finding the right grip does. But the same $$ can be dumped into a better fork (or tune for it), and that would take more of the sting out and add better trail performance. The biggest change I've had to sore hands is swapping to the ACS3 on the Fox 36. Riding it back to back with the Float 36 (same G2 damper) is eye-opening. Unfortunately, the ACS3 is only available for the 36 and Lyrik.
    Have you considered going to the 38? For your weight and riding style, I'd bet that would make a huge difference. If you put the same $ for carbon bars and sell off your existing fork, you'd get close. Looks like BC has it in stock, and they just released their 20% off...
  7. Nov 3, 2021 at 7:56 AM
    SenatorBlutarsky
    Utah
    I think about a 38 all the time!
    My buddies are actually both on ACS3 Lyriks and one of them has a push 11-6 too. Very swanky bikes!
  8. Nov 3, 2021 at 8:16 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Ok I bought the other one as well. Pretty decent correlation. Same tire. Easily operator, valve, order, time, temperature, angle error of 1 psi.:thumbsup:
  9. Nov 3, 2021 at 8:22 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Nice, glad to see they are both close.
    I'm on a 27.5+ bike, I run 18f/19r or about 18.5r if I'm a little slimmer. I like the low psi gauge.
    I have this gauge for my cars/trucks. I'm a tire pressure snob in everything.
    https://www.amazon.com/Accu-Gage-Professional-Pressure-Protective-Straight/dp/B00GWTAAIA
    Pablo8[QUOTED] likes this.
  10. Nov 3, 2021 at 9:13 AM
    SoCal_Erik
    i have the same gauge. Works great and has lots of positive reviews.
    Pablo8 likes this.
  11. Nov 3, 2021 at 9:34 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    dang... thats low! I'm always worried about mangling a rim with lower tire pressure. I'm usually in the 28 f / 30 r range
    Gunshot-6A[OP] and mrtonyd like this.
  12. Nov 3, 2021 at 9:38 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Oddly I consider the gauge pressure shown there pretty darned hard on my bike - feelwise. Depends on the bike, rims, suspension, weight, style, etc..............fack tire sidewall says 40 psi max. If I went 30 psi, wow!
  13. Nov 3, 2021 at 9:39 AM
    aturk
    Tony
    Charlotte, NC
    It's a 27.5+ bike, normal.
    Gunshot-6A[OP] likes this.
  14. Nov 3, 2021 at 9:54 AM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    hmmm not sure how much you weigh but at 210ish I'd for sure large mammal a wheel set or three. I'm living that wagon wheel life though so wtf do i know...
  15. Nov 3, 2021 at 9:59 AM
    aturk
    Tony
    Charlotte, NC
    220ish with gear. Never even had a rim strike in three years on this wheelset.
    honda50r likes this.
  16. Nov 3, 2021 at 10:00 AM
    aturk
    Tony
    Charlotte, NC
  17. Nov 3, 2021 at 10:08 AM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    ahhhh... yea missed the (+) part... okay that makes more sense... how wide are the tires you running? photos of said bike ?
  18. Nov 3, 2021 at 10:19 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Wait, you guys don't just squeeze the tire and say, "eh, good enough"?
  19. Nov 3, 2021 at 10:22 AM
    mrtonyd
    Tony
    Colorado
    your guy's tires hold air?
  20. Nov 3, 2021 at 10:32 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    you guys have tires?!
