allignment still not right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DARK TRD, Mar 11, 2010.
  1. Mar 11, 2010 at 6:28 PM
    DARK TRD
    DARK TRD [OP] Well-Known Member
    Bartlett,IL
    All Black TRD Sport
    ez lift 3inch plus 1 inch block custom flat black trd black stickers same style as stock black badges from toyota black headlights tinted windows satoshi grille with grillcraft grill vinyl tinted tail lights
    I have a 3in ez lift 2in aal and one inch block on stock set up and sears can not get my wheel plumb the pass side looks like its on a angle bottom in top out
  2. Mar 11, 2010 at 6:34 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    need new aftermarket upper control arms to get the alignment back into spec. if non-offroading, the Light Racing ones are under $400 and do the job.
    anything over 2.5" of lift starts getting the alignment past the point of no return and needs UCAs to fix it
  3. Mar 11, 2010 at 6:45 PM
    DARK TRD
    Bartlett,IL
    All Black TRD Sport
    thats it can i put them in myself
  4. Mar 11, 2010 at 7:41 PM
    jhodge83
    SC
    17 XLT Sport
    yeah...the long bolt is a bitch to get out. need to bend back the inner fender to remove it, reinstall, then bend back down
  5. Mar 11, 2010 at 7:54 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    so if i have a Fabtech 6" lift, i can use the TC UCA's to fix my alignment?
  6. Mar 11, 2010 at 7:57 PM
    jhodge83
    SC
    17 XLT Sport
    i thought the DB lifts kept everything into spec? if thats not the case, then yes...aftermarket UCAs will work for the alignment
