Almost at 36,000! Yikes!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Delrivpilot, Aug 17, 2009.
  1. Aug 17, 2009 at 5:44 AM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    Good morning All. I am at 35,000 miles on my 06. My warranty is almost up. Has anyone ever sent their rig to a third party mechanic to check things out just in case there was something that could be covered under the warranty? Also, anyone notice any major probs after they turned 36,0000? Just curious
  2. Aug 17, 2009 at 5:57 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I know the feeling... I've had my truck a few days shy of one year, and over 24,000.... lol
  3. Aug 17, 2009 at 6:00 AM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    I'm only 17800 on my 06, but the 3 years is up next month. I hope nothing goes wrong after September.
  4. Aug 17, 2009 at 6:10 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    You still have powertrain warranty after the full factory expires.
    Drive on.. :burnrubber:
  5. Aug 17, 2009 at 6:12 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    My 2006 is about 1000 shy of the 36k mark & I plan on a dealer visit to fix the air intake rattle again & the fuel filler door before it snaps off. My bottom hinge is hosed & the dealer won't cover after 3/36 so I hear. Nothing major.
  6. Aug 17, 2009 at 6:24 AM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    I have 32K on my 06, , considering the number of people that I have talked to, one guy has a 06 with 60K on it and he just does regular maint.
    Perhaps the best way to check things is to take it to a trusted mech along with the owners manual and have him look at the 30-36K maint spec's and go from there.
    If its a normal truck I doubt if you will see any major problems. Of course off road work it tougher on any vehicle.
    Jeff 06, V6, SR5, 6spd, Radiant Red.
  7. Aug 17, 2009 at 6:29 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    My 08' has over 52,000 on it. Trucks been sound except for a heater blower motor, power steering pump, and rear spring tsb. Just keep changing your oil and greasing your u-joints and it should run with 0 problems until 100K.
  8. Aug 17, 2009 at 6:32 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Yeah Jeff, good advice. Truck has been solid so far.(Knocking on wood) I'm guessing the honest folks as Toyota would benefit more from holding back from telling you if something major was about to go wrong, right before the warranty expires. I know that sounds bad, but can't help it!!
  9. Aug 17, 2009 at 6:35 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    A Okay after 130k+
  10. Aug 17, 2009 at 6:38 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    right about 36500 the engine will blow, which is normal for these trucks...
    im at 125k and still going strong. i bought it used at 84k, so luckily the previous owner had the responsibility of replacing the engine. other than that, i just changed the tranny fluids at 100k and do regular maintenance...all is well...
  11. Aug 17, 2009 at 7:12 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Funny Yosh! I'm not nervous about it going over 36k, just curious if anyone had taken it in for a final look over before warranty expiring. I know Toyotas r solid.
  12. Aug 17, 2009 at 10:26 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I'm now at 36,2xx. I passed 36k last week
  13. Aug 17, 2009 at 11:56 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i thought so too!
    the only thing i can think of is to get all the TSBs taken care of if you wish (leafs, tailgate, misc engine ones). also, there were some guys complaining of failed rear ends on the 05s, but im sure they have that straightened out by now.
  14. Aug 17, 2009 at 12:03 PM
    Jeff
    Hopkinton,MA
    Might drop by my local dealer in the next few hundred miles and ask them what the cost is for the 36K check up. Probably should look into any TSB's that are in effect, too. Good thoughts yosh2000, lets go easy on the engine replacement jokes. LOL
    Jeff 06, V6, 6spd SR5, Radiant Red.
  15. Aug 17, 2009 at 12:09 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    make sure you know what is involved in the 36k checkup, from what i recal those things are a complete ripoff. all the stuff they do you can do yourself.
    and engine jokes on toyotas can never be taken seriously...i have 120k on my current taco, and i had almost that much on my previous...these things last...:D
  16. Aug 17, 2009 at 12:10 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i think it is 7/100k. they are just under 1k from a guy here correct? might be something to look into, as long as you know all the terms. make sure you know what the deductible is..
  17. Aug 17, 2009 at 12:56 PM
    jonny
    jonny Betty White Edition Heep ZJ
    bought the extended when i was signing papers.
    wish i knew about troy's hook up.
    o well.
    20k and runin strong :D
  18. Aug 17, 2009 at 6:07 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    yeah I did thru Troy a couple of months ago
    Platinum 7yr/100k w/ 0 ded cost $880 for the 4x4
  19. Aug 17, 2009 at 6:28 PM
    Bandit
    Bandit Well-Known Member
    North Charleston, SC
    2007 Tundra CrewMax 4x4
    Leveling kit, 295/75r18 nittos, banks exhaust
    im rollin over 98k miles on my 05... new front wheel bearing and thats it. i drive 140- 250 miles a work day. truck runs perfectly!! just put new brake pads on... still had almost 20% left too. original pads! Put 40k miles on it since October 22 last year.
  20. Aug 17, 2009 at 7:30 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Do I have to go to the dealer to find out info on the 7/100k warranty? Where I bought my truck from the dealer gives a liftime powertrain warranty, is it similar to that?
