Alpine Power Pack 4 Channel Amp
Discussion in 'Audio & Video' started by KILGORE76, Apr 24, 2011.
  1. Apr 24, 2011 at 11:47 AM
    KILGORE76
    KILGORE76 [OP] Well-Known Member
    Beaufort,sc
    2011 toyota tacoma double cab
    Hello,
    I was looking at buying the alpine power pack mini amp,I have a 2011 Toyota tacoma double cab.I have already installed the kenwood x993 head unit which i really like,I was going to modify the plugs on the power pack to work with the kenwood.I was wanting to know if anyone has done this before and where would be a good place to put this little amp.I looked but there is very little room behind the head unit and under the dash.I wanted to keep it close to the head unit so i would not have to run extra wire.
  2. Apr 24, 2011 at 2:17 PM
    outxider
    outxider Well-Known Member
    Sang
    Bay Area
    06 DCSB 4x4
    A few mods here and there and counting....
    I have Alpine power pack amp modified to work with my Pioneer Z2. What a great investment to boost my speakers which I've replaced all the way around. I mounted the power pack above the glove box. Open you glove box, there is a black cover that can be remove very easily. I mounted it using heavy duty double sided tape. It will sit right side up, hidden and out of view and the cord is perfect length.
  3. Apr 24, 2011 at 3:08 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Cedar Park / Austin
    2013 DCSB MGM TRD OR 4x4
    Fox 2.5 c/o, Camburg UCA, OME Dakar, Fox 2.0 rear, LED interior light kit, LED fogs, LED headlights, Nitto G2, MB black wheels, diff breather mod, All AMSOIL syn fluids, XRXS bed cross bars, full debagged, shortened OEM antenna mod, Wet suit seatcovers, and fog light any time mod.
    I have the KTP 445 as well in the same place. It is held in place by some velcro. I have it hooked up with my Alpine CDA 105 and it works good.
    Thinking of some other plans with my stereo so might be selling it soon if anyone is interested let me know.
  4. Apr 24, 2011 at 3:42 PM
    KILGORE76
    Beaufort,sc
    Thanks for the reply!Ok so open my glove box and there is a black cover?Above the glove box?
  5. Apr 24, 2011 at 11:02 PM
    outxider
    Sang
    Bay Area
    06 DCSB 4x4
    Once the glove is open, drop it down, so you have room to work with. I believe there is one screw holding it down, can't remember. But, yes the space is more than enough to hold the power pack and the wires are easily reached.
  6. Apr 25, 2011 at 3:12 PM
    KILGORE76
    Beaufort,sc
    Ok,I opened my glove box,I think i see what you are talking about,It's 1 bolt,It kind of looks like a star or hex bolt?It is where the lock is when the glove box close shut.
  7. Apr 25, 2011 at 6:25 PM
    06TXED
    Tony
    Cedar Park / Austin
    Yep thats it. I think that it is a 10mm bolt
  8. Apr 25, 2011 at 6:35 PM
    KILGORE76
    Beaufort,sc
    Ok,Thanks!Im going to open it up and take a look,I'll go buy the amp this week..Got a lot of soldering to do with those wires..lol But i need that extra power:)
  9. Apr 29, 2011 at 9:46 PM
    KILGORE76
    Beaufort,sc
    Ok,I opened it and i see where you said it would sit on top of the plastic part,It might be just me or i could be wrong but the plastic part seems kind of flimsy to me,That amp wont be to much weight to sit on that would it?or does it go above that plastic part mounted upside down?or does it sit on top of the plastic part that is held by one screw?Thanks!!sorry for all the questions.
  10. May 3, 2011 at 12:39 AM
    outxider
    Sang
    Bay Area
    06 DCSB 4x4
    That's it. It will hold the amp just fine, right side up, hidden out of view. I really can't explain any more than that. Theres plenty of space and 06TXED and mine is proof of that.
  11. May 3, 2011 at 6:55 PM
    06TXED
    Tony
    Cedar Park / Austin
    x2 space is not that big of an issue but a few times I have thought that the plastic is a little flimsy. Thinking of zip tieing the amp up to the metal dash support bar only if I feel like it.
  12. May 5, 2011 at 8:33 PM
    Performula
    Performula Six lugs of fury!
    Justinian the Gr3iht
    CO
    A no option 4WD vehicle.
    Alpine HU - Wow :)
    For a super stealth look I'd get one! After paying $110 for one, I could offset that cost with a decent $150 amp pushing more wattage. I know it's a pain hooking everything up.
