Alpine install and now clock won't work
Discussion in 'Audio & Video' started by glasgow grin, Apr 2, 2011.
  1. Apr 2, 2011 at 4:50 PM
    glasgow grin
    glasgow grin [OP] Member
    Northeastern U.S
    Tacoma 4 Banger
    Hi all. I've been browsing for a while, and recently picked up my first Tacoma. A 2009 Access cab. I hated the stock radio, so I installed an Alpine CDE-126BT CD Receiver, which i purchased from crutchfield. The install went well, except that I had trouble getting the factory clock out of the housing. When I got everything installed, the clock no longer works. I followed the instructions from Alpine and Crutchfield, and wired everything correctly, and soldered and taped all connections. Pretty straightforward. The Alpine does have a clock on it, and I'm wondering if the instructions intentionally eliminate the factory clock, or did I do something wrong? None of the clock wires were touched. The airbag lights and hazard flashers still fuction fine....just the clock is now blank. Anyone have any ideas, or experienced this before? Thanks.
  2. Apr 2, 2011 at 4:52 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    18 DCLB OR Prior: 99LX470/05DCOR97LX450/914R
    Basic
    did you connect the clock back in? just asking because when i installed my stereo I forgot to connect it...
  3. Apr 3, 2011 at 5:56 AM
    glasgow grin
    Northeastern U.S
    Tacoma 4 Banger
    There's only one wiring connector for the whole unit. If it wasn't plugged in, my airbag lights wouldn't work.
  4. Apr 3, 2011 at 6:54 PM
    glasgow grin
    Northeastern U.S
    Tacoma 4 Banger
    O.K. I'm starting to think I missed something here. When I removed the clock/air bag lights, I don't recall if there was more than one connector that plugged into the unit. Can anyone tell me if the clock has a seperate connector from the air bag lights? I may have just lost the connector back inside the dash.
  5. Apr 3, 2011 at 7:16 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    On an '11 there is definitely two plugs. Should be an easy thing to check, pop off the panel and see if there is an empty socket on the back side of the clock.
  6. Apr 6, 2011 at 8:08 AM
    glasgow grin
    Northeastern U.S
    Tacoma 4 Banger
    Ok, so I ripped the entire dash apart again. There is only one connector that goes to the clock/airbag indicator unit. Apparently, I must have rendered it inoperable while attempting to remove it from the cover. Can anyone tell me the correct name/part number for this clock? I need to replace it.
