Alright, someone help me out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacOffRoad11, Nov 8, 2015.
  1. Nov 9, 2015 at 5:03 PM
    TacOffRoad11
    TacOffRoad11 [OP] Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    Nitrogen is what is in the tires now. I'm actually going to take it to another shop here in town and see if I have better luck.
  2. Nov 9, 2015 at 5:04 PM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
    I know they added air, how much is anyone's guess.
  3. Nov 9, 2015 at 6:07 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    I'd recommend doing the spray bottle with soap (dish soap is what I prefer) and water. Spray the bead areas (inner and outer) and stems (doesn't sound like the tread area is your problem, but it doesn't hurt to soak that too). Walk away for a good 30-60 minutes. Then, come back and look for the telltale bubbles.
  4. Nov 9, 2015 at 6:11 PM
    ndmak
    ndmak Well-Known Member
    Oddly enough, my AT3s were also leaking. each one of them at different rates. I took them to les schwab and had valve stems replaced and had the beads re-done and that has done the trick. good luck.
  5. Nov 9, 2015 at 7:02 PM
    2011GTACO
    2011GTACO Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    Take it to discount tire and tell them to clean where the bead seal and tell them to put bed sealler when they finish cleaning them
  6. Nov 9, 2015 at 7:08 PM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
    Excuse my not knowing. But what does it mean to have the beads redone?
  7. Nov 9, 2015 at 7:28 PM
    ndmak
    basically what you were talking about earlier, having them remounted and making sure the beads around all the tires were sealing correctly. they were leaking slowly.
  8. Nov 9, 2015 at 8:47 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    The beads are where the tire meets the wheel.
  9. Nov 9, 2015 at 8:50 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Ok ill chime in. I used to own a tire shop (15 years) and have repaired thousands of tires. Start with trying to find the leak with water and dish soap that already has been suggested. If the leak can't be found the tire is going to have to come off the rim. Inspect the rim for rust (steel wheel) or oxidation (aluminum wheel). If present clean the rim to a shine. I dont recomend bead sealer. If the rim is clean and not pitted the tire will seal. Inspect the tire from the inside for linner cracking and nails/screws. I like to take a shop rag and wipe the inside of the tire. A small nail will catch the rag. Remove the valve stem and clean the hole with a round file. Install a new stem. If you have TPMS use new stem seals. Some rims will crack and leak very slowly but its rare. Do the obvoius first.
    Almost forgot, dont bother with the nitrgen. The air you breath is 78% nitrogen and its free. The extra 22% you get isnt going to make any difference.
    TacOffRoad11[OP] likes this.
