Alright the finding wheels with the right offset is turning into an assache . . .
Discussion in 'Wheels & Tires' started by jimcasy, Jun 20, 2009.
  1. Jun 20, 2009 at 11:39 AM
    jimcasy
    jimcasy [OP] Active Member
    Los Angeles
    2005 Regular Cab Prerunner
    Sorry for the constant questions . . . the offset on my '05 regular cab Prerunner is +25 according to Flip's Tire out here in Los Angeles. I was looking to buy a set of Pro Comp black steelies that Wheeler's Off-Road sells, but was told I'd rub up against the fender . . . What kind of offset should I be looking for? I'm looking for a black 16x8 wheel to go with some 265/75/16 Good Years. Thanks for the the help . . .
  2. Jun 20, 2009 at 11:40 AM
    jimcasy
    Los Angeles
    i hat typos . . .
  3. Jun 24, 2009 at 5:38 AM
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    +35 to +42 as per one accessory shop (2wd access cab, 4 cyl)
  4. Jun 24, 2009 at 6:18 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I think for an 8" wide wheel, you want a 4" backspace. 9" wide, about a 4.5" backspace should do.
    The lower the number, the more it sticks out.
  5. Jun 24, 2009 at 6:50 AM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    X2
    I have the wheeler crawler steelies 16x8. type B has the 4 inch BS.
  6. Jun 24, 2009 at 12:00 PM
    jimcasy
    Los Angeles
    I ordered a set of american racing mojaves. got them for about $150 a wheel.
    the offset on these wheels is '0'. The steelies definitely work for Tacomas just don't ask Pro Comp to verify this. Apparently, alloys tend to clear better than steel wheels or so they say . . . gjbonner: where in Northern Idaho? I was born and raised in Moscow/Pullman . . .
  7. Jun 24, 2009 at 6:49 PM
    gjbonner
    Guy
    Northern Idaho
    Wow. I was born and raised in Pierce which is above Orofino on the Hill. just up river from Lewiston. I've been all over up there though. I love Northern Idaho and cant wait to get back. I have quite a large family have you heard of any Bonners up there? Where you at now?
  8. Jun 25, 2009 at 12:35 AM
    jimcasy
    Los Angeles
    cool . . . i've been to Orifino a handful of times . . . once on a field trip in high school to visit the state pen . . . me and my buddies used to race up the Lewiston grade on our way back from Effies (full 1lb burgers. My colon still hates me for those trips). I live in Los Angeles now . . . it might as well be another planet . . . but i've grown to like a lot about this city . . . i suppose good people are everywhere . . .
  9. Jun 25, 2009 at 7:30 AM
    gjbonner
    Guy
    Northern Idaho
    Yeah i'm a Marine in Pendleton now but in a couple years i'll be back there.
  10. Jun 25, 2009 at 2:48 PM
    jimcasy
    Los Angeles
    hey gjbonner, did you have to use a spacer or trim your calipers to get the steelies to fit? I've ordered 16x8 mojaves but there seems to be no consistent answer if they will clear the calipers even with the right BS and offset. Btw, your 'other ride' is badass!
  11. Jun 25, 2009 at 7:30 PM
    gjbonner
    Guy
    Northern Idaho
    i used spidertrax 1 1/2inch spacers but that shouldnt have too much to do with the calipers. trust me they will clear the caliper. CraigTRD has em on his ride w/out spacers and they fit. he is the reason i got them because like u said its hard to get clear word on the 16" rim situation and he was the only one i could find. everyone is going 17 or higher or staying stock. i used the spacers because his was a 10" wide and mine is 12" wide but i would probably still not rubbed too much if i had the spacers off. you'll be good to go man. no trimming...but i will alittle on the fender behind the front tires. at max turn it touches just little
  12. Jun 25, 2009 at 7:44 PM
    jimcasy
    Los Angeles
    sweet . . . thanks a lot man . . .
