Already have 5100's need a little more lift
Discussion in 'Suspension' started by toyodajeff, Sep 22, 2012.
  1. Sep 22, 2012 at 11:32 AM
    toyodajeff
    toyodajeff [OP] Well-Known Member
    jeff
    06 reg cab sr5
    I already have 5100s set at 2.5 on my 2006 4cyl prerunner regular cab. I would like to get another 1/2 to 1 in lift. My stock front springs may be sagging some im not sure but it has 80,000 miles so they might be a little wore out. I've looked into the toytec top plate 1/2 inch spacer, but I know everybody says spacers are bad. I just want to lift it up more because I put a set of used (20% tread left) 285/75/16 bfg a/t tires and had to cut a good bit for it not to scrub the fenders. I need new tires soon and will probably get treadwright a/t's in the same size and they are a little bigger than the bfg's so they will probably scrub without doing way more cutting than I have already done. Can anybody throw out any other options I might have for this in the $300 dollar price range.
  2. Sep 22, 2012 at 11:49 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Sell 5100s and buy a spindle lift.
  3. Sep 22, 2012 at 11:58 AM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    What he said. It will give you 4" of lift with no sacrifice to stock ride quality. But if you plan in the future to do a 4x4 conversion then I would not get them
  4. Sep 22, 2012 at 12:01 PM
    monsterkx2fiddy
    I want treadwrights! Gonna have to settle with duratracs -.-
  5. Sep 22, 2012 at 12:02 PM
    cgs2k2
    cgs2k2 old man
  6. Sep 22, 2012 at 12:10 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Those are more in my price range than the lift spindles. But will the ride really suck with them??
  7. Sep 22, 2012 at 12:19 PM
    boardude
    boardude BOOMSHAKALAKA
    Kris
    Tucson, Arizona
    '15 Tundra TRD Pro Inferno
    A Yota with more cowbell
    I have the same setup with the 5100s. I just ordered the OME 885x coils and the top plate spacers from toytec. Im going to throw these on the billies (set @ 0) to get a smoother ride and some additional lift. Lots of guys here with this and getting around 3"
  8. Sep 23, 2012 at 7:16 AM
    toyodajeff
    jeff
    06 reg cab sr5
    Do you guys think if i go up any higher I'll have to get new uca's?
  9. Sep 23, 2012 at 7:20 AM
    toyodajeff
    jeff
    06 reg cab sr5
    Heres a pic of my truck by the way
  10. Sep 23, 2012 at 7:23 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  11. Sep 23, 2012 at 8:30 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    x2 I didnt know you were a reg cab when I pm'd you about the 885s I have.
  12. Sep 24, 2012 at 10:14 AM
    toyodajeff
    jeff
    06 reg cab sr5
    I thought about a 1 in body lift but people on here always rag on body lifts. I know the pros and cons of each but whats worse a 1in body lift or a 3/4 inch spacer lift? each lift would probably cost about the same and I would be installing either one on my truck so labor cost doesn't matter
  13. Sep 24, 2012 at 10:25 AM
    toyodajeff
    jeff
    06 reg cab sr5
    Was moving the radiator/fan shrould or the gas tank filler neck a pita?
  14. Sep 24, 2012 at 11:47 AM
    bradicus8
    bradicus8 Well-Known Member
    Brad
    Phoenix, AZ
    2018 cement Trd sport DCSB
    icon kit 33's ovtune pro grille JL audio subs with custom box
    Ya I would get those maxtrac spindles, they go for about 500$ if u look for em and I kno it's more than u wanna spend but WELL worth the money
  15. Sep 24, 2012 at 12:20 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Thanks for the help man
  16. Sep 24, 2012 at 1:37 PM
    TRD6Speed
    Bill
    East Hartford, CT
    longer brake lines are needed right? Once i get my 3" lift installed I'll want more when I need tires. 4hrs sound not bad.....Im slow though so even 8 hrs is ok if I can do it with some help.
  17. Sep 24, 2012 at 1:49 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    The coilovers need to be disassembled to install the longer studs with the 3/4" lift top plate spacers. Just making sure the OP knows that if he decides to go that route.
  18. Sep 24, 2012 at 1:50 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    heavier coils
  19. Sep 24, 2012 at 2:00 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Yea its not a big deal I have a friend who works at a dealer that has a wall mount spring compressor I can use
  20. Sep 24, 2012 at 2:34 PM
    ajohnson
    Andy
    Charlotte, NC
    :thumbsup:
