all warning lights turn on after a simple mod! help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nachocheez, Aug 6, 2011.
  1. Aug 6, 2011 at 1:38 AM
    nachocheez
    nachocheez [OP] Member
    dae
    seoul, KOREA.
    11 TRD Sport
    Hi, after hardwiring radar detector on wires that goes into room mirror, I get this all warning signs. (tire pressure, abs, breaks, slippery signs, check engine and etc)
    Back-up cam is not working,and window is not working either.
    Please don't tell me to go see toyota dealer since there is no toyota dealer where they can fix Tacoma here in Korea :)
    Should I get scan gauge to clear the code? I tried kill the battery for 10min, but still the same.
    thanks in advance.
  2. Aug 6, 2011 at 3:11 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Have you tried removing the radar detector? I think you might have it hooked up to the wrong wires, or shorted out some wires. All the lights on is not the sign of a code. It is a sign there is an electrical problem.
  3. Aug 6, 2011 at 4:00 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Try disconnecting the battery, see if that helps reset.
  4. Aug 6, 2011 at 4:13 AM
    2008taco
    chris
    san diego
    He said he disconnected the battery. Didn't fix it.
  5. Aug 6, 2011 at 4:41 AM
    nachocheez
    dae
    seoul, KOREA.
    11 TRD Sport
    hey folks, thx for the replies, I have figured it out that the fuse #7 was dead. had it replaced, and everything worked just fine!
