alpines supercharger?
Discussion in '4 Cylinder' started by vtragweed, Oct 4, 2009.
  1. Oct 4, 2009 at 5:53 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i noticed Alpine is getting ready to come out with a supercharger kit for 05-09 2.7, does anyone know how hard it is to tune these things or are they just bolt on and roll. im half temped to get one just wanna know what im up against before i put my order in, and if it will mess with my mpg?
  2. Oct 4, 2009 at 7:57 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    of course it will. you are adding a HUGE power upgrade, so when you are WOT you will use much more air and FUEL. makes sense, right?
  3. Oct 4, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im not sure what the second gen 2.7 has for fuel managment, but on my 2000, it was really easy to do the required fuel mods.
  4. Oct 4, 2009 at 8:02 PM
    crawl
    Greg
    Valencia, CA
    Chris, you agree that more air requires more fuel?
  5. Oct 4, 2009 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Absolutly. Generally, you want to have an AF ratio of 12 to 1 if boosted. The injectors on the stock second gen 2.7 should be up to the task of a little bit of boost. Maybe around 5 to 6 psi without issue. Alpine produces a solid product, and they are pretty well known for covering all the bases with their kits.
  6. Oct 4, 2009 at 8:18 PM
    crawl
    Greg
    Valencia, CA
    kool man. so the stock 2.7L injectors are up to the task of mild boost...lets say 6 psi? My stock Prelude injectors require 100+ psi of fuel (100% duty cylcle) to properly fuel my 6 psi supercharger. Soon to be changed with much better injectors and going back to 40-50 psi of fuel.
  7. Oct 4, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I never had any problems with my stock pump. I know the 3.4 guys had to upgrade theirs, but I was running close to 7 psi with no issue. I belive the Alpine unit is going to use the 62 cui mangunson SC. It doesnt heat up the air at 6 psi too much, so I cant see fuel upgrades being needed. BUT...I have yet to see one of these on a second gen, so Im just speculating.
  8. Oct 4, 2009 at 8:29 PM
    crawl
    Greg
    Valencia, CA
    Idk, I just don't see how ANY factory NA injector can handle boost without a rising rate fuel pressure regulator. My Honda factory injectors can handle a 10-20% increase in air flow, but thats about it...not enough to support a blower imo.
    btw, all my knowledge and experience is related to my honda prelude, so I could be way off the mark here.
  9. Oct 4, 2009 at 8:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Alpine kit I had, had a rising rate fuel regulator. The more boost it gave, the more fuel dumped into the engine.
  10. Oct 4, 2009 at 8:41 PM
    crawl
    Greg
    Valencia, CA
    ^^^ok...same as my prelude setup with the stock Jackson Racing supercharger kit. It's not ideal though. I much rather have injectors runing at 70-80% duty cycle and capable of fueling the airflow. I see/feel/have alot of issues running my RRFPR. I can't wait to dump it!
  11. Oct 4, 2009 at 8:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. Oct 4, 2009 at 8:47 PM
    crawl
    Greg
    Valencia, CA
    you had an on board wideband to monitor the 12:1 afr?
  13. Oct 4, 2009 at 8:48 PM
    crawl
    Greg
    Valencia, CA
  14. Oct 4, 2009 at 8:50 PM
    crawl
    Greg
    Valencia, CA
    come visit me in cali and feel what 8000 rpm feels like BOOSTED and bouncing off the rev limiter.
    you keep thinking thats all its got........but no, its got more~~~~~~~~~~~~
    10:1 compression, 8000 rpm reving, 2.2L BOOSTED 4 banger! It's a blast at WOT.
  15. Oct 4, 2009 at 9:04 PM
    crawl
    Greg
    Valencia, CA
    allright, I'm gonna stop being a dick and look into the Alpine kit.
  16. Oct 4, 2009 at 9:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not on board. Just at the dyno shop.
    LOL...I have been in some pretty wicked powerfull rides, as well as some pretty tuned 4 bangers. I know what they feel like. :)
  17. Oct 4, 2009 at 9:13 PM
    crawl
    Greg
    Valencia, CA
    on board is a must imo.
    ok... I give in, you're not impressed with my blown 4cyl. bottom line, we agree on the fact that proper/safe tuning and the right amount of fuel is key :)................................and adding a supercharger WILL increase your WOT mpg.
  18. Oct 4, 2009 at 9:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl: I dont think I agree to that.
  19. Oct 4, 2009 at 9:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OP, after I installed teh Alpine SC, My mpg's, overall, dropped about 2 mpg. HOWEVER, I found my self useing the throttle a little more. :)
  20. Oct 5, 2009 at 8:22 PM
    willis
    willis Well-Known Member
    keith
    birmingham
    09 prerunner
    not enough!
    did i miss something???
    link please !?!?!!?!?!
