Already have good lift kit...
Discussion in 'Suspension' started by button, Jun 6, 2011.
  1. Jun 6, 2011 at 5:24 PM
    button
    button [OP] Well-Known Member
    chris
    Stafford VA
    2011 Trd off road x-cab 6-speed super white
    total chaos UCAs, OMEs all around, dakar leafs, tib.bump stops, extended brake line, yota bajas wrapped in 285/75,dakota digital interface, extra bed tie downs,tail gate theft mod,beefed sliders,
    My questions are
    Can you run a 3in lift and a 2in body lift? What are the side effects? Anyone else running this Thanks in advance
    I already have the 3 inch suspension, as follows:
    front coil overs OME nitro chargers
    Total chaos uniball UCAs
    extended stainless steel braided brake lines from wheelers front/rear
    rear dakar OME leaf springs with extended travel nitro charged OME shocks
    all pro u bolt flip kit with timbren bump stops
    285/75/16 bfg at ko tires
    spidertrax wheel spacers for the front
  2. Jun 6, 2011 at 5:28 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You could... But I wouldn't do it.. Why not just run with that setup and skip the body lift idea? Iam pretty much running the same as you and no complaints with my 285s.
  3. Jun 6, 2011 at 5:32 PM
    button
    chris
    Stafford VA
    Im still rubbing on the back side. I already trimmed the front. Im not lookin to get to aggresive with the body lift. I was thinking 1 or 1.5 inch im also running 285s
  4. Jun 6, 2011 at 5:35 PM
    krimson
    krimson Nothin
    TRD Off Road
    You are rubbing on the cab mounts? If so, check out the cab mount chop mod. Tons of people that run 285s do it and have close to no rubbing while wheeling.
  5. Jun 6, 2011 at 5:37 PM
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    sounds to me like you have to do a bit more trimming. Are you rubbing on the frame? because a body lift won't help you, look into a cab mount chop and cut some more wheel well. pics? where you are rubbing
  6. Jun 6, 2011 at 5:38 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    i did the cab mount chop and have no rubbing on 285s while wheeling as well
  7. Jun 6, 2011 at 5:38 PM
    button
    chris
    Stafford VA
    I will def check into that. Thanks for the info. I drive DOWN a washed out dirt road every day. Thats when im hitting thanks again
  8. Jun 6, 2011 at 5:41 PM
    button
    chris
    Stafford VA
    Does the cab mount still give enough clearance in the same circumstances /|\ with a heavy plate bumper. I plan on installing one soon
  9. Jun 6, 2011 at 5:43 PM
    krimson
    krimson Nothin
    TRD Off Road
    Yeah it should, what OME coils are you running? With a plate bumper, it's a good idea to run the 886s.
  10. Jun 6, 2011 at 5:47 PM
    button
    chris
    Stafford VA
    885s now
  11. Jun 6, 2011 at 5:48 PM
    krimson
    krimson Nothin
    TRD Off Road
    Get the 886s like I said if you gonna run a new bumper. Then you will be good to go :thumbsup:
  12. Jun 6, 2011 at 5:51 PM
    button
    chris
    Stafford VA
    awesome. easy enough b/s/t section here i come Thanks for the info man. I'll look in to the cap mount chop too
    sent some rep your way
  13. Jun 6, 2011 at 5:52 PM
    krimson
    krimson Nothin
    TRD Off Road
    No problem! Thanks for your service Marine!
  14. Jun 6, 2011 at 6:01 PM
    button
    chris
    Stafford VA
    Oorah!!
