Almost New 1996 Taco Power Steering Pump...
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by tooter, May 18, 2013.
  1. May 18, 2013 at 7:59 AM
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I removed this power steering pump when I first bought my new Tacoma.
    SOLD
    It's been stored full of oil for 17 years and only has about a hundred miles of use on it. Comes with reservoir, pulley, idler, belt, pressure switch and banjo bolt.
    $85 including shipping. :)
  2. May 18, 2013 at 9:20 AM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    Do you know if it is compatible with a 99 with 2.7?
  3. May 18, 2013 at 9:55 AM
    tooter
    Greg
    Los Angeles
    It could be. Toyota is notorious for parts compatibility.
    I had a shortened shift lever on my 1996 and wanted to keep it. To my surprise it fit perfectly in my 2012. :eek:
    This is parts compatibility over a span of 17 years.
    If you're interested, take a good look at your pump and exactly how it mounts. I can take detailed pictures and take exact measurements so that you can determine if it will work on your truck. Knowing Toyota they likely use the same basic pump for years with different mounting brackets to fit different applications.
  4. May 19, 2013 at 10:09 AM
    tooter
    Greg
    Los Angeles
  5. May 19, 2013 at 11:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    damn! i need this..oh well
