Aloha New Member! 3" Toytec spacer lift on 325/60/18 Rubbing Questions
Discussion in 'Suspension' started by 808Renato, May 12, 2011.
  1. May 12, 2011 at 3:47 AM
    808Renato
    808Renato [OP] Well-Known Member
    Renato Medeiros
    Kauai
    16 MGM DC 4x4 6spd Manual
    Aloha, I'm really stoked to have join this site :D
    Well like the title says I got a 3" Toytec lift on 18"x10" rim (same backspace as stock) wrapped on 325/60/18.
    I know that this setup is way bigger then recommended but I loved the loOk so Im willing to compromise with the rub if I can't eliminate it...
    I cut and cut the plastic to eliminate fender rub so now Im down to two issues:
    1-Tires rub on the cab mount at a full turn :(
    2-Tires rub on control arm on I hit a bump while turning :mad:
    Solutions?
    1-Shaving the cab mount back + weld plate?
    2-using a small spacer?
    Should solutions #1 and #2 eliminate my problems completely? I'm affraid of spending the cash to get those done and still have rubbing issues...:(
    Hope u can help ;)
  2. May 12, 2011 at 4:06 AM
    808Renato
    Renato Medeiros
    Kauai
  3. May 12, 2011 at 3:11 PM
    lvlytaco
    lvlytaco Well-Known Member
    Allan
    Hawaii
    Got Lip?
    6" procomp basic lift, alpine dbl din, 9" headrest screens, mb quart components, jl amp, yellow top battery, wet okole seat covers all around
    go 6" and all ur worries will dissapear.....nice truck man
  4. May 12, 2011 at 3:14 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    alll your money will dissapear too.
    use a spacer in the front, make sure you use hub and lug centric like spider trax
    and get the cab mount chop
  5. May 12, 2011 at 3:56 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    ALmost guaranteed with that wide of a tire you will not be able to completely eliminate rubbing. Adding a spacer will help with the UCA rubbing but will make cab mount rubbing worse. A chop will help, but the addition of a spacer, especially 1.25" one will make it nearly impossible to eliminate rubbing at the rear.
  6. May 12, 2011 at 10:32 PM
    808Renato
    Renato Medeiros
    Kauai
    Thanks!
    I'm getting work done tomorrow & I'll report back with updates...
    Will a 1/4" spacer work?:confused:
  7. May 13, 2011 at 11:45 PM
    808Renato
    Renato Medeiros
    Kauai
    Work is done on the cab mount and used a 1/4" spacer... Let's just say that rubbing is a thing of the past!;) (at least for street driving)
    Will post some pics later... Aloha
  8. May 14, 2011 at 12:48 AM
    808Renato
    Renato Medeiros
    Kauai
    What are other downsides of running wide tires? Besides rubbing...
  9. May 15, 2011 at 1:47 AM
    808Renato
    Renato Medeiros
    Kauai
    thanks for all the comments and concerns... Aloha
  10. May 15, 2011 at 11:50 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    my frined had that sive with a 6in lift....looked awsome no rubbing even when offroading
  11. May 22, 2011 at 9:59 PM
    808Renato
    Renato Medeiros
    Kauai
    Cab mount chop
  12. May 22, 2011 at 10:26 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    where did you go to get your work done?
  13. May 23, 2011 at 12:35 AM
    808Renato
    Renato Medeiros
    Kauai
    See Jeff @ Maui Offroad (Mililani)
    Around $200
  14. May 23, 2011 at 12:58 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    those wide tires do look really nice I like . whats your MPG?
  15. May 23, 2011 at 5:46 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Since the rims are so wide, if you add a spacer you will probably start rubbing on the outside of the tire.
  16. May 23, 2011 at 5:53 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    WOW. I run a 325/65/18 on my tundra and it rubs some so that must REALLY rub.
  17. May 23, 2011 at 11:41 AM
    808Renato
    Renato Medeiros
    Kauai
    I didnt check, but Im sure its not pretty!:eek: Its not a daily driver...(weekend and beach only)
    I ride my drz400sm back & forth
  18. May 23, 2011 at 11:44 AM
    808Renato
    Renato Medeiros
    Kauai
    I added a 1/4" spacer and I can do full turns without rubbing...
  19. May 23, 2011 at 11:47 AM
    808Renato
    Renato Medeiros
    Kauai
    Without the cab mount chop a cutting the plastics it would of been impossible to even switch lanes without rubbing... Now there is no rubbing issues what so ever! (u turns, reverse turn, bump turns and etc..)
  20. May 23, 2011 at 11:54 AM
    Smoove06
    Smoove06 Well-Known Member
    Alex
    North Phoenix
    05 SSM DCSB PreRunner
    Starting From Scratch....again
    Howzit! Whered you get your 1/4" spacer from?
