Alright guys what could cause my Tacoma to do this:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Aug 3, 2017.
  1. Aug 3, 2017 at 5:35 PM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    https://www.youtube.com/watch?v=qg4BuFaHqWc
    I parked it and heard a hiss, saw this under the hood. Checked the temp gauge and sure enough it was hot.
    I was alone in the wilderness so I had no choice but to limp it many miles to where I could get a tow. I kept it cool when limping by keeping the heater on full blast and stopping every couple miles to rest it and top off the radiator with water I had in the truck. I think I was successful because the heater stayed hot the whole time (never went dry) and the temp gauge stayed normal the whole time, never even started to creep up other than when I noticed it initially. I still have no idea what is causing what you see in the video though.
    Starting the engine would actually cause the boiling to stop in some cases. What you see was typically only happening with the engine off.
  2. Aug 3, 2017 at 6:55 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Looks like head gasket issues:notsure:
    cruxofthebisquit and Vereor_Nox like this.
  3. Aug 3, 2017 at 7:33 PM
    ISLANDJIM
    ISLANDJIM Well-Known Member
    2017 4Runner Off Road
    Or your radiator cap is not holding pressure.
  4. Aug 3, 2017 at 7:37 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    :1up:
  5. Aug 3, 2017 at 8:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't think it is a head gasket as the engine isn't running in the video...
  6. Aug 3, 2017 at 8:56 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Well dude it's over heated.
    Fan clutch
    Water pump
    Thermostat
    Radiator issues- clogged- bad cap- fucked up in general
    Head gasket
    If head gasket isn't the cause beware because over heat will result in blown head gasket
    Jimmyh likes this.
  7. Aug 4, 2017 at 11:00 AM
    andrew61987
    Like Jimmyh said no way it's a head gasket, it bubbled several minutes after engine shut off.
    I did find this though. I only wish I knew where the rest of that cap went.
    07 sport 4x4 and tomwil like this.
  8. Aug 4, 2017 at 5:59 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Ahh true. Overlooked that small detail lol
  9. Aug 4, 2017 at 6:11 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It happens. I've also seen turbo cars that only leaked when on boost. Still most likely a plugged radiator.....no guarantees. Hot running is hot running, can be anything.
  10. Aug 4, 2017 at 6:20 PM
    Radarninja
    Northern California
    06 taco
    It's probably in your cooling system may have jammed your thermostat and or water pump. I'd take it apart.
    Also don't rule out a head gasket or cracked head/ warped head dude that bitch looks hot
  11. Aug 4, 2017 at 6:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It cannot get out of the radiator as I think the suction is on the bottom and the return is on top.
  12. Aug 4, 2017 at 10:34 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I agree, that missing piece is likely at the bottom of the radiator. I'd replace the radiator/cap and thermostat while you're at it and go from there. Use an OEM/Aisin t-stat, radiators are cheap on rockauto, like $75 for a Denso. You could leakdown test it to rule out head/gasket issues.
  13. Aug 5, 2017 at 3:48 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    pressure test
    Braves95 likes this.
  14. Aug 7, 2017 at 9:03 AM
    andrew61987
    So I did a little googling and learned that a 50/50 coolant mixture at 15 PSI (typical cooling system pressure) boils at around 260 degF, but at atmospheric pressure boils around 223 degF. Quite the difference. This tells me that with a failed cap not holding any pressure she doesn't really have to get that hot to start boiling all the coolant off, which is what I saw. This gives me a little peace of mind but I'll definitely be taking it apart to finish the job.
    tomwil and 07 sport 4x4 like this.
