AllPro Expedition Leaf Spring install...
Discussion in 'All-Pro Off Road' started by MonkeyProof, Jan 7, 2011.
  1. Aug 15, 2011 at 10:47 AM
    #61
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    my 35's will tuck in there nicely :)
  2. Aug 15, 2011 at 10:53 AM
    #62
    PLC721
    Patrick
    Chandler, Az
    well sell your 33's and get them! i saw in your build you picked some up i thought?
  3. Aug 15, 2011 at 10:53 AM
    #63
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    :cool:
  4. Aug 16, 2011 at 9:32 PM
    #64
    cotruckin
    cotruckin Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    I got mine on today, definitely takes the bumps way better. The rear does sit pretty high even with the topper on, need to get more gear to carry in the bed. Hopefully once they settle a little and I get my ATO rear bumper (hoping I can order soon) it will sit just right. Now I just need to save up for rear shocks, I can tell the 5100's are going to limit the flex. Besides super expensive resi's what do you guys recommend? I saw the Walker Evans, was also thinking the 5125's. Pictures tomorrow, it is dark out now.
  5. Nov 5, 2012 at 10:13 PM
    #65
    kimber45
    kimber45 Active Member
    jay
    ohio
    2012 db cab trd
    Interior -leds-weatherteach floor mats-chrome vents-20%tinited window-exterior-3" pro comp pro runner strutsin front/shocks rear-1"block-weather tech window gaurds-black grill craft mesh grill- hids headlights/fogs -airaid cold air intake/ doug thorley y pipes/banks ss monster cat bak exhaust-polished running boards!
    Im getting the expos end of this month ! how does it ride with bed empty ? i talked to allpro and they recommended that u atleast put some kinda weight in bed .like sand bags if ur not carrying any loads . and did u hav any shakin or vibrations after install? or did u use any angle shims or cb drop kit? didnt c any in pik!
  6. Apr 3, 2013 at 11:48 AM
    #66
    Spitfire
    Spitfire Well-Known Member
    AZ West Valley
    05 TRD Taco
    OME Lift, Stubbs Sliders, Truxedo cover, Pioneer Avic deck, speakers/amp etc., Black badges.
    Bump it up- Mine are enroute. DSM was able to spec me a pair of Icon remote res rears for these leafs.
    For the record I read on exportal that these leafs were 17" collapsed and 26" extended, so the shock needs to have 27" of extension.
    ready6delta likes this.
  7. Apr 3, 2013 at 11:57 AM
    #67
    Slodgetto
    Slodgetto Über Posre
    Silas
    You mean 9" travel? It's extended minus collapsed equals travel. I would go with 9.5" or 10" and adjust the bump-stops accordingly to be on the safe side. Especially since you 2nd gens typically have the shocks mounted outside the springs. (Meaning they'll travel a tad more than the springs during articulation.)
  8. Apr 3, 2013 at 12:18 PM
    #68
    Spitfire
    AZ West Valley
    05 TRD Taco
    Right, so they need to have 9.5-10" of travel if you want the leafs to be the limiting factor. Those numbers are the actual shock lengths when collapsed and extended.
    Edit- What up ABQ? I bought my truck at Karl Malone Toyota when I lived out there! Popped her cherry at the Puerco!
  9. Apr 3, 2013 at 2:35 PM
    #69
    Slodgetto
    Silas
    Yup..
    haha Nice, man! Borque is still kickin. :) Everybody loves the Puerco. I'm down there almost every week, and there are always a lot of people. :cool:
  10. May 6, 2013 at 9:55 PM
    #70
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
  11. Nov 21, 2013 at 6:27 PM
    #71
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    So with no weight in my bed and these springs on I have a vibration when I start off and till I hit about 30. Any ideas what it could be and or how to fix it?
  12. Nov 21, 2013 at 9:31 PM
    #72
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I would hazard a guess that you've altered the geometry of drive line system, specifically the angle of the rear axle. My understanding is that it should be like this.
    Also, I'm no expert and if it were me I'd create a separate thread about your issue, you may be better served that way. Good luck!
  13. Jan 19, 2014 at 9:58 PM
    #73
    mandzach
    mandzach Well-Known Member
    When measuring the travel of the rear suspension, you should also measure the additional droop that the shackle provides.
    I'm pulling 11" of travel (65% is down travel) with these springs, BAMF shock relocation kit and 12" 2.5 Kings.
  14. Feb 27, 2014 at 7:00 PM
    #74
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    I got bad vibes after these install what degree shims do i need??
    Thanks
  15. Mar 11, 2014 at 9:07 PM
    #75
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    So if I get this set of expos on my 06 can I put air bags to tow my travel trailer . And still be able to off road and get my flex on . Or will I get less flex with the air bags
  16. Mar 12, 2014 at 7:05 AM
    #76
    mandzach
    The all pro expos excel at droop or down travel.
    Ever see what happens to an air bag when spring down traval exceeds the bags operational range?
    It's kinda ugly, rips the bag.
    If your planning on towing with heavy tongue weight, look at Dakar leaf set. But if your tongue weight is resonable then AllPro expos will do fine.
    Bags and off-road flex do not mix. Only option for that is those bags that connect at one side and slam on a strike plate on the other side. Those don't do well when debris gets on the strike pad.
    TacoPandaTRD likes this.
  17. Mar 24, 2014 at 8:35 PM
    #77
    Toyotamudbogs
    Devin
    White Springs , FL
    10-4 I won't do the air bags then. So every one is putting 9.5 to 10" shocks on there leaf packs right. ?
  18. Mar 29, 2014 at 5:53 PM
    #78
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    MoneyProof Thanks for the write-up.. I used it as a reference when I installed them today. I also did it by myself. :eek: never done that before but I had Ben (Benson X) check my work.. rep'd
    The springs are awesome!
    Before 2'' Block
    All pro expo's
    Ben and I
    TacoPandaTRD and GHammer like this.
  19. Mar 29, 2014 at 6:36 PM
    #79
    MonkeyProof
    SoCal- SGV
  20. Sep 28, 2015 at 10:56 PM
    #80
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
