All Weather Floor Mat - What floor mats are you using?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2018H, Mar 9, 2024.
  1. Mar 10, 2024 at 10:19 AM
    DesertIceCap
    DesertIceCap Well-Known Member
    Gasoline Forever
    I had the WeatherTechs on my last vehicle...not impressed.
    When I installed them, 3 of the 4 fit perfectly. The only problem was the front passenger mat had a slight bow inward from the center console by where your left foot would be.
    I thought it would work it's way back to a flush fit after some time, but it never did.
    With my truck, I use the OEM mats that came with it and they work well enough for me.
  2. Mar 10, 2024 at 11:44 AM
    Plus20DB
    Plus20DB Member
    The Burgh
    19 Barcelona Red SR5 DCSB
    I went with Husky Xact Countours for mine. I've had Weathertech and both offerings from Husky(Weathertechs in a Mazda CX5, Husky Weather beaters in a Subaru Legacy, and now Xact Contours in my Taco). These are so far my favorite.
    In my experience Husky seems to offer a bit better floor coverage and have stayed in place better, but material on the Weatherbeater models isn't as nice as the Weathertechs. The Xact contours are mostly rigid but still somewhat flexible which seems like it will be resistant to the edges rolling over with age and they lay better along the floor. Husky weather beaters seemed to roll worse than the original Weathertech mats that I had. Weathertech now has a newer mat that is comparable to the Xact contours from Husky, but I have no experience with those. The Xact contours have also been nicer to clean. Just spray them down with Adam's rubber cleaner, hit them with a tire brush and hose off. The others always had a streaky/inconsistant color to them after being cleaned and my OCD always had me trying to find a product that would turn them a consitant dark black and not be slippery.
    Donniet53 and 2018H[OP] like this.
  3. Mar 10, 2024 at 11:50 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    2018H[OP] likes this.
  4. Mar 10, 2024 at 12:38 PM
    2018H
    2018H [OP] Well-Known Member
    Yes, I replaced mine.
  5. Mar 10, 2024 at 12:38 PM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    I use the OEM ones that came with my Tacoma. Easy to rinse off if the vacuum doesn't quite do the job. I have a set of Husky mats in my GX460.
  6. Mar 10, 2024 at 1:19 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    WeatherTech front and rear. Quality isn't as good as the previous set I had in 2012. Current set (purchased in 2021) catches most of it but the fit isn't as good. There are gaps, especially on the drivers door near the foot-rest and kick panel. They are also impossible to get completely clean no matter what I've tried. I've used everything including powdered dishwasher detergent and full-strength liquid cleaners, and with the stiffest scrub brush there is, and when they dry, they still look dirty. No better with the car-wash pressure wand or with my own pressure washer with the scary aggressive nozzle, which blasts everything off of my outside cast cement front stairs and leaves them looking like new. Not so with the floor liners. They look dirty when dry.
    To be fair though, the rear one piece floor-liner did catch an entire travel mug of coffee that got dropped back there behind the driver's seat.
    TacoJoe480 likes this.
  7. Mar 10, 2024 at 1:21 PM
    Plus20DB
    Plus20DB Member
    The Burgh
    What material are these Tuxmats made out of? It looks like they have stitching in them. Is it a type of fabric?
  8. Mar 10, 2024 at 1:23 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Those sure look to be the ticket! I'm using Husky's now, and when prepping before heading out for a known muddy / snowy slop fest, I line all the carpets under the mats with carpet mask. A pain, but carpet still in great shape and clean.
    Will get a set of these when they become available. The lower walled matts just don't protect enough when getting in with mud and snow caked boots, and the door sill area always prone to water / mud damage from melting snow. These look like they take care of those two issues nicely.
    musicisevil likes this.
  9. Mar 10, 2024 at 1:25 PM
    Pentangler
    Pentangler 24 Aces
    2022 DCSB OR 4x4
    Previous Toy's 2021 DCLB OR 2017 DCSB SR5 2006 RAV4
    Went from none, to OEM, to Husky. No regrets.
  10. Mar 10, 2024 at 2:01 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I had original weathertechs on my first gen. As someone else mentioned they were too rigid, almost like a plastic, and would bow away from center console. Never had an issue with them moving though.
    I’ve had the HPs in this truck for 2 years, and they are much more flexible, less prone to curling and have more coverage up the center console. It’s more of a firm rubber than rigid plastic. With the little twisty locks they don’t go anywhere but I’d appreciate the extended coverage the tuxmats offer for the salty snow melt all winter, so I’ll be in the market for them eventually.
    If I had to choose between the two weathertechs again, I’d pick HP all day for less than $20 more.
    This is all just for the fronts. I kept the oem rubber mat in the rear because I never have passengers back there.
    four22[QUOTED] likes this.
  11. Mar 10, 2024 at 2:19 PM
    RyanDCLB
    4/19 DCLBOR
    It seems more like a molded or woven vinyl with the stitching on the edge.
  12. Mar 10, 2024 at 2:41 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    All because of this thread, ruined it for all.
    Plus20DB likes this.
  13. Mar 10, 2024 at 2:54 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    That sucks to hear. Those tuxmats do look good. The one thing I liked about the weather techs when I had them was that you could drop a full drink on them and just pick up the mat and dump it out without any getting inside the vehicle. Not sure those tuxmats would do the same but Im definitely gonna consider them now.
    Right now I have whatever was like $25 at costco. Made by goodyear from recycled tire. Trimmed em to fit, but their definitely just place holders for whatever I decide on next.
  14. Mar 10, 2024 at 3:11 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    replacing with aftermarket because the aftermarket have better coverage.
    double floor mats are part of the problem that created the unintended acceleration drama!
  15. Mar 10, 2024 at 3:18 PM
    #35
    2018H
    They should stack up soon with plenty inventory. Does this fix it?
  16. Mar 10, 2024 at 3:30 PM
    #36
    zonzin
    zonzin Member
    Bob
    2023 Tacoma SR5 SX
    So do the Tuxmats front row fit the access cab?
  17. Mar 10, 2024 at 3:56 PM
    #37
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Even with only 1 layer of floor mats I managed to install it over my gas pedal. Caught it, but not before I started driving.
    Yes you guys can laugh at me and call me names. I deserve it.
    soundman98[QUOTED] likes this.
  18. Mar 10, 2024 at 6:31 PM
    #38
    Donniet53
    Donniet53 Member
    2023 SR5 4x4 Blue crush
    I would have kept the oem ones if they would have added them to my truck.
  19. Mar 10, 2024 at 6:33 PM
    #39
    RyanDCLB
    4/19 DCLBOR
    I have some extra. LMK if you want them.
    Donniet53[QUOTED] likes this.
  20. Mar 10, 2024 at 6:37 PM
    #40
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    They have more coverage and seem more pliable
    four22[QUOTED] and musicisevil like this.
