Allpro Aluminum Bumpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicktoria, Nov 3, 2015.
  1. Nov 3, 2015 at 3:17 PM
    nicktoria
    nicktoria [OP] Member
    Nick
    Iqaluit
    Allpro Front & Rear Bumpers just installed, waiting on Warn Winch M8000-SynRope & Fog Lights.
    Also Frontrunner SlimLine 2 w/LED Bar, needs to be relocated under the rack (confusion during install)
    Front LED Bar is the E2 Hyperspot combo. Fog Lights to be installed are PIAA 3.5 LEDLP530's.
    Next: Icon Suspension / Skid-plates / CB Setup / Rear Rack / OBA
  2. Nov 3, 2015 at 3:28 PM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
  3. Nov 3, 2015 at 3:30 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    OMG that APEX is sooo sexy..
  4. Nov 3, 2015 at 3:35 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    nice bumpers man, looks sweet,how much weight.
  5. Nov 3, 2015 at 3:39 PM
    nicktoria
    Nick
    Iqaluit
    Considerably less than the Steel ones due to the Aluminum characteristics.
  6. Nov 3, 2015 at 5:15 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Those are some nice looking bumpers. I wonder how they will hold up to road salt.
  7. Nov 3, 2015 at 6:56 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Better than steel.
  8. Nov 3, 2015 at 7:11 PM
    Pigpen
    Dan
    Northwest Montana
    You must not be concerned, but won't you have to take the bumper off to install your winch?
  9. Nov 4, 2015 at 6:13 AM
    nicktoria
    Nick
    Iqaluit
    Not overly concerned. It might actually squeeze in place. Either way, I don't have the truck right now as it is at the installers. So they'll be the ones putting the winch on.
    Pigpen likes this.
  10. Nov 4, 2015 at 6:17 AM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    Looks good! You're going to need some sliders too, the steps won't cut it once you have the entire rest of the truck armored to the teeth.
    Lord Helmet likes this.
  11. Nov 4, 2015 at 7:00 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    DCLBFTMFW :thumbsup:
  12. Nov 4, 2015 at 7:38 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Nice, quick question are you running a lift currently in those pictures or just a larger tire? I was curious to see how going to a new bumper would look on a stock set up
  13. Nov 4, 2015 at 7:39 AM
    Large
    Large Red
    Looks nice .. why all the armor with nerf bars
  14. Nov 4, 2015 at 7:42 AM
    Pigpen
    Dan
    Northwest Montana
    I'm sure it's a matter of allocating funds. Give a guy a break. He adds bad ass aluminum bumpers and a winch, but you bust his balls about his steps?
  15. Nov 5, 2015 at 7:59 AM
    nicktoria
    Nick
    Iqaluit
    Just Dandee,
    I bought the truck second hand w/ 16,000km's. I believe there s a bit of a lift, as when it stands next to a stock Tacoma it sits a little higher. The tires a temporary Bridgestone 265/75/16 winter treads. There does seem to be some rubbing on the body when cutting hard in either direction, which makes me wonder how much lift there is considering the tire size.
    Putting together an order for an ICON Stage 6 or 7 Setup, with new tires.
    Large,
    Relax. I dont even live in the same area as my truck. It is kept in storage, and I order and install parts when I am in the area. I appreciate your concern, and no I have not forgotten about the rock sliders as they will be ordered in conjunction with the skid plates. I live in Canada, so ordering things can be a bit of a challenge at times.
    Next is CB Radio / Winch hook up, ICON's, Rock Lights, Skids.
    Readjusted lights, and relocated Block heater on the grill.
