Almost burned down my truck this morning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigMacMcCoy, Oct 23, 2017.
  1. Oct 23, 2017 at 7:58 AM
    BigMacMcCoy
    BigMacMcCoy [OP] Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Alternate title: Why everyone should have a fire extinguisher in their truck!
    Got to work this morning and noticed some weird feedback coming from my subwoofer. Popping noises that seemed like interference. Figured some recent wiring had caused that, told myself I'd take a look at it later this week.
    Jumped out of the truck and noticed smoke coming up from under my hood. Reached in to pop the hood, thinking I would disconnect the batteries. I had multiple breakers and fuses for everything, so I wasn't too worried. The truck itself was insulated from any of my aftermarket accessories.
    Open the hood and immediately see flames down by the drivers side exhaust pipe right behind the drivers side tire. I reach in and grab my fire extinguisher and crouch down by the tire and stay it down good. I hit it from the engine bay direction as well. Fire extinguisher spent, I decided to sit there for a few and hope it didn't spark back up again. I also disconnected both batteries.
    After it all cooled down I took a closer look and noticed that it was the power cable for my amplifier, more specifically the plastic fuse enclosure on it that had melted. I disconnected that from the battery and pulled it out.
    I sat there for a while, worried about the truck. Eventually I worked up the courage to start the truck and drive it around the lot to park it somewhere not coated in white powder so I could crawl underneath and take a look. Truck started just fine and drove fine. Parked it a ways away from everyone else and crawled under. Moved the other side of the amp power cable up and secured it. Felt and looked around for fire damage but I couldn't see any. I found a melted zip tie in the original spot, so my guess is the heat from the exhaust melted the tie and the amp wire swung free and melted to the exhaust pipe.
    Looks like the fire started after I parked (Thank God!) and only lasted for a few seconds before I put it out. Another wiring loom right next to it didn't even melt, so it was fairly contained. I'll crawl under the truck this evening and do a more thorough inspection. Maybe even bring it by the shop to get them to jack it off the floor so I can see better.
    Takeaways:
    1. Your wire runs can't be too secure. More tiptoes = less chance for failure.
    2. Keep everything a healthy distance from the exhaust pipes. I thought I had done this.
    3. Instead of using the precut wires from the kit, cut your own. The fuse should have been much closer to the battery.
    4. Always keep a fire extinguisher in your vehicle. If not for yourself, for someone else!
    Feel free to berate me for what I did wrong. I want to use this as a learning experience.
    10 hours later update:
    Boss let me leave early so I swung by my neighborhood shop and asked them if they could throw it up on a lift so I could get a clear picture of any damage. They were more that happy to. They also rinsed off all the powder, and I scrubbed the areas on the frame it hit. I've got a can of Fluid Film on the way so I can touch up those spots.
    When we got the dripping truck up on the left and took a look we could clearly see where the fire happened, but luckily there wasn't any brake lines, factory wire runs, fuel lines or anything else in the area. No signs of damage, hard to see the scorch marks since everything down there is black anyways.
    So I took advantage of the lift and went through all my wire runs, securing them all with a ton of zip ties. Scraped off the plastic residue from the cat and hosed everything down again.
    On the way home I stopped at the hardware store and picked up a 2.5lb ABC fire extinguisher and a 2.5lb BC fire extinguisher. I'll pick up another of the 1lb tiny ones like I had this morning when they are back in stock.
    I've ordered new cable, a 60amp breaker, and fluid film from Amazon. Should get here Wednesday. Until then the Aux battery will remain disconnected with all accessories turned off. I'll spend time this week or this weekend making sure everything is secure so that this doesn't happen again.
    I hope everyone has learned from my mistakes with wiring, and I really hope everyone will pick up a fire extinguisher for all of their vehicles! It saved my truck this morning, and it may save yours or someone else's!
    I'll update one more time once I've gotten everything hooked up and working again!
  2. Oct 23, 2017 at 7:59 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    :eek:
    Be careful and change the routing of your cable. You can bring it into your cab through the firewall.
    Glad you didn't lose your truck!
  3. Oct 23, 2017 at 8:07 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Thanks!
    Not a bad idea! Mine ran along the frame rail and up into the rear of the cab through a grommet.
    ManBeast likes this.
  4. Oct 23, 2017 at 8:12 AM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Hose off the fire extinguisher dry chemical on your truck, its corrosive.
  5. Oct 23, 2017 at 8:13 AM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Wow. Good write up and heads up, thanks.
  6. Oct 23, 2017 at 8:14 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Thanks for the heads up! the frame is fluid filmed so I'll have to go to the pay and spray and gently hose things off.
    Steves104x4 and DrFunker like this.
  7. Oct 23, 2017 at 8:14 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Thanks! Just trying to make some good of my near-miss.
    Or hear from everyone the obvious mistakes I made. Either way is fine by me!
    emelianenkov likes this.
  8. Oct 23, 2017 at 8:17 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    100% take care of This today the corrosive agents in the mist will eat mild steel and assuming it was a car cert extinguisher it’s designed to cut through any oils I.e. fluid film scrub the shit out of that
  9. Oct 23, 2017 at 8:18 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Will definitely do it tonight. I'll probably also order a small bottle of FF off Amazon to touch up where it hit. Thanks!
    I married my tacoma likes this.
  10. Oct 23, 2017 at 8:18 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    This makes me realize I need a extinguisher ASAP
  11. Oct 23, 2017 at 8:19 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    That was my hope! If I hadn't had one my truck would probably have burned down completely... in front of my coworkers no less.
    I married my tacoma and ManBeast like this.
  12. Oct 23, 2017 at 8:21 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  13. Oct 23, 2017 at 8:23 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I did that too for my bed lights but I ran it in wire loom and wrapped that in heat reflective tape near the cats
  14. Oct 23, 2017 at 8:26 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    same here, getting one today!
    DrFunker and BigMacMcCoy[OP] like this.
  15. Oct 23, 2017 at 8:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Whew, close call, almost turned into a parked ford simulation................
  16. Oct 23, 2017 at 8:31 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  17. Oct 23, 2017 at 8:31 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  18. Oct 23, 2017 at 8:31 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Congrats! You completed the "make your truck an arc welder" mod!
  19. Oct 23, 2017 at 8:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Seems like this was user error versus a general fire caused by the manufacturer.
    No worries, I don’t have any aftermarket electronics or anything
    Blockhead and BigMacMcCoy[OP] like this.
  20. Oct 23, 2017 at 8:37 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Is there a patch for that?
