Alpine V-Power work for me?
Discussion in 'Audio & Video' started by Tidrow, Jun 30, 2010.
  1. Jun 30, 2010 at 9:46 AM
    Tidrow
    Tidrow [OP] Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    Hey guys,
    Thinking about picking up this amp from CL. Guy told me I could take it for $55. I don't have any stereo mods, just the OEM everything. Would this be a good amp to push the speakers (after I put in a deck and component system)? Anybody have any experience with this amp?
    I realize you prolly wouldn't want to use it on a sub, but no worries cause I don't have one. I'm holding out for a stealthbox
    Description: The MRP-F240 is designed to work in a variety of applications: With 40 watts RMS per channel in 4-channel mode, you can easily drive two pairs of full-range or component speakers. Or, bridge the amp to 2-channel mode for 100 watts RMS x 2. That power makes your music sound tighter and more detailed at all volume levels.
    • 40 watts RMS x 4 at 4 ohms
    • 50 watts RMS x 4 at 2 ohms
    • 100 watts RMS x 2 bridged output at 4 ohms
    • 2-, 3-, or 4-channel output
    • 4-ohm stable in bridged mode
    • Tri-Way capable
    • requires 10-gauge power and ground leads wiring and hardware not included with amplifier
    • selectable high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
    • subsonic filter at 15 Hz for channels 3 & 4
    • tuned Bass EQ (0-12 dB bass boost at 50 Hz) for channels 3 & 4
    • preamp outputs
    • MOSFET power supply
    • STAR Topology (minimizes internal noise and prevents ground interference)
    • speaker- and preamp-level inputs
    • gold-plated screw terminals
    • 10-1/2"W x 2-7/16"H x 9-9/16"D
    Thanks in advance.
  2. Jun 30, 2010 at 9:48 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    That would run a set of mids & highs just fine.
  3. Jun 30, 2010 at 10:31 AM
    Tidrow
    Austin
    PreRunnin' 08
    thanks man, going to pick this up today
  4. Jun 30, 2010 at 12:16 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I think those amps are underrated too. Probably makes more power than stated. Good amps from what I remember.
  5. Jul 2, 2010 at 10:09 AM
    Tidrow
    Austin
    PreRunnin' 08
    I bought the amp and bought this deck new. Kenwood KDC BT945U, $219 at Fry's.
  6. Jul 2, 2010 at 10:16 AM
    sirsaechao
    Tim
    Commifornia
    Great deck. USB, Bluetooth via Parrot and 4 Volt preamp for Front Rear and Sub.
  7. Jul 2, 2010 at 12:26 PM
    Tidrow
    Austin
    PreRunnin' 08
    That's it!!! I'll be doing the install tonight. Pics on the way
  8. Jul 3, 2010 at 9:38 PM
    Tidrow
    Austin
    PreRunnin' 08
    done!!!
  9. Jul 3, 2010 at 9:40 PM
    Tidrow
    Austin
    PreRunnin' 08
