allenfab's 95 Tacoma build
Discussion in '1st Gen. Builds (1995-2004)' started by allenfab, Oct 23, 2014.
  1. Sep 5, 2015 at 7:16 AM
    #101
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    What do you mean ripped?
  2. Sep 5, 2015 at 3:11 PM
    #102
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    The rubber steering shaft seal that I put in the new firewall plate ripped. I imagine that it's the original one, so 20 years and 245k miles on it and it had some dry rot. I need to pick up a new one.
  3. Sep 5, 2015 at 3:54 PM
    #103
    allenfab
    Todd
    Lakeland, FL
    Well I actually got some time to work on it a little bit today. I welded on an exhaust hanger so the exhaust that's there wouldn't bounce around and cause any cracks (still have to run a full exhaust with muffler). I also got my rear shocks mounted. I ended up welding a tube across the frame rails and mounted them both behind the axle. No more bounce while driving, but a little stiff now. But, that is to be expected with such a light bed area and Chevy 63's. I plan on upgrading to radflos in the future to compliment the front end.
    Slashaar likes this.
  4. Sep 14, 2015 at 4:36 PM
    #104
    allenfab
    Todd
    Lakeland, FL
    Started putting together my tool box of parts and tools. Trying my hardest to cram everything I can into my toolbox so it will stay clean and leave some free bed space for my spare tire and cooler.
    I will be buying a Warn winch accessory kit soon to add to what I already have, and a few other tools like a big hammer and a big adjustable spud wrench.
    So far in my ammo can I have...
    2 u-joints (one for driveshaft, one for front axle)
    spare lug nuts, both standard for front axle, and metric for rear
    stock Dana 44 hub
    3 TRE's for the tie-rod. I need to buy 2 spares for the drag link as well
    filler neck for my Jerry can
    more will be added....
    Started on my traction bar as well. It will be the shackle style, built from 1.25" SCH. 80 pipe. Hopefully it will hold up fine, as it will be mounted just slightly below the driveshaft, so it can protect it.
  5. Sep 14, 2015 at 4:56 PM
    #105
    Ritchie
    I'll be watching the fab of the traction bar.
    Need one real bad. Thought about BudBuilt but they have not returned my call.
    Good luck.
  6. Sep 14, 2015 at 5:46 PM
    #106
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    awesome truck, keep up the good work!
  7. Sep 16, 2015 at 3:52 PM
    #107
    allenfab
    Todd
    Lakeland, FL
    A little progress....
    Slashaar, SWYPER and doyouevenprerun like this.
  8. Sep 16, 2015 at 4:09 PM
    #108
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Nice jack stand
  9. Sep 17, 2015 at 5:19 PM
    #109
    Ritchie
    Excellent job. You gonna sells these?
    Question, will it fit a regular cab short bed or is it too long? And yeah, I have a regular cab short bed... same question I asked Bud Built only they never got back to me.
    Thanks.
  10. Sep 17, 2015 at 5:33 PM
    #110
    allenfab
    Todd
    Lakeland, FL
    My truck is a regular cab short bed, so it would definitely fit.
    I could potentially make a clone of this one to sell. Fitment may vary though based on amount of lift, and where your shocks are located.
  11. Sep 17, 2015 at 5:43 PM
    #111
    Stubbs07Tacoma
    Stubbs07Tacoma Toyota Veteran
    Blake
    EXPO in the making All Pro Expo Leafs PelfreyBilt front bumper full hoops 20 Inch led bar in bumper AVEC pods for fogs Warn 9500 Front suspension currently being redone
    shes a beaut! Makes me miss my 95
  12. Sep 18, 2015 at 4:15 AM
    #112
    Ritchie
    Nice to hear.
    My shocks are in the stock location but I did the u-bolt flip and welded tabs to the housing for the shocks.
    Looking at your pics, I could slide it towards the 3rd for more shock clearance.
    Your thoughts?
    Also, is the front going utilize a Heim joint?
    Thanks.
  13. Sep 18, 2015 at 4:56 AM
    #113
    Poofyfoot
    Poofyfoot Well-Known Member
    Jordan
    Logan, Ohio
    89' Pickup and 2013 AC Sport
    Dude this build is awesome! Great work!
    Was there any science behind the way you mounted your rear shocks? I see a lot of guys go almost vertical with them, it's nice to see someone do something different.
  14. Sep 18, 2015 at 10:14 AM
    #114
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Hey Todd, I know you might have mentioned it somewhere, but I'm too lazy to search the whole thread to find it, but did you do anything with your oil pan?
  15. Sep 18, 2015 at 10:17 AM
    #115
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :p
    allenfab[QUOTED][OP] likes this.
  16. Sep 18, 2015 at 11:20 AM
    #116
    Taco No Baka
    Lee
    Tampa, FL
  17. Sep 18, 2015 at 2:27 PM
    #117
    allenfab
    Todd
    Lakeland, FL
    Could definitely slide it over, as long as the exhaust isn't in the way. And yes on the heim joint, the traction bar itself will be attached to the heim, and then the poly end of the shackle will be attached to the frame.
    Main reason for them being mounted the way they are is because of the lack of space. Knowing I had a traction bar and exhaust to be built made the only feasible mounting position on the back of the axle.
    Went with the trail-gear oil pan swap kit. It's just a new rear sump pan (2wd T-100 pan maybe) with the matching oil pickup tube.
  18. Sep 18, 2015 at 7:46 PM
    #118
    Taco No Baka
    Lee
    Tampa, FL
    @allenfab Cool, thanks. That sounds pretty painless.
  19. Sep 19, 2015 at 5:12 AM
    #119
    Ritchie
    Cool on the traction bar... I'll take one after you've tested yours. Let me know.
    I hate to say it but, I ordered my oil pan kit from YotaMasters and received the TG pan kit. Haven't installed it yet though.
    Here is a pic of the Diamond axle w/ 5.29's and ARB locker:
    Slashaar, DJB1 and SWYPER like this.
  20. Sep 19, 2015 at 6:53 AM
    #120
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Nice! Wanting diamond housings for my fj60 and fj80 axles
