Allenfab’s 2008 5-lug SAS and LS swap
Discussion in '2nd Gen. Builds (2005-2015)' started by allenfab, Jun 19, 2022.
  1. Aug 7, 2023 at 4:42 PM
    #201
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I'm finally gettin somewhere on this radiator. I got the base mounts done and the ends of where I cut off up top capped off. I'm going to connect the upper radiator support first so I can get the hood latch mounted back, then tie in the bottom support and then a vertical support similar to what is there in stock form. Room will be made to accommodate the condenser, and trans cooler, and a power steering cooler.
    As you can see, the driver side radiator mount was a bitch. The steering box location fucked me on this one big time, and in hindsight, I should not have pushed it as far forward as I did. Oh well, the damage is done
  2. Aug 12, 2023 at 11:09 AM
    #202
    allenfab
    Todd
    Lakeland, FL
    Tom Woods SYE in the np241c. Had to pull the planetary so I could tap the vent hole out to 1/8” npt for a new fitting since the factory breather was broken off. Simple install and good quality parts.
  3. Aug 12, 2023 at 12:59 PM
    #203
    hayrider2.0
    hayrider2.0 Over the hill and going down fast!
    Hey You
    2 Centimeters from Hell 200 Miles from Water
    05 & 07 White Reg. Cabs w/ sticks
    05 Magnuson 07 LS Swapped
    Todd,
    May I ask what you are going to do for a center hood latch?
    And what I really like to know is what fans are those?
    We are trying to use two 12” SPAL fans and they are pretty thick! Any advice? Because with the engine within a 1/2” of the firewall on the passenger side and the Vette accessories that hug the block by a extra 1.5” we are still going to have clearance issues with the radiator hose entering the Vette water pump.
    Thank You so much in advance, I really do appreciate all your advice!!
  4. Aug 12, 2023 at 1:37 PM
    #204
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Why not use the original?
  5. Aug 12, 2023 at 3:56 PM
    #205
    hayrider2.0
    Hey You
    Sir,
    From the pictures he has posted he has cut and removed the upper radiator support.
    As for me I can’t use the original fan because there’s no place to attach a fan to the GM LS Vette water pump.
    We may have to run the water / coolant backwards through the OE Mishimoto drop in radiator.
    Coolant runs the opposite direction in LS engines. The thermostat on an LS is a Inlet not an Outlet as it is in my Tacoma.
  6. Aug 12, 2023 at 3:58 PM
    #206
    Pittsy
    AZ
    I’m referring to the hood latch. It’ll have to be in the original spot unless you plan on hood pins.
  7. Aug 12, 2023 at 4:00 PM
    #207
    hayrider2.0
    Hey You
    Sir, that was my first question…
    :hattip:
  8. Aug 13, 2023 at 5:15 AM
    #208
    allenfab
    Todd
    Lakeland, FL
    The factory hood latch will be remounted on the new core support.
    I am running these fans
    https://www.summitracing.com/parts/sum-g4902s
  9. Aug 13, 2023 at 2:19 PM
    #209
    allenfab
    Todd
    Lakeland, FL
    Tcase is back in. I pulled the transmission crossmember and trans mount to finish welding those up. A transmission pan skid will be added at a later date but this will be more than sufficient for now. This allowed me to measure for a rear shaft, set pinion angle, build the traction bar mounts, and get ready to order stuff for the rear regear.
    Wulf, la0d0g, Sociopenguin and 3 others like this.
  10. Aug 13, 2023 at 2:34 PM
    #210
    hayrider2.0
    Hey You
    God I can’t believe a human welded this!! :welder:
    Looks like a machine welded, did you start welding when you were 4 years old? :bowdown:
  11. Aug 19, 2023 at 11:26 AM
    #211
    allenfab
    Todd
    Lakeland, FL
    If anyone needs a Cravenspeed gauge pod, selling mine because it won’t work for my application
    https://www.tacomaworld.com/threads/cravenspeed-gauge-pod-new.809978/
    Added the oil pressure and water temp gauges to the new cluster. I’ll get the tach and speedo info from an ultragauge mounted over the two rivets on the cluster. Should look pretty slick once it’s done and painted/powder coated
    la0d0g, hayrider2.0, Coma 13 and 3 others like this.
  12. Aug 21, 2023 at 10:08 AM
    #212
    hayrider2.0
    Hey You
    Sir,
    With your incredible welding skills would you be interested in a side job of modifying an aluminum Mishimoto radiator? Don’t know yet but we are suspecting it may need modification.
    Thanks for your consideration!
    :spending:
  13. Aug 21, 2023 at 12:17 PM
    #213
    allenfab
    Todd
    Lakeland, FL
    What are you needing to do to it?
  14. Aug 21, 2023 at 12:23 PM
    #214
    hayrider2.0
    Hey You
    I will DM you, Thanks!!
  15. Aug 24, 2023 at 4:59 PM
    #215
    allenfab
    Todd
    Lakeland, FL
    Finally had time to pick up some metal for the core support. I only got about a half day to work on it but pretty happy with how it's turning out. The protruding pieces in the second pic are for the condenser....
    rblalliance, la0d0g, Coma 13 and 5 others like this.
  16. Aug 27, 2023 at 2:06 PM
    #216
    allenfab
    Todd
    Lakeland, FL
    Core support about 85% done, but I'm counting that as a victory. It still needs at least two vertical tie-ins, one directly under the latch and then another (or even three total) that the transmission cooler and power steering cooler will mount to. I am going to wait to do that when I get the coolers so I can mount them and the vertical supports exactly where I want them.
    I ended up moving the radiator about 5/8" further back toward the motor and about 1/2" higher than where I originally had the mounts at. The final condenser location required the move.... which also required me to notch some of the ribbing on the underneath of the hood so the radiator cap would clear. No biggie though....
  17. Aug 30, 2023 at 4:39 PM
    #217
    allenfab
    Todd
    Lakeland, FL
    I went back and forth on what I was going to do with the center console, from building a whole new one from the dash to the back wall, or trying to find something factory that would fit.
    Settling on this.... t-case shifter will be mounted where the factory cup holders were, and then I am building a locking console with spots for cupholders. I have some .090 aluminum left over from some other jobs so that's what I am using. The console will have a latching lid, and two stainless cupholder inserts from Amazon, big enough to fit those big dumb yeti cups....
    The console, instrument cluster, and probably the airbox will be powder coated
  18. Aug 30, 2023 at 5:31 PM
    #218
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Might steel this idea. I've considered using an ammo can before. Kinda want to find center console from a range rover with the built in cooler
    allenfab[QUOTED][OP] likes this.
  19. Aug 30, 2023 at 6:28 PM
    #219
    Pittsy
    AZ
    IDK what to do for my center console lol.
    allenfab[OP] likes this.
  20. Aug 30, 2023 at 7:10 PM
    #220
    allenfab
    Todd
    Lakeland, FL
    Boujee lol
