Almost new Rear leaf went flat.. wtf
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shawnw72, Aug 27, 2022.
  1. Aug 27, 2022 at 8:08 PM
    shawnw72
    shawnw72 [OP] New Member
    2016 Tacoma TRD Offroad
    I have some almost new all-pro expedition series 3” leaf’s.
    I went out and ran em pretty hard for about 10 minutes of Baja style running and now the drivers side leaf is sagging about 2 1/2 inches lower then the right.
    I ran a straight line on the two leafs to check the arc and the drivers side is for sure much flatter then the passenger.
    Anyone know if this is fixable (other then flattening out the right side, lol) or do I need to replace this thing.
    Also, is this a real issue with these all pros or what leaf should I run if I wanna have fun with dips and bumps at higher speeds.
  2. Aug 28, 2022 at 5:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Great first post without pictures. And without all your mods.
    “almost new” that’s like kinda pregnant.
  3. Aug 28, 2022 at 5:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Fast dips and bumps are shock challenges. Loads and load transfer (turns, stops etc) are spring challenges.
    33yrsoftoys likes this.
  4. Aug 28, 2022 at 6:22 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    ^^this^^
    2 1/2" lower? Sounds like something might have broke?
    Fast1, TexasWhiteIce and Wulf like this.
