All warning lights on after start, gone with restart..
Discussion in '1st Gen. Tacomas (1995-2004)' started by PLUNKSALOT, Apr 2, 2024.
  1. Apr 2, 2024 at 11:22 AM
    PLUNKSALOT
    PLUNKSALOT [OP] Active Member
    I keep having this random issue of when I start the truck all the dash warning lights come on. I turn the truck off and immediately restart and they go away. Happens maybe 1 in 20 starts. It's very random, truck can be warm, cold, long set period, short set, it's all over the place.
    I tried to pull a code off it last time it happened with the reader but it shows nothing. Any ideas what could be happening?? Thanks.
  2. Apr 2, 2024 at 11:25 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Loose ground?
    PLUNKSALOT[OP] likes this.
  3. Apr 2, 2024 at 11:27 AM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    My old impala did something just like that. It turned out to be a dodgy ignition switch. I'm guessing it was from the systems not getting the right voltages at the right time.
  4. Apr 2, 2024 at 11:31 AM
    PLUNKSALOT
    That would make sense. I do get the occasional bad start and have been questioning the ignition but that's like 1 in 50. The light issue has never shown up on a poor start though.
  5. Apr 2, 2024 at 11:32 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    You've tried just resetting the ecu?
    1st gens, I believe, you just need to pull the ECU fuse under the hood.
  6. Apr 2, 2024 at 11:46 AM
    PLUNKSALOT
    Didn't know that was a thing, will try that tonight. Thanks
    bkhlrTaco's[QUOTED] likes this.
