Alpha Rex Tacoma headlights turn signal problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skycore11, Aug 31, 2024.
  1. Aug 31, 2024 at 2:38 PM
    Skycore11
    Skycore11 [OP] Member
    Whenever I use my passenger side turn signal it does the sequential turn signal but it randomly speeds up one time then goes back to normal I’ve seen you need resistors and was wondering if that’s what would fix my issue. Also less important in videos it looks like the drls are flashing but in person they aren’t so I was wondering if that’s a normal thing because I’ve seen videos where it doesn’t do that
  2. Aug 31, 2024 at 8:38 PM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    When did you purchase them? They released a "new" inline DRL harness 2-3ish years ago that resolved hyperflash without needing 3rd party resistors. Speaking of, if you have that new harness I'd check how you have the passenger side piggyback connector hooked up to the main harness/driver side.
    As for the blinking on some videos vs. not, that simply has to do with the aperture/shutter speed the camera is recording at, and the refresh rate of the LED on the DRL. You'll notice in shows and other homevideos the same happens when videoing LED monitors or lights. It's just catching what our eyes can't perceive: the light refreshing/cycling dozens of times per second.
  3. Aug 31, 2024 at 11:35 PM
    Skycore11
    Bought last week I’ll check out my connection tomorrow
  4. Sep 2, 2024 at 10:21 PM
    Skycore11
    Unplugged and replugged and now they are good
    EveryDayIsTacoTues and Knudsen like this.
