Alpine CDA-9884
Discussion in 'Audio & Video' started by scrouch7x, Dec 27, 2008.
  1. Dec 27, 2008 at 12:49 PM
    scrouch7x
    scrouch7x [OP] Member
    02 Tacoma Prerunner
    Just replaced factory speakers with Pioneer 6x8's in the front and rear. Replaced factory tweeters with Infinity 107t's. Was wondering how to tie in the tweeters? Running an Alpine MRP-F250 amp. The Head has RCA outputs that I am running to the amp just for the front 2 and back 2 speakers. There are extra connections for gauged wire for front and rear. Should I hook them up to the front speaker outputs? Any suggestions?
  2. Dec 27, 2008 at 8:56 PM
    81shark
    81shark Well-Known Member
    generally you use crossovers. is it safe to assume the 6x8's are 3 way or something like that. if so, they have a tweeter built in.
  3. Dec 28, 2008 at 1:32 AM
    scrouch7x
    02 Tacoma Prerunner
    Correct, the 6X8's are 3-way and the tweeters have crossovers.
  4. Dec 28, 2008 at 1:19 PM
    81shark
    if you have 3 way speakers, you really don't need the extra tweeters.
    but if you want to hook them up and you have a cross over, i'd run the wires from the amp to the cross over and then the 6x8's to the woofer side, and the tweeter to the tweeter side.
    it may sound funky...who knows.
