All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 16, 2019 at 4:10 PM
    #8441
    YummmyTaco
    YummmyTaco Active Member
    Jacob
    Calabasas, CA
    2018 Tacoma TRD Off Road
    Could either be air in the lines, or a worn out pad. Need more info...When was the last time pads were replaced, when was the last time they were bled?
    A picture would help too
  2. May 16, 2019 at 4:11 PM
    #8442
    CementTRDOffRoad
    CementTRDOffRoad Well-Known Member
    Cement TRD OR 4x4 DCSB
    pads are cheap and easy! might be brake bleed tho
    Coot83 likes this.
  3. May 16, 2019 at 4:12 PM
    #8443
    YummmyTaco
    Jacob
    Calabasas, CA
    It could even be as simple as even pushing out the pistons to shorten the dead space between the pad and rotor
  4. May 16, 2019 at 4:14 PM
    #8444
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I would bleed your brakes if you got that much play unless you tuned it to be like that. When I first bled my shimano brakes after two years it took about two full bleeds to just get the dirty fluid out of which instantly fixed the grabbing of the brakes. As others said though...get another set of pads if you can tell they are low on material. Deore pads are like 12 bucks I think, but it never hurts to learn how to bleed your stuff.
    CementTRDOffRoad likes this.
  5. May 16, 2019 at 4:20 PM
    #8445
    1Taco2Taco3TacoFloor
    1Taco2Taco3TacoFloor Well-Known Member
    2018 TRD 4x4 Sport
    Thanks for the advice gentlemen! Was only considering new because if you buy new from The Bike Lane in Reston you get free maintenance for life. I’m not opposed to used, but to be honest I don’t know enough to know what to look for. I loved biking in high school back in the day and my moms friend gave me his 3rd or 4th spare bike he built.
    dbbowen2[QUOTED] likes this.
  6. May 16, 2019 at 4:32 PM
    #8446
    CementTRDOffRoad
    speaking of.. i really neeed the cane creek eewings to match the titanium in my leg
    abacall likes this.
  7. May 16, 2019 at 4:42 PM
    #8447
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Thanks for the ideas. I'll definitely change the pads myself, and then take it in for a bleed. I'd love to bleed them myself, but I live in an apt and don't have the space to work on my own bike :(
    I'll probably just do both front and rear, just because I haven't done either in a long time.
    Coot83[QUOTED] likes this.
  8. May 16, 2019 at 5:02 PM
    #8448
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    The Marlin maxes out with a Rockshox spring shock. I think the only real difference between the X-Cal and the Roscoe is that the Ros is a fattie. Same geometry on the frames. So you can basically get the same bike in a 29” wheel and 2.20 tires by getting the X-Cal.
    I was pitting the Marlin vs X-Cal and wound up just going with the X-Cal 8. I steer far and wide away from anything with a Suntour shock. I took the X-Cal because air springs feel WAAAY better than spring shocks. Also the X-Cal wheels are “tubeless ready” (still need rim tape, goop, valve, and tire to convert) whereas I don’t think the Marlins come with TLR (TubeLess Ready) wheels.
    Overall I am happy with the bike. But some faults are the brakes (small rotors with minimal heat dissipation and cheap metallic pads). Brakes fade on almost every downhill I’ve been on. Also the Bontrager tires aren’t really too spectacular. I converted to Maxxis Minion DHF for less than $100
    Chasespeed, paleh0rse and 113tac like this.
  9. May 16, 2019 at 5:04 PM
    #8449
    CementTRDOffRoad
  10. May 16, 2019 at 5:41 PM
    #8450
    machspeed
    machspeed Well-Known Member
    Michigan
    2016 Tacoma TRD Offroad 4x4 Accesscab
    Well the GF Mullet build was a bust for me. Bought a large 19” frame, combined some new and parts I had. I never made it out of the driveway since the geometry was way too small for me, and my knees were in my chest.
    So take two, find a larger frame and swap over. Enter the xl Santa Cruz Superlight. Frame just arrived today and I swapped parts tonight. Prelim ride fits nice but I have so slight tweaks to make.
    And if anyone is looking for a large frame GF Mullet frame or a large Trek Marlin 29er frame, hit me up. I could even throw in the F29 Fox fork for pretty cheap too.
    paleh0rse and dbbowen2 like this.
  11. May 16, 2019 at 6:03 PM
    #8451
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    That’s not a bad deal actually. I just think with the Marlin you will want to upgrade fairy quickly if you stick with mountain biking. It’s not a bad bike though. Trek, specialized, etc. are always safe purchases.
    Chasespeed likes this.
  12. May 16, 2019 at 8:46 PM
    #8452
    dbbowen2
    dbbowen2 Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    Jesus Christ! i thought the XX1 cranks were ridiculous! Oh em gee
    I believe you are correct, the frame is the same between the two. Since my wife is new to mountain biking, I wanted to get her the 2.8 inch tires to give her more confidence and control and a little extra cushion. Eventually Ill get her a Jeffsy or something if she keeps at it and enjoys it! Suntour shocks are a no go for me too. You did super good swapping to the DHF. The DHR2 is my favorite tire!
    That looks like a shit load of fun times right there!
  13. May 16, 2019 at 8:49 PM
    #8453
    dbbowen2
    TN
    too many to list
    Had an epiphany at work today....
    My buddy and I went for a ride after work and after my worktime epiphany. Quick 8 mile loop of singletrack. I got him to stop at mile 6 to get something out of my hydration pack. I ride with an osprey raptor 14 filled with ice water.... I figured out it fits 2 cans of beer inside the bladder perfectly with enough water and ice for a 15 mile ride. Hes talking about his bike and he hears the beer crack and his mind exploded. I tossed him the second one and they werent even really too shaken up. No foam!
    Excellence!
    cowsquatch67 and 113tac like this.
  14. May 16, 2019 at 9:16 PM
    #8454
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Wait, beer cans inside the bladder, or in the pack next to the bladder?
  15. May 16, 2019 at 10:00 PM
    #8455
    dbbowen2
    TN
    too many to list
    Inside the bladder, with a bunch of ice and water. I washed the beer cans first. Freaking evil genius shit haha the beers were ice cold :cheers:
  16. May 16, 2019 at 10:20 PM
    #8456
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    You may have just changed my life. For the better. I will always remember you
    Ccwahoo likes this.
  17. May 16, 2019 at 10:53 PM
    #8457
    dbbowen2
    TN
    too many to list
    HAH! It was honestly the best idea I’ve had i a long time.
  18. May 16, 2019 at 10:56 PM
    #8458
    dbbowen2
    TN
    too many to list
    So I have an order for a full set of skids for my tacoma from RCI that I placed like 3 weeks ago. No word from them yet. Thinking about cancelling my order.
    So with backcountry’s 20% discount. I can get a fox factory 36 fork for $800 shipped.
    My rhythm fork is only 2 or 3 months old and was hoping to sell it for like 200 or 300 bucks.
    In theory, I could get a fox factory fork for $500.
    Is this a dumb idea or genius? I don’t even think I need the skids because I don’t plan on wheelin anytime soon, my 3rd gen is stock as hell.
  19. May 17, 2019 at 4:48 AM
    #8459
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I can relate. I’ve thought about pulling my full CBI overland skids that have only been mounted for about 3 months to put money towards a bike. I’ll likely never need more than stock skid plate protection. I only bought them because I wanted them :notsure:
  20. May 17, 2019 at 5:34 AM
    #8460
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Do it. The 36 factory is miles above the rhythm.
    I just replaced my tires with DHF / DHR2 Exo+ casings, a HuckNorris DH rear insert, added a 203 rear rotor, and new sintered pads.
    Then I did something I shouldn't have done. I weighed it... 33.5 lbs. With 170/165 travel, 1210 wheelbase, low BB, 65* HA.
    Yeah, I was wondering why it was a little slower goin up. lol. Funny thing is, it clears climbs I wasn't able to with shorter travel and lighter rigs. But steep switchbacks require some planning.
    I think people blow a lot of that out of proportion. I'm still comfortable putting in 3+ hour rides with 3500 ft of climbing (so far). But then, coming down, all is well with the world.
