All you supercharged guys
Discussion in 'Performance and Tuning' started by ghostboy808, Feb 2, 2009.
  1. Feb 2, 2009 at 8:50 PM
    ghostboy808
    ghostboy808 [OP] Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    If any of you have mods like headers and intakes, did you also have to install some sort of piggyback to the ecu or does the ecu keep the afr's in range by itself?
    I was thinking of getting the trd intake but don't want to make the truck run lean. Just wondering about other people's experience with the supercharger and if any of you had problems with it after installing more mods.
  2. Feb 3, 2009 at 2:45 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    The TRD flash is hit and miss. Some of the trucks out there run perfectly with bolt ons, others go from real rich to very lean.
    I am running the APR X-1 as a piggyback, and it is hands down the BEST ecu tuning device available for the 1GR
  3. Feb 3, 2009 at 3:08 PM
    ghostboy808
    Gibson SS, TRD S/C
    I'm looking to pull the trigger on the trd cai but don't want to put something that would have an adverse affect on engine life. That APR is a nice piece of equipment but it looks pretty advanced and seems to be set up mainly for racing?
  4. Feb 4, 2009 at 10:07 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Easiest way to see how the engine is responding to the TRD flash is by getting a wideband AFR setup. Check your air/fuel, throw the TRD CAI on it, and see where its at.
    The X-1 is for all tuning purposes, with keeping the engine safe as the number 1 priority. It comes with a feature called Engine Guardian, which will kick on if the engine senses any danger.
  5. Feb 4, 2009 at 10:38 AM
    ghostboy808
    Gibson SS, TRD S/C
    yeah that X-1 is an impressive piece of work. Must be nice to have all that control over the entire engine. Does it monitor wideband too or do you need to have a separate hookup for that?
    I guess i'll get a wideband and see what mine is before I do anything.
  6. Feb 4, 2009 at 10:44 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    It monitors both WRAF sensors, and you can wire in a Wideband gauge as well to see exactly what the ECU is reading.
