Alternaties to the Rigid Industries 98000 SR-M back-up kit
Discussion in 'Lighting' started by Wasatch, Feb 6, 2017.
  1. Feb 6, 2017 at 10:35 AM
    Wasatch
    Wasatch [OP] Well-Known Member
    Hi all,
    I'm looking for a (cheaper) alternative to the Rigid Industries 98000 SR-M Diffused Back-Up Light Kit:
    http://www.rigidindustries.com/led-lighting/98000
    Anyone know of an alternative brand light with the same dimensions?
    Thanks for the help!
  2. Feb 10, 2017 at 10:42 AM
    fishcommander
    fishcommander fishcommander
    S.E. PA.
    2016 taco limited white
    none as of yet
    I too have a thread in here about raptor light installation with ZERO responces also. crazy!
  3. Feb 10, 2017 at 10:58 AM
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    just installed some generic LED pods on my work truck (2001 Dodge 2500). 1,200 lumens ea for a third of the price. Wired into existing lighting & mounted to bumper. There are a ton of options out there on Amazon, etc... but if you want the exact same dimensions as the rigid industry lights you posted, that's going to be tricky.
  4. Feb 10, 2017 at 2:10 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Wasatch[OP] likes this.
  5. Feb 10, 2017 at 2:14 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Like this?
  6. Feb 10, 2017 at 2:18 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I just searched raptor lights tacomaworld
    I'm sure if you take the time to search...
    You can find better threads than I did.
    https://www.google.com/url?sa=t&sou...SgDMAA&usg=AFQjCNFOcMd5HLPXtew37-D2KmdRO5fSPg
    https://www.google.com/url?sa=t&sou...ggaMAA&usg=AFQjCNHgcXXbv2EEyzPfAsDH-A4lV2WcMw
    https://www.google.com/url?sa=t&sou...ghEMAY&usg=AFQjCNF9JgiVQzdjw1jyeZJMlZbfJSMFgA
  7. Feb 10, 2017 at 2:24 PM
    NightProwler
    Harlan
    Maricopa, Az
    And don't be dissuaded by the output picture they have. Looks like they used the spot version. The flood uses diffused lenses. Has a really awesome flood pattern.
  8. Feb 10, 2017 at 2:32 PM
    Wasatch
    Thank you very much for your help. It may be a littttle too big for the holes in a 4x HC bumper... but I will get measurements tonight .
    If it is too big, I'll just throw in a single LED pod
  9. Feb 10, 2017 at 2:45 PM
    Wasatch
    Also, found these ones too:
    LINK
    $15 each
  10. Feb 10, 2017 at 2:47 PM
    NightProwler
    Harlan
    Maricopa, Az
    Oh i see. Though you were just mounting them under a stock bumper or something and not in openings. I'm sure there's other options out there. Lots and lots of options on eBay. Its a lot to sift thru tho if you don't know exactly what you're looking for. Ha. Ibwoukd just input different specs in an eBay search. Like 20w led light. Or something close to what other lights are rated for. See what the specs are on the rigids as far as wattage or dimensions go and try that. Usually the dimensions on eBay will be off. Like if it's a 4.5" light, they sometimes list it as 4.6... GL
  11. Feb 10, 2017 at 2:47 PM
    NightProwler
    Harlan
    Maricopa, Az
    There ya go! Those look like clones. Wasn't sure if they were out there. Nice find!
