almost a disaster
Discussion in '1st Gen. Tacomas (1995-2004)' started by carolinaTRD, Dec 24, 2010.
  1. Dec 24, 2010 at 7:59 AM
    carolinaTRD
    carolinaTRD [OP] Well-Known Member
    Evan
    Ft. Bragg, NC
    03 double cab TRD debaged
    nothing....yet
    so i drove my truck from nc to el paso, tx. 1800 miles and it ran like a dream. well me not thinking i didn't check the oil level regularly. a week and a half after i arrived in el paso i hear my engine making a funny noise. so i pop the hood and after some investigating i notice i had the most microscopic of drops of oil on my dip stick. almost ruined my engine. QUICKLY went to the store and got some oil for her. i would've have cried if my engine seized up.
  2. Dec 24, 2010 at 8:02 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    I always ALWAYS check my fluids every fill up.
    And I check my tire psi once a month twice if on a trip.
    Like every other fill up Ill check tire psi
  3. Dec 24, 2010 at 8:05 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    got to keep a eye on that stuff man, make it a habit to check everything every time you stop, oil, antifreeze, brake fluid and power steering fluid.
  4. Dec 24, 2010 at 8:09 AM
    cc350
    cc350 Retired Member
    First thing to do before and after a trip, is CHECK ALL FLUIDS! Good way to stretch the legs and wake up after driving awhile is to CHECK ALL FLUIDS. :)
  5. Dec 24, 2010 at 10:41 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    OP, I live in El Paso, TX. If you need anything, feel free to ask, bud.
  6. Dec 24, 2010 at 10:53 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    ^ thats why I love TW, guys and gals always there to lend a hand!
  7. Dec 24, 2010 at 11:27 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I check my oil level on occassion, once you are familar with your truck and know its habits check it as needed, unless you off road and take a chance on punctureing the oil pan.
  8. Dec 24, 2010 at 1:38 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Gotta check those fluids at least twice a week or before any major trip! Im glad my truck doesnt burn one drop of oil or antifreze. Fluids are always topped out and I never have to add any. :D
  9. Dec 24, 2010 at 1:54 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    It's great you caught it before something bad happened. You better look into why it happened though...that's a lot of oil to lose. Are you sure the correct amount was added at the last oil change and how many miles was on it from the last change?
  10. Dec 24, 2010 at 2:17 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    No oil dummy light in your truck?
  11. Dec 24, 2010 at 3:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Curious how many quarts of oil you had to add to bring it up to the full mark? If there was little to no oil on the dipstick, it had to be at least a couple of quarts low. That's quite a bit for only an 1800 mile trip to cause.
    Any indications of oil drips from being parked overnite?
  12. Jan 8, 2011 at 10:20 AM
    carolinaTRD
    Evan
    Ft. Bragg, NC
    nothing....yet
    yeah there is i guess the bulb is burnt out or something got to check into that
  13. Jan 8, 2011 at 10:21 AM
    carolinaTRD
    Evan
    Ft. Bragg, NC
    nothing....yet
    thanks man. is there a group of tacoma guys here that go up to red sands??
