allenfab's 95 Tacoma build
Discussion in '1st Gen. Builds (1995-2004)' started by allenfab, Oct 23, 2014.
  1. Jun 7, 2015 at 4:29 PM
    #61
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Got a little bit done over the week and this weekend. Next thing is to get the upper link mount for the axle made so I can get that mocked up and cycle the suspension. If everything is good then I can start bracing all the brackets up and welding them in.
    Slashaar likes this.
  2. Jun 7, 2015 at 4:30 PM
    #62
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Holy flock this thing is gonna be sick
  3. Jun 12, 2015 at 4:24 PM
    #63
    allenfab
    Todd
    Lakeland, FL
    updates...
    Slashaar, SWYPER and ajohnson like this.
  4. Jun 13, 2015 at 5:34 PM
    #64
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
  5. Jun 14, 2015 at 8:49 AM
    #65
    allenfab
    Todd
    Lakeland, FL
    Passenger side bracket completed and tacked into place
    Slashaar, Pirhett and The End like this.
  6. Jun 20, 2015 at 6:52 PM
    #66
    allenfab
    Todd
    Lakeland, FL
    Got all the frame brackets welded on, all tube inserts welded, Derale steering cooler installed, Steering lines ran from the pump to the box, and made an attempt to modify the exhaust to clear the upper link. Hopefully it will work, it will be a week or so before I can test clearances again. Also started on the transmission crossmember.
    Picked up what I thought were 12" Sway-a-way 2.0 resi coilovers for $350, but it ends up they are 14"... no complaints about that though
    Slashaar and razerok1 like this.
  7. Jun 21, 2015 at 3:25 PM
    #67
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Looks good buddy. You see that post I tagged you in?
  8. Jun 21, 2015 at 3:54 PM
    #68
    allenfab
    Todd
    Lakeland, FL
    I did. And that reminds me to look at it now that I'm on a computer.
  9. Jun 28, 2015 at 5:01 PM
    #69
    allenfab
    Todd
    Lakeland, FL
    I managed to get quite a bit done this week and weekend. I got the pain in the ass part of the exhaust done. The cat is in the stock location but rotated some, this was about the only option I had. Made a firewall plate for the steering shaft out of some 11 gauge I had which is overkill for that part, but I had it laying around so whatever.
    Fitting the PSC ram was also a bitch, but managed to get that crammed in there as well. I still need to source a sleeve of aluminum so I can limit its travel internally.
    Transmission crossmember is also done, which was also a pain in the ass. I think it will work just fine though.
    I pulled the truck out of the garage to crank it up for the first time in a month and to bleed the steering, check oil pressure, and the new radiator for leaks. Everything worked perfect and I can steer with one finger at idle still with the stock pump.
    One picture is as it sits, and another is with the back jacked up to where it will sit after I get the 63's put in.
  10. Jun 28, 2015 at 10:55 PM
    #70
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Hell yea man. Might be in Lakeland next weekend might try to stop by and check it out.
  11. Jun 29, 2015 at 6:19 AM
    #71
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Very nice dude. What are you planning on for tires?
  12. Jun 29, 2015 at 9:56 AM
    #72
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    when you doing it man? :stirthepot:
  13. Jun 29, 2015 at 2:24 PM
    #73
    allenfab
    Todd
    Lakeland, FL
    Let me know. I should be in town
    Plans are for a 35... Leaning towards the KM2 as of now
  14. Jul 11, 2015 at 8:50 PM
    #74
    allenfab
    Todd
    Lakeland, FL
    Rear springs in
  15. Jul 11, 2015 at 8:58 PM
    #75
    michaelrussell
    Michael
    belleview,FL
    Dat ass dude this thing is sick
  16. Jul 13, 2015 at 4:44 PM
    #76
    allenfab
    Todd
    Lakeland, FL
    checklist is getting shorter
  17. Jul 13, 2015 at 5:15 PM
    #77
    xweslingx
    Wes
    Durham, NC
    damn son!
  18. Jul 13, 2015 at 5:40 PM
    #78
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :thumbsup: coming together nicely. digging the new tars
  19. Jul 13, 2015 at 6:14 PM
    #79
    blt2tuk
    blt2tuk Well-Known Member
    Franklin, North Carolina
    1996 Toyota Tacoma
    Truck looks great! Love all the fab work.
  20. Jul 13, 2015 at 7:29 PM
    #80
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Looking good dude! Plans for front bumper?
