AlphaRex Headlight.
Discussion in 'Lighting' started by Xx Ares xX, Jul 26, 2020.
  1. Nov 18, 2021 at 10:48 PM
    #101
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    False. The reasons you list they are better is exactly why they are "wayyyyyyy" worse, AlphaRex is a short range floodlight, not a headlight. The product is an optical disaster. More comparison info here. And that is against v1.0 Morimotos, the v2.0 Morimotos are massively brighter while actually maintaining a correct headlight pattern as covered in post #4548 here. The v2.0 Morimotos exceed D2S HIDs in low beam output intensity and high beam output intensity while placing hot spot intensity at the cut off for maximum distance projection as a proper headlight should. AlphaRex has the headlight pattern literally backward, with huge increases in foreground light while dipping the beam intensity significantly in the pattern reducing the distance projection and causing the massive increases in foreground light which limits the distance vision of the driver. So yeah, slow speed on the trail seeing things 10' in front of you they will work fantastic and you can see everything. 60+mph on the freeway they will be completely worthless, you will outdrive your headlights and see nothing until it is way too late.
    Unfortunately the massive increase in foreground light is often viewed as positive from non-educated users, while not realizing they have lost their critical distance light. This is human nature to rate foreground light as better (a common mistake so don't feel bad!), even though that isn't how a headlight is supposed to work, as headlights are supposed to minimize foreground light and focus on distance light. So that either makes AlphaRex completely incompetent in headlight design, or cleverly designing poor performing products to be misleading to the buyers. In interactions with their reps, it is pretty clear they have no clue how these products are supposed to work. Maybe that is because AlphaRex doesn't actually make anything, they don't have actual product engineers, zero expertise in automotive lighting, they just resell cheap Chinese products at huge markups to ill-informed American buyers.
    Those headlights are made by Zhejiang Lingyi. You just paid crazy markups on a very poorly designed rebranded cheap china headlight.
    http://www.zjlingyi.com/en/pd.jsp?id=139#pfc={"groupIds":[12],"lid":1,"sc":{"key":"name","desc":false}}&_jcp=3_12
    While the Morimoto v2.0s are far better designed than the AlphaRex/Zhejiang Lingyi headlights, the OEM LEDs are vastly superior in all aspects of design, pattern performance and quality compared to both those options as covered in post #3626 here.
    dpele, Too Stroked and 2013XSPX like this.
  2. Nov 22, 2021 at 12:45 PM
    #102
    MR.WaynesWorld
    MR.WaynesWorld Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    @crashnburn80 So what you are saying both AlphaRex and Morimoto are less superior then the stock Tacoma limited LED headlights. I have been tossing around swapping out my stock LED lights for either of the two I mentioned. But after a lot of reading and research here on TW it looks like I already have the best. I can tell you when I first got my truck I was very impressed with the lights on it. And I really don't want to spend 1K+ just to be disappointed.
    One thing I wanted to do is eliminate the chrome strip in the headlights. But after reviewing a couple of more videos that showed the 21 Limited with the Nightshade package I noticed that even with that trim level it still has the chrome accent in the headlight.
    dpele likes this.
  3. Nov 22, 2021 at 7:42 PM
    #103
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    AlphaRex should be discarded entirely as a consideration if you actually care about headlight performance. Between Morimoto and OEM LED, the Morimotos are brighter in output intensity but have flaws that reduce visibility (lack of uplight) and some quality control issues. The high beam also lacks the flood function of an OEM headlight, so you get further illumination down road but not the wide area coverage. Vs Toyota's exceptionally well designed headlight that includes uplight and is from the leader in automotive quality and the high beam offers a good concentrated hot spot for punch down road while still providing that general flood function for the ultra wide area illumination. Styling is personal preference. You could debate on the merits of both if upgrading from halogen, but I wouldn't pay to switch away from the OEM LED.
  4. Nov 23, 2021 at 10:54 AM
    #104
    apbright
    apbright Well-Known Member
    Aaron
    2007 Silver Tacoma Base
    Do you have a video of the sequential turn signals? Are all of their headlights sequential?
