ALLPRO VS ARB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nperry03, Mar 1, 2011.
  1. Mar 5, 2011 at 4:15 AM
    #61
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Allpro = form over function
    ARB = function over form
    Relentless = form and function
    I chose Relentless cuz I like things to work like they should and look good doing it.
    Lumberjackcoma likes this.
  2. Mar 5, 2011 at 4:17 AM
    #62
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Does anyone know if the all pro has cut outs for a hi-lift?
    I know my ARB does, they work awesome too.
  3. Mar 5, 2011 at 6:07 AM
    #63
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ^^AP does not have cutouts. They depend on using the shackle to lift the front.
  4. Mar 5, 2011 at 8:35 AM
    #64
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Very well put. I've owned both versions of the AP front bumper. The 'greatly improved approach angle' stuff is BS. I have posted pictures side by side of the old one on my truck and the new on my truck (same day, same angle, etc) and the approach angle is only slightly better, but nothing to really brag about. I'm afraid to mount a winch to my AP, for fear that I'll hurt the bumper if/when I have to use the winch... SERIOUSLY.
    I'd look into something more beefy if you are going off roading and want a bumper that offers more than 'looks' and 'clearance'. Just my 2 cents.
    I'm thinking relentless front and ATO rear FTW!!!
    Serious offer, I'll trade my relatively new AP with no damage and no rust for someone's relentless and I'll throw in cash and help with the removal and install.
  5. Mar 5, 2011 at 9:39 AM
    #65
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    I have none of the three bumpers but if you take a lesson from the real rock crawlers aka jeeps, you find the move is most definitely away from big heavy run into anything bumpers. In fact bumpers skids and sliders are now being made in aluminum which if designed correctly and of the right grade will perform as well or better than steel.
    Weight hinders performance, both on and off-road. That is just fact and it doesn't matter what kind of offroading you do weight is the enemy. The more weight you slap on the vehicle the more negative the impact to performance. Suspension suffers, the engine and drive train suffer and of course gas mileage suffers.
    Additionally bumpers are designed (or should be) to absorb the force of an impact and in doing so they will and should deform depending on the hit they take. Force doesn’t just disappear it has to go someplace and if you hit something hard with a big giant bulletproof bumper that force is obviously transmitted to your frame and surrounding components. Now depending on the hit both the bumper and the frame will survive no harm no foul but a big enough hit will damage the frame if some of that force is not dissipated by the bumper as it should be.
    You have only to look at the stock bumpers on your vehicles (any vehicles) to see that manufacturers are not bolting big steel monstrosities on them and it’s for all the reasons above.
    Now as was pointed out before, if you want to run your truck into trees and boulders and don’t want to damage your bumper and you don’t care about maximizing performance or damaging the rest of your vehicle then a big heavy steel bumper is for you! But in reality you need to find the best mix of protection and durability at the lowest weight. I like the relentless bumper in aluminum myself but that is based strictly on my opinion of what a good bumper should be as I have never seen it in person or used it.
    I have used metalcloak bumpers on my jeep made from a mix of both aluminum and steel. Basically the shell was aluminum with steel end caps which worked great. I foresee a big push towards aluminum in the Tacoma aftermarket world as the word gets out so keep an eye out on the websites of your favorite manufacturers and I will bet more and more aluminum products are going to be cropping up.
  6. Mar 5, 2011 at 9:57 AM
    #66
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    The Relentless Fab bumper IS available in aluminum , I have one .
  7. Mar 5, 2011 at 9:58 AM
    #67
    The_Hodge
    SC
    yup...QFT!!
    i'll trade the same, but i have one of the shittily powdercoated AP ones that is peeling anywhere there is an edge. no one has taken my up so far:D
  8. Mar 5, 2011 at 10:38 AM
    #68
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    The allpro handles winching just fine. Ive had to be pulled and had to pull at pretty extreme angles and it did just fine.
    Allpro has good approach angles too.
    If you already have a bumper I have no idea why you would get a new one especially since you havent even been wheeling where you need a winch?! I dont get why you need a new bumper.
    Its your money though.
  9. Mar 5, 2011 at 3:06 PM
    #69
    DrRabbitFurHead
    Salem, VA
    I've only been on light to moderate trails. Nothing serious as I don't allow myself to get in situations that I can't get out of w/o a winch. This truck is my DD until I pick up something "more fun" ;)
    Glad to hear the AP holds up to winching. Maybe I'll spring for something very soon.
  10. Mar 5, 2011 at 6:56 PM
    #70
    mandzach
    mandzach Well-Known Member
    I call BS.
    I have winched with two different AP, original plate version and the new version. I also drove my truck into the back of an 08 BMW (Cali Female Driver - Don't Ask) and nothing on my truck was damaged except the $22.00 headlight support.
    Lrgrnr - what does your truck currently have on it for a front bumper?
  11. Mar 6, 2011 at 5:38 AM
    #71
    DrRabbitFurHead
    Salem, VA
    I hear the new stickers have better ass clearance. :D
  12. Mar 6, 2011 at 4:43 PM
    #72
    The_Hodge
    SC
    At least the new sliders have gussets. My original AP sliders bend like mjp2s sexuality...lol
  13. Mar 6, 2011 at 4:49 PM
    #73
    jandrews
    '09 FourDubDee TRD OR
    We gotta get you some ATO man. I hear he makes some pretty good armor.
  14. Mar 6, 2011 at 4:54 PM
    #74
    The_Hodge
    SC
    Your sig keeps getting better and better...lol
  15. Mar 6, 2011 at 4:58 PM
    #75
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Does the ATO skids work with the all-pro front bumper? If not I'm going to ditch this bumper and put the stock on (too much work trying to straighten this one out).
  16. Mar 6, 2011 at 5:00 PM
    #76
    The_Hodge
    SC
    Unfortunately yes...would have given me more of a reason to upgrade sooner...lol
  17. Mar 6, 2011 at 5:03 PM
    #77
    S.B.
    Sean
    San Diego
    15 Taco
    Good, I might be getting one for my birthday!
  18. Mar 6, 2011 at 5:07 PM
    #78
    jandrews
    ATO is straight bolt on, yes, works fine with aftermarket bumpers.
  19. Mar 6, 2011 at 5:09 PM
    #79
    S.B.
    Sean
    San Diego
    15 Taco
    Ok, I asked because the budbuilts need some modification and was wondering if ATO's did.
  20. Mar 6, 2011 at 6:00 PM
    #80
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I love my ARB, but I will admit to missing some shackle mounts!
